Chester's TJ build - Page 15 - JeepForum.com
post #211 of 925 Old 02-02-2013, 02:58 PM Thread Starter
yellow_snocone
4.88' s
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #212 of 925 Old 02-02-2013, 03:24 PM
NYGLT56
Your Local Body Builder
NYGLT56's Avatar
Originally Posted by yellow_snocone
4.88' s
Good choice haha
2014 TJOTY Winner
A Daily Driven Lowrider TJ on 40s.
NYGLT56 is offline
post #213 of 925 Old 02-02-2013, 03:55 PM Thread Starter
yellow_snocone
Ya I might as well jump right to the proper gear instead of messing with 4.56' s
Military Jeepers
post #214 of 925 Old 02-10-2013, 08:18 PM Thread Starter
yellow_snocone
So the regear has began but is far from done. We started with the front knowing it would be the most difficult. Everything got setup up without much trouble minus some issues with the crush sleeve. After some testing and refitting of the pinion shaft we got the right depth and had the front locked in. Now on to the rear which first started off with what we thought was to much pinion depth because we could not move the ring gear if we tried. So we adjusted the pinion shim to .00 form .30 to have a good starting point. The second try gave us great results but the pinion need to come in more so we moved up to .10 on the shim. On the third try we had a great wear pattern but ran into another issue. The ring gear binds at a certain spot. It may be that the ring gear is warped or the carrier . I'm going to repress the bearings on the carrier and maybe drop down the shim on the pinion to .08. I'm hoping the ring and carrier are fine but we'll see.
We had the pinion in to much.
Pretty good wear pattern
The 8.8
Military Jeepers
post #215 of 925 Old 02-10-2013, 08:29 PM
NYGLT56
NYGLT56's Avatar
The 8.8
Impressive. I would never touch gearing lol
2014 TJOTY Winner
NYGLT56 is offline
post #216 of 925 Old 02-10-2013, 08:34 PM Thread Starter
yellow_snocone
Neither would I without the help of my friend who is pretty good with gears. I'm learning alot so I can help the next person with their install if their feeling up to it
Military Jeepers
post #217 of 925 Old 02-10-2013, 08:44 PM
NYGLT56
NYGLT56's Avatar
Ah that makes sense haha. I would never go at it alone lol
2014 TJOTY Winner
NYGLT56 is offline
post #218 of 925 Old 02-10-2013, 09:03 PM Thread Starter
yellow_snocone
After learning what I have its not that hard to be quite honest. I wouldn't recommend doing it the first time on your own, especially without the proper tools.
Military Jeepers
post #219 of 925 Old 02-10-2013, 09:16 PM
NYGLT56
NYGLT56's Avatar
Good to know. What's next??
2014 TJOTY Winner
NYGLT56 is offline
post #220 of 925 Old 02-10-2013, 09:29 PM Thread Starter
yellow_snocone
outboarding frt and rear shocks with my rear spring perch.
Military Jeepers
post #221 of 925 Old 02-16-2013, 11:21 AM
G Beasley
Its the weekend wheres the pictures ?
G Beasley is offline
post #222 of 925 Old 02-16-2013, 12:58 PM Thread Starter
yellow_snocone
Well thats not happening until the regear is done. Tomorrow I'm going to try to finish the rear. Today I'm buying a welder, its a hobart 187.
Military Jeepers
post #223 of 925 Old 02-16-2013, 01:11 PM
G Beasley
Thats a nice welder , should serve you well . Whats left to finish the rear ?
post #224 of 925 Old 02-16-2013, 02:56 PM Thread Starter
yellow_snocone
The ring gear is binding at a certain spot we're trying to figure out why, so I'm going to check my backlash and make sure the ring gear isn't warped. So tomorrow will involve so adjusting and hopefully the rear gearing should be done.
Military Jeepers
post #225 of 925 Old 02-17-2013, 06:29 PM Thread Starter
yellow_snocone
ROUND TWO
We swapped the the ring gear 180 on the carrier and adjusted the shims on the carrier and success
Military Jeepers
black tj , military jeep , work in progress
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
