can someone please help (79 cj7) - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > can someone please help (79 cj7)
NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDWe have Engo 10k Synthetic IN STOCK!!! Hurry while supplieSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREE
Unread 09-25-2014, 03:21 PM   #1
tonypajamaz100
i have a 1979 cj7 straight 6. the original frame rusted out so we went out a 1999-2001 wrangler tub and frame. mounted the axles and engine, but when we were went to put on the drive shafts we noticed that they were 6 in off where they needed to be. It was too close in the rear and too far in the front. Is there anything i can do. If not, what should i do?
tonypajamaz100 is offline   Reply With Quote Quick reply to this message
Unread 09-25-2014, 04:21 PM   #2
84jeepcj7rock
What suspension are you using?
84jeepcj7rock is online now   Reply With Quote Quick reply to this message
Unread 09-25-2014, 05:32 PM   #3
tonypajamaz100
Stock
Unread 09-25-2014, 05:54 PM   #4
84jeepcj7rock
Originally Posted by tonypajamaz100
Stock
stock for a 79 is leaf springs. Stock for a 99 is coil springs w links. I assume you mean the stock coils w the 99 frame. The I6 was an option in 99 so motor mounts should be interchangeable.
You didn't say which DS where shorter/ longer.
Unread 09-25-2014, 05:58 PM   #5
84jeepcj7rock
Are the axles centered in the wheel well. If so, then your motor mounts are in the wrong place. If the axles are not centered, the move the rear back and decide if you want to stretch the front. Steering linkage shouldn't line up if the front is 6" forward
