Chester's TJ build - Page 28 - JeepForum.com
post #406 of 925 Old 07-07-2013, 03:20 PM Thread Starter
yellow_snocone
Top is the 7" stretched. Bottom is stock setup.
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #407 of 925 Old 07-07-2013, 03:29 PM
brplatz
Interesting, I won't get nearly 7" maybe 4-5" but still have to think about it
The Second Amendment is in place in case they ignore the others.
That's like saying you wish your boyfriend was a bit less gay.
MOΛΩN ΛΑΒΕ
brplatz is offline
post #408 of 925 Old 07-07-2013, 03:33 PM Thread Starter
yellow_snocone
I should be able to pull 7" but to be on the safe side I'm going with 6" since my 8.8 is not a forever deal. Plus I'm using a genright 15G comp tank
Military Jeepers
post #409 of 925 Old 07-07-2013, 03:36 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
I'm going to use the genright bezel on the side..... easy solution.
gst95dsm is offline
post #410 of 925 Old 07-07-2013, 04:05 PM
brplatz
Link? I can't find it
MOΛΩN ΛΑΒΕ
brplatz is offline
post #411 of 925 Old 07-07-2013, 04:18 PM Thread Starter
yellow_snocone
I never knew they had one.
Are you referring to this Nate?
http://www.genright.com/ProductInfo....0#.UdncBW10lXE
Military Jeepers
post #412 of 925 Old 07-07-2013, 04:31 PM
gst95dsm
gst95dsm's Avatar
No, you can buy just the plastic bezel they sell in their stretch kits. I'm posting from my phone so I can't provide a link, but I have seen just the bezel listed at several retailers.
gst95dsm is offline
post #413 of 925 Old 07-07-2013, 04:37 PM Thread Starter
yellow_snocone
Ok I'll look into it
Military Jeepers
post #414 of 925 Old 07-07-2013, 04:38 PM
aw12345
Yup now that you mention it Genright does sell it separate. It's what my bud used when he first stretched his
aw12345 is offline
post #415 of 925 Old 07-07-2013, 04:42 PM Thread Starter
yellow_snocone
Found it
GenRight GFB-2000 Gas Filler Bezel for Stretched Jeep TJ/LJ
http://www.dirtpartsdepot.com/servle...n-Right/Detail
Military Jeepers
post #416 of 925 Old 07-07-2013, 04:52 PM
AngryTJ
Found it
Yup that's what came with my genright tank
AngryTJ is offline
post #417 of 925 Old 07-07-2013, 04:57 PM
brplatz
That's interesting, I would probably have to make my own custom mounting holes in the corner guards
MOΛΩN ΛΑΒΕ
brplatz is offline
post #418 of 925 Old 07-07-2013, 05:49 PM
AngryTJ
Correction it came with my stretched genright corners with the hole pre cut
AngryTJ is offline
post #419 of 925 Old 07-07-2013, 08:01 PM
gst95dsm
gst95dsm's Avatar
Yeah that's it, my plan is to make the stretch cut into my existing Metalcloak corner guards, then graft onto the front portion the correct filler piece. I figure a little welding, body filler and grinding and sanding I'll have some stretched corner guards without spending much, and I won't have to drill any new holes in my tub. Lot's more work though than just buying another set. Oh well.
gst95dsm is offline
post #420 of 925 Old 07-07-2013, 09:42 PM Thread Starter
yellow_snocone
Heck of alot more work. Why not sell and get new corners?
Military Jeepers
black tj , military jeep , work in progress
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 10:59 PM
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 12:15 PM
JeepDVL45's 'Bruiser' Build -- A Daily Driver's slow build JeepDVL45 Jeep Builds 41 08-11-2011 10:44 AM
