Cavasar's TJ - Page 25 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Cavasar's TJ
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 09-14-2013, 12:38 AM   #361
joeyk803c
I'll try and snap some pictures of the wiring harness tomorrow while I am in the engine bay cleaning up the wiring I have running near the firewall.
joeyk803c is offline   Reply With Quote Quick reply to this message
Unread 09-14-2013, 07:02 AM   #362
Cavasar
No Longer DD
Cavasar's Avatar
Sounds good, I have the wiring ready now. Just waiting for my boss to get back with me about the powdercoating.
Cavasar's TJ
May TJ of the Month 2015
Cavasar is offline   Reply With Quote Quick reply to this message
Unread 09-14-2013, 07:54 PM   #363
Cavasar
No Longer DD
Cavasar's Avatar
Should be getting the mounts powder coated early next week, and hopefully get the bar up by Thursday. Also ordered a few more goodies
Cavasar's TJ
Unread 09-19-2013, 03:16 PM   #364
Cavasar
No Longer DD
Cavasar's Avatar
Dropped the mounts off yesterday for the powder coater. Today I received my Uniden PRO520XL, 3' Fire stick II, spring, PA speaker, and still waiting on the coax, SWR meter, and antenna mount.
001 (38) by Cavasar, on Flickr
Cavasar's TJ
Unread 09-21-2013, 06:13 PM   #365
Cavasar
No Longer DD
Cavasar's Avatar
Well I got the CB/antenna/PA speaker installed but for some reason I'm not getting power to the CB, I'm not sure how electricals work...
006 by Cavasar, on Flickr
007 by Cavasar, on Flickr
005 by Cavasar, on Flickr
Cavasar's TJ
Unread 09-21-2013, 08:50 PM   #366
Cwest22
How are you running it?
[url]http://www.exiledoffroad.com/[/url]
Cwest22 is offline   Reply With Quote Quick reply to this message
Unread 09-21-2013, 09:04 PM   #367
Cavasar
No Longer DD
Cavasar's Avatar
I ran the wires behind the dash and have the power wire in a thing called "add a fuse" and plugged it into my glovebox fuse panel. Tried to turn it on though and I'm not getting power I'll see if a friend that knows more about CBs can show me what I did wrong.
Cavasar's TJ
Unread 09-21-2013, 09:28 PM   #368
Cwest22
I have the same thing. My add a fuse has two fuse slots and I had to use both the fuse spots to rt power to cb. Also what fuse spot are you using?
Unread 09-21-2013, 09:45 PM   #369
Cavasar
No Longer DD
Cavasar's Avatar
It has two 10A fuses in it and it is in radio (15?) slot.
Cavasar's TJ
Unread 09-21-2013, 09:47 PM   #370
Cwest22
That's the exact one I have mine in. So, maybe your ground? If not that it could be the 2a fuse in the power wire of your cb.
Unread 09-21-2013, 09:50 PM   #371
Cavasar
No Longer DD
Cavasar's Avatar
I thought ground but I tried it on a couple spots and still nothing, in line fuse looks good. I did splice into the wires to add some disconnects to it so I can pull out the CB in case of rain, might not be making a solid connection in one of those spots.
Cavasar's TJ
Unread 09-21-2013, 09:57 PM   #372
Cwest22
That could be it. Especially if there is plastic sheathing crimped in with your disco.unless you soldered. Your jeeps freaking sweet by the way just read your build thread. Can't wait to get back home to Texas to hit some of the spots I've seen on here
Unread 09-21-2013, 10:17 PM   #373
Cavasar
No Longer DD
Cavasar's Avatar
I just used regular crimp/heat shrink for the splice parts, the disconnects are little battery disconnects that I snipped the ring terminals off of.
Thanks man, I really try to put my best into the Jeep. I'm happy where it is at right now, but I can't wait until I can put in a D44 or 8.8 and 35s. That's the biggest I plan on going with maybe some 4" springs in the future as I want it to be a fun streetable Jeep.
Cavasar's TJ
Unread 09-22-2013, 11:16 AM   #374
Cavasar
No Longer DD
Cavasar's Avatar
Talking to a guy about trading my hard top for his black hard top. We'll see if it goes through. Edit: Nevermind, he found my ad on College Station C-list and then he decided that was too far of a drive to trade
Cavasar's TJ
Unread 09-22-2013, 11:18 AM   #375
tyvanwie
Nice
tyvanwie is offline   Reply With Quote Quick reply to this message
