Chester's TJ build - Page 2 - JeepForum.com
post #16 of 925 Old 09-26-2012, 09:24 PM
gspup
Checking in. Looking to do some wheeling your way next spring.
gspup is offline
post #17 of 925 Old 09-26-2012, 09:40 PM Thread Starter
yellow_snocone
By all means come on down. I've been reading your thread great build so far. I would love to come up and wheel in CO sometime too the trails look great.
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #18 of 925 Old 09-28-2012, 08:27 PM Thread Starter
yellow_snocone
Finally got all the mount holes drilled to the right bolt size.
I had to shave a bolt head to allow it to fit pass the shock mount
Axle goes in tomorrow
Military Jeepers
post #19 of 925 Old 09-29-2012, 01:39 PM Thread Starter
yellow_snocone
I got the axle in but ran into an issue with one of my upper control arms so I'll wait on cycling the suspension
I couldn't take the center ring out to regrease the bearing
Called RC and got a replacement jonny joint. Thankfully these arms are only temporary I have all new custom JJ arms for my 4 link
I'm going to have to figure out a way to use the stock e-brake cables I have on the 8.8 if not I'll get the kit from ECGS
Military Jeepers
post #20 of 925 Old 10-05-2012, 07:58 PM Thread Starter
yellow_snocone
Finally got the rest of my parts in the mail
Brown Dog MML
My new upper CA JJ
I had a hick up with my u-joint with my new flange
Got a new one and was good to go
DV in with CA's adjusted
Finished alot today. Tomorrow I'm going to install the MML/BL with my new skid
Military Jeepers
post #21 of 925 Old 10-06-2012, 06:19 PM Thread Starter
yellow_snocone
Got the BL and MML lift in
Not much trouble from the install besides having to file down a few mounts to fit the BL. The motor mounts went in without any issues at all, tough working on the driver side with all lines being there. I didnt get a chance to take any pictures from the install.
Back on all fours. I just need to adjust my shock mounts. A quick grind of and reweld should cover it.
Military Jeepers
post #22 of 925 Old 10-06-2012, 06:23 PM Thread Starter
yellow_snocone
I need to finish the jeep before Thursday since the Girlfriend will be in town and I cant work when shes here but I need it done before the 20th for Carnage Canyon.
To Do List
flush brakes
install New UCF skid
Adjust rear pinion angle
Fix Shock mounts on axle
Military Jeepers
post #23 of 925 Old 10-06-2012, 09:28 PM
gspup
To Do List
flush brakes
Carnage in CO ?
gspup is offline
post #24 of 925 Old 10-06-2012, 09:40 PM Thread Starter
yellow_snocone
No in southern New mexico. Its just outside of Oro Grande,NM
Great trail lots of shelves to climb
Military Jeepers
post #25 of 925 Old 10-07-2012, 04:08 PM Thread Starter
yellow_snocone
painted the UCF skid
Before
After
Military Jeepers
post #26 of 925 Old 10-07-2012, 05:21 PM
G Beasley
Very nice ! The extra clearance is going to let you get even further into trouble
G Beasley is offline
post #27 of 925 Old 10-07-2012, 05:28 PM Thread Starter
yellow_snocone
Driveway shoot
Military Jeepers
post #28 of 925 Old 10-07-2012, 05:29 PM Thread Starter
yellow_snocone
Tell me about it
When I went up in tire size I started doing the risker stuff too
Military Jeepers
post #29 of 925 Old 10-08-2012, 01:14 PM Thread Starter
yellow_snocone
Today I got the shock mounts fixed and got my ebrake cable setup up.
Only thing left is my pinion angle and now have a noise coming from my rear. Sounds like something is scraping my brake pads. It increases with speed so that might be the problem area.
Military Jeepers
post #30 of 925 Old 10-08-2012, 06:00 PM Thread Starter
yellow_snocone
Another fine day at work
Military Jeepers
black tj , military jeep , work in progress
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
