Cavasar's TJ - Page 57 - JeepForum.com
post #841 of 1319 Old 04-24-2014, 09:45 AM
tyvanwie
Not too bad considering everything that's going into it.
tyvanwie is offline
post #842 of 1319 Old 04-24-2014, 09:51 AM
NYGLT56
Your Local Body Builder
NYGLT56's Avatar
Damn. That's pricey. I built mine for around $500....
I paid 4k for fully built JK axles.
Instagramin --> @cornfedarmybro
2014 TJOTY Winner
NYGLT56 is offline
post #843 of 1319 Old 04-24-2014, 09:55 AM
RWKHaus
1990 XJ Cherokee
for 900-1000$ more there could have been a Currie Hp44 rockjock that uses the new JK larger gear set, and 3" tubes, etc. I guess its more money, but just seems like it would have been 20% more for 50% more axle, and held its value for ever really. That HPD30 will only be worth about 1000-1700K at most if you ever want to upgrade. The Currie would be at 3K at least.
But at least the D30 will be ok with 35's with all you put in to it...
Brook "He kissed me at KOH, you should ask him about itů"
RWKHaus is offline
post #844 of 1319 Old 04-24-2014, 10:05 AM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Yea but mine doesn't require and fab work, just turning some wrenches.
I looked into the 44 and I juts couldn't justify the cost for what I plan on doing. When you look at how much gears, install kit, locker, blah blah would have cost to just add to my LP30 the HP was only $200-300 more. Plus I'll be selling the LP w/ Aussie to local student. I honestly don't ever see this Jeep going bigger than 35s. Plus I'm not going to sell the TJ, it'll be my son's some day (or daughter I suppose). 24 years from now
Cavasar's TJ
May TJ of the Month 2015
Cavasar is offline
post #845 of 1319 Old 04-24-2014, 10:09 AM
NYGLT56
NYGLT56's Avatar
Originally Posted by Cavasar
Yea but mine doesn't require and fab work, just turning some wrenches. I looked into the 44 and I juts couldn't justify the cost for what I plan on doing. When you look at how much gears, install kit, locker, blah blah would have cost to just add to my LP30 the HP was only $200-300 more. Plus I'll be selling the LP w/ Aussie to local student. I honestly don't ever see this Jeep going bigger than 35s. Plus I'm not going to sell the TJ, it'll be my son's some day (or daughter I suppose). 24 years from now
The HP30 didn't require any fab work.
2014 TJOTY Winner
NYGLT56 is offline
post #846 of 1319 Old 04-24-2014, 10:14 AM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
But the JK44 did. I'm still in school, I'll save the big stuff for when I'm married and I'll build up the wife's JKU.
Cavasar's TJ
Cavasar is offline
post #847 of 1319 Old 04-24-2014, 10:37 AM
NYGLT56
NYGLT56's Avatar
I only mentioned the jk44s because the pair of fully built ones were 1k more than your HP30.
Try a junkyard. Build it gradually and save $$.
2014 TJOTY Winner
NYGLT56 is offline
post #848 of 1319 Old 04-24-2014, 10:43 AM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Eh maybe in the future. While I have people's attention, is it just my TJ or does the gas pedal on y'all's sit a good bit lower than the brake pedal? I can pull it up to about even with the brake pedal but it falls right back down a couple inches.
Cavasar's TJ
Cavasar is offline
post #849 of 1319 Old 04-24-2014, 11:11 AM
tyvanwie
I believe mines like that too.
tyvanwie is offline
post #850 of 1319 Old 04-24-2014, 12:34 PM
holdren4100@cyb
It's designed that way so you don't hit the gas when you step on the brakes.
holdren4100@cyb is offline
post #851 of 1319 Old 04-24-2014, 12:50 PM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Thanks guys. It just always made me wonder, never thought to ask.
Cavasar's TJ
Cavasar is offline
post #852 of 1319 Old 04-27-2014, 10:52 PM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Alright guys I'm having second thoughts here. The HP30 has a Detroit full case soft locker, done. The rear locker hasn't been ordered yet and I was thinking this might not be a bad time to get OBA and put a selectable in the rear. I'm not really worried about the soft locker for on road use, it's the OBA I would like. I don't usually get to air down because most parks don't have air stations. I don't necessarily have the extra money right now, but my birthday is in May so I will get probably the extra I need to get the Arb then. So the question:
Detroit full case soft locker = $670
Arb air locker + High out put compressor $1040 + $275 = $1300
or am I better off just getting a CO2 tank to air the tires?
Cavasar's TJ
Cavasar is offline
post #853 of 1319 Old 04-27-2014, 10:53 PM
tjwood02
Would you consider a seperate OBA set up and different locker? You could probably do it cheaper that way unless youre looking for a selectable.
tjwood02 is offline
post #854 of 1319 Old 04-27-2014, 10:56 PM
NYGLT56
NYGLT56's Avatar
I choose selectable.
Ran a Detroit rear for 3 years In a 5spd and hated it.
2014 TJOTY Winner
NYGLT56 is offline
post #855 of 1319 Old 04-27-2014, 11:06 PM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Man you guys are fast.
Would other OBA replace my ac comp? If so, no. What other locker are you suggesting?
You're one of the few people I've heard that doesn't like the Detroit in the rear. From what I under stand the auto vs 5spd makes a difference.
Cavasar's TJ
Cavasar is offline
