Cavasar's TJ - Page 9 - JeepForum.com
post #121 of 1323 Old 06-04-2013, 01:12 AM
midnight_f150
Maybe you should post them up for sale and see what happens!! You might be able to make a quick sale on them.
midnight_f150 is offline
post #122 of 1323 Old 06-04-2013, 07:18 AM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
After my next paycheck I might post them on Craigslist and see what happens. I'll just keep em attached until I get a hit that actually wants one.
May TJ of the Month 2015
Cavasar is offline
post #123 of 1323 Old 06-04-2013, 04:37 PM
midnight_f150
Would you get the overline or the arch fenders?
post #124 of 1323 Old 06-04-2013, 04:44 PM
midnight_f150
I know this will be a long drive but it would be worth it.
post #125 of 1323 Old 06-04-2013, 05:39 PM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Yea definitely a long drive, I want to try to keep it under 4hrs until I have a tow rig/trailer. (Not anytime soon)
Cavasar is offline
post #126 of 1323 Old 06-06-2013, 04:04 PM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Well I was finally able to finish the Monstaliner today, it's drying now so I'll add pics later. I did the two coats and thought I was being generous on each coat but I ended with half the gallon left... We'll see how it turns out. Probably replacing the RMS tomorrow.
002 (18)
003 (15)
004 (10)
005 (9)
Cavasar is offline
post #127 of 1323 Old 06-07-2013, 10:32 AM
Cuder
I had about a pint left over. If it looks good then don't worry about it. After it cures good it will take alot of force to go thru it.
Good luck with the RMS. But are you sure the leak is coming from there? Sometimes the aft side of the valve cover leaks and it looks like a RMS leak. I need to look at my valve cover also and see if it needs a new gasket.
My Build Thread:
Cuder is offline
post #128 of 1323 Old 06-07-2013, 11:13 AM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Well I've looked around and it doesn't appear to be the valve cover. I'll change the RMS and keep my fingers crossed that that's the fix.
Edit: I can't even get the O2 sensor off, so I posted in Dirty Old Man's thread on LSJC forum for some help. I'll get to it on a later day.
Cavasar is offline
post #129 of 1323 Old 06-07-2013, 02:13 PM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Well the latch in my tailgate is broken after it slammed shut multiple times on the trail. I tried messing with it to make it functional again, but no luck. $200 for the SWAG Offroad kit seems a bit much for just hardware, I might just run around with it ratchet strapped. I found new latches for ~$100.
Cavasar is offline
post #130 of 1323 Old 06-07-2013, 03:26 PM
Cuder
Have you tried adjusting the latch? I would help you with the RMS, but I have the weekend booked. I'm taking my wife 4 wheelin for the first time at Bridgeport in the morning.
Do you have a torch? Heating it up will help alot.
My Build Thread:
Cuder is offline
post #131 of 1323 Old 06-07-2013, 03:32 PM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
It's not that the latch needs adjusted, but the internal connecting piece that connects the lock cylinder to the lever. That and the latch housing is bent.
Cavasar is offline
post #132 of 1323 Old 06-07-2013, 06:53 PM
dirtdude35
on the O2 sensor why couldnt you just unplug it? Then drop the exhaust and pan. I would help you but I have to work this weekend
04 LJ 2in body lift, 4in rough country n2.0, winch, 35 Goodyear Wrangler MT/rs new style, poison spyder stinger, front locker
93 ZJ, 2in BB, Moabs, Goodyear wanglers MT/r Cherry bomb glass pack
dirtdude35 is offline
post #133 of 1323 Old 06-07-2013, 07:08 PM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Well the O2 sensors are the 15 year old factory ones. So I think they've kind of formed to the pipe.
Cavasar is offline
post #134 of 1323 Old 06-07-2013, 07:22 PM
dirtdude35
Follow the wires up and there should be a plug up there. This is where it is on my 04. Cant remember if the older ones are different or not. be to long since I have been under one
post #135 of 1323 Old 06-07-2013, 07:34 PM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Alright cool, I'll take a look when I get home.
Cavasar is offline
