Cavasar's TJ - Page 19 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Cavasar's TJ
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 07-23-2013, 11:18 AM   #271
tyvanwie
Cool. Just making sure
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 07-23-2013, 11:23 AM   #272
Cavasar
No Longer DD
Cavasar's Avatar
Come on Thursday (payday)!
Cavasar's TJ
May TJ of the Month 2015
Cavasar is offline   Reply With Quote Quick reply to this message
Unread 07-23-2013, 12:34 PM   #273
Cuder
All it takes is a simple toggle switch wired to the starter or ignition switch. I did it on my 68 Chevy PU, I had the switch hidden behind the glove box on it. I need to do the Jeep.
You could also pull the starter relay under the hood at night.
My Build Thread:
http://www.jeepforum.com/forum/f22/c...-lift-1268317/
Cuder is offline   Reply With Quote Quick reply to this message
Unread 07-23-2013, 01:16 PM   #274
Cavasar
No Longer DD
Cavasar's Avatar
I don't really know anything about electrical. Could I just splice a toggle/push button into the 106 Connector?
One of these?
Cavasar's TJ
Unread 07-23-2013, 03:17 PM   #275
Cuder
Splice the BLK/WT on pin 8 of the ignition switch connector or the LG/BK wire going to the starter.
My Build Thread:
Unread 07-23-2013, 06:45 PM   #276
Cavasar
No Longer DD
Cavasar's Avatar
Just ordered:
31 tooth Speedo gear from Quadratec
Pair of Maxxima Hybrid Reverse/STT LED lights from eBay
Frame tie-ins for rear bumper from GPF
I don't think I'm ever really in that bad of an area where my Jeep is at too much risk. I'd like to install the kill switch but I don't feel confident enough to cut into the wiring harness.
Cavasar's TJ
Unread 07-23-2013, 09:25 PM   #277
TrailJ
Originally Posted by Cavasar View Post
Picked up some Autolite Platinums (AP985) from work today, I'll change those out before I move back to school. Ty reminded me to remove my rear bumper. Waiting on Dirtworx bumper/carrier but it hasn't even shipped yet, I'm just excited! Looks kinda goofy now though
I think you want APP or XP or plain 985. the one sided platinum are supposed to idle poorly in the 4.0
TrailJ is offline   Reply With Quote Quick reply to this message
Unread 07-23-2013, 09:39 PM   #278
Cavasar
No Longer DD
Cavasar's Avatar
I think the AP985 plugs work fine with the older 4.0 that still has a distributor. Once you get to the distributor-less 4.0s you're better off with double platinums.
the AP985 can eventually cause hard to diagnose problems with a rough running engine with the newer 4.0L distributorless engines. It's with the older non-fussy 4.0L with a distributor where the AP985 is an excellent choice and what I run in my '97 4.0L engine.
Cavasar's TJ
Unread 07-23-2013, 11:13 PM   #279
TrailJ
Ahhh thx didn't know that.
Unread 07-23-2013, 11:57 PM   #280
Cavasar
No Longer DD
Cavasar's Avatar
Yea I knew there was somethin about em so I searched around before I bought em. Thanks for the thought though.
Cavasar's TJ
Unread 07-24-2013, 09:19 AM   #281
Cavasar
No Longer DD
Cavasar's Avatar
I just thought of something. My new bumper will have a receiver hitch in it and I'll add the frame tie-ins, so I should be ok removing the lower bolt on receiver and just towing from my bumper from now on right?
Cavasar's TJ
Unread 07-24-2013, 09:27 AM   #282
h1driver
Should be- Just pay attention to the load rating of your new hitch (bumper), and you should be just fine. Probably won't be an issue anyhow, since you're towing with a Jeep
Will actually be better off... Get that old draw-tite off of there so it can't hang on te rocks... More clearance
"A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed."
So, Suck-It Trebek!!! MOΛΩN ΛΑΒΕ
My "Build" - Collect and Assemble
h1driver is offline   Reply With Quote Quick reply to this message
Unread 07-24-2013, 10:25 AM   #283
Cavasar
No Longer DD
Cavasar's Avatar
And done. Yea it hit the rocks more than my gts did. Well this is good news, I can sell it and negate a little of the cost of the new one. My gts is looking a bit rust colored, maybe I'll need a new one of those before too long
Cavasar's TJ
Unread 07-24-2013, 11:30 AM   #284
Cavasar
No Longer DD
Cavasar's Avatar
Just found out my speedo gear is back ordered
Cavasar's TJ
Unread 07-24-2013, 12:24 PM   #285
Cuder
I may have a 31 tooth gear, I'll look when I get home. My brother gave me a box of parts and there was a gear in it. I never have changed mine out, I need a 26 tooth.
My Build Thread:
