Cavasar's TJ - Page 19 - JeepForum.com
post #271 of 1316 Old 07-23-2013, 10:18 AM
tyvanwie
Cool. Just making sure
tyvanwie is offline
post #272 of 1316 Old 07-23-2013, 10:23 AM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Come on Thursday (payday)!
Cavasar's TJ
May TJ of the Month 2015
Cavasar is offline
post #273 of 1316 Old 07-23-2013, 11:34 AM
Cuder
All it takes is a simple toggle switch wired to the starter or ignition switch. I did it on my 68 Chevy PU, I had the switch hidden behind the glove box on it. I need to do the Jeep.
You could also pull the starter relay under the hood at night.
Cuder is offline
post #274 of 1316 Old 07-23-2013, 12:16 PM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
I don't really know anything about electrical. Could I just splice a toggle/push button into the 106 Connector?
One of these?
Cavasar's TJ
Cavasar is offline
post #275 of 1316 Old 07-23-2013, 02:17 PM
Cuder
Splice the BLK/WT on pin 8 of the ignition switch connector or the LG/BK wire going to the starter.
Cuder is offline
post #276 of 1316 Old 07-23-2013, 05:45 PM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Just ordered:
31 tooth Speedo gear from Quadratec
Pair of Maxxima Hybrid Reverse/STT LED lights from eBay
Frame tie-ins for rear bumper from GPF
I don't think I'm ever really in that bad of an area where my Jeep is at too much risk. I'd like to install the kill switch but I don't feel confident enough to cut into the wiring harness.
Cavasar's TJ
Cavasar is offline
post #277 of 1316 Old 07-23-2013, 08:25 PM
TrailJ
Originally Posted by Cavasar View Post
Picked up some Autolite Platinums (AP985) from work today, I'll change those out before I move back to school. Ty reminded me to remove my rear bumper. Waiting on Dirtworx bumper/carrier but it hasn't even shipped yet, I'm just excited! Looks kinda goofy now though
I think you want APP or XP or plain 985. the one sided platinum are supposed to idle poorly in the 4.0
TrailJ is offline
post #278 of 1316 Old 07-23-2013, 08:39 PM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
I think the AP985 plugs work fine with the older 4.0 that still has a distributor. Once you get to the distributor-less 4.0s you're better off with double platinums.
the AP985 can eventually cause hard to diagnose problems with a rough running engine with the newer 4.0L distributorless engines. It's with the older non-fussy 4.0L with a distributor where the AP985 is an excellent choice and what I run in my '97 4.0L engine.
Cavasar's TJ
Cavasar is offline
post #279 of 1316 Old 07-23-2013, 10:13 PM
TrailJ
Ahhh thx didn't know that.
TrailJ is offline
post #280 of 1316 Old 07-23-2013, 10:57 PM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Yea I knew there was somethin about em so I searched around before I bought em. Thanks for the thought though.
Cavasar's TJ
Cavasar is offline
post #281 of 1316 Old 07-24-2013, 08:19 AM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
I just thought of something. My new bumper will have a receiver hitch in it and I'll add the frame tie-ins, so I should be ok removing the lower bolt on receiver and just towing from my bumper from now on right?
Cavasar's TJ
Cavasar is offline
post #282 of 1316 Old 07-24-2013, 08:27 AM
h1driver
h1driver's Avatar
Should be- Just pay attention to the load rating of your new hitch (bumper), and you should be just fine. Probably won't be an issue anyhow, since you're towing with a Jeep
Will actually be better off... Get that old draw-tite off of there so it can't hang on te rocks... More clearance
"A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed."
So, Suck-It Trebek!!! MOΛΩN ΛΑΒΕ
My "Build" - Collect and Assemble
h1driver is offline
post #283 of 1316 Old 07-24-2013, 09:25 AM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
And done. Yea it hit the rocks more than my gts did. Well this is good news, I can sell it and negate a little of the cost of the new one. My gts is looking a bit rust colored, maybe I'll need a new one of those before too long
Cavasar's TJ
Cavasar is offline
post #284 of 1316 Old 07-24-2013, 10:30 AM Thread Starter
Cavasar
No Longer DD
Cavasar's Avatar
Just found out my speedo gear is back ordered
Cavasar's TJ
Cavasar is offline
post #285 of 1316 Old 07-24-2013, 11:24 AM
Cuder
I may have a 31 tooth gear, I'll look when I get home. My brother gave me a box of parts and there was a gear in it. I never have changed mine out, I need a 26 tooth.
Cuder is offline
