Chester's TJ build - Page 3 - JeepForum.com
post #31 of 925 Old 10-08-2012, 07:38 PM
G Beasley
Originally Posted by yellow_snocone View Post
Another fine day at work
What is it ?
G Beasley is offline
post #32 of 925 Old 10-08-2012, 07:45 PM
TJRHD
Slick jeep.. I really like the wheels and tars......
NOT A HATER
TJRHD is offline
post #33 of 925 Old 10-08-2012, 07:54 PM Thread Starter
yellow_snocone
Its a 100K Hyster container handler building a 100K Hyster container handler
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #34 of 925 Old 10-08-2012, 07:56 PM Thread Starter
yellow_snocone
Thanks man the tars are huge
Military Jeepers
post #35 of 925 Old 10-10-2012, 08:07 PM Thread Starter
yellow_snocone
Well it seems like I might not be done before the 20th.
I took the jeep out for a drive yesterday to test out my scraping sound solution which worked only to end up finding out I have DW now. I cant figure out how that happened since I didnt do anything to my front end.
Time to run through everything in hopes to fixing it before the 20th
Military Jeepers
post #36 of 925 Old 10-11-2012, 05:07 AM
G Beasley
Death wobble is not fun to chase down . Did you check the usual culprits , ie; trac bar and tres ? Mine was a bad balance and the trac bar .
post #37 of 925 Old 10-11-2012, 06:03 AM Thread Starter
yellow_snocone
Ya I'm going to check everything out tonight after work. I'm thinking my track bar might be the culprit.
Military Jeepers
post #38 of 925 Old 10-11-2012, 11:46 PM Thread Starter
yellow_snocone
Got the DW fixed the track bar bolt on the axle end opened the hole up. I simply drilled a slightly bigger hole and out in a beefy bolt.
Military Jeepers
post #39 of 925 Old 10-15-2012, 08:13 AM Thread Starter
yellow_snocone
It will seem my DW is still alive and well. Its back to the cutting board. I'm going to get a 4 wheel alignment and see if my rear is matching up as well as it should be.
Military Jeepers
post #40 of 925 Old 10-16-2012, 06:48 AM Thread Starter
yellow_snocone
Got the DW down to a slight shimmy at 45mph which I can deal with so I'm calling it good for a bit. After work I'm going to adjust the rear and move it forward a hair, its kind of touching my gas skid at full bump.
Military Jeepers
post #41 of 925 Old 10-16-2012, 12:50 PM
--chris--
--chris--'s Avatar
Excellent choice on the parts/build so far. Looks great.
--chris-- is offline
post #42 of 925 Old 10-16-2012, 12:54 PM Thread Starter
yellow_snocone
Thanks man, I did alot of research and hope I can keep it up
Military Jeepers
post #43 of 925 Old 10-19-2012, 06:09 PM Thread Starter
yellow_snocone
So I tested out the suspension to make sure things were good.
bumbstops are set perfectly
Military Jeepers
post #44 of 925 Old 10-20-2012, 05:16 PM Thread Starter
yellow_snocone
The jeep performed great today on the trail.
Here are some pictures. More to come.
Military Jeepers
post #45 of 925 Old 10-20-2012, 05:19 PM
gspup
Nice pics I'll be doing some night wheeling this evening !
gspup is offline
black tj , military jeep , work in progress
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
