Build thread: “Project Taildragger” - Page 27 - JeepForum.com
post #391 of 487 Old 10-03-2010, 08:46 AM Thread Starter
jkl
Here is what needs to be done by the 21st so I can take it to Jeeptoberfest
Replace transfercase adapter
Make the sidemount for the transfercase
Fix the overheating problem (going to do the contour dual fan)
Gear change (found someone to do it, need to order gears)
Replace power steering belt
Replace lower radiator hose (somehow got a small hole in it)
Exhaust
I'm sure I'll find some small items when I go through and double check everything. It's going to be close but I think it will be ready.
'13 10th Anniversary Unlimited Rubi
...now parting out
jkl is offline
post #392 of 487 Old 10-04-2010, 08:40 PM Thread Starter
jkl
Bought a contour fan assembly today. Tried ordering a ring and pinion but got dispatched to a fire in the middle of the order , guess I'll call em back tomorrow.
...now parting out
jkl is offline
post #393 of 487 Old 10-04-2010, 10:41 PM
AustinTexasXJ
1987 MJ Comanche
damn im soo glad its coming together..
its been along project and wait for some of us. haha
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
AustinTexasXJ is offline
post #394 of 487 Old 10-05-2010, 06:52 AM
Boundless
wow you are really getting some head way... can't wait to see it (you & the gang) at Jeeptoberfest.
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
Boundless is offline
post #395 of 487 Old 10-05-2010, 05:47 PM Thread Starter
jkl
1 year and 10 months, I'm ready to have this thing done. We'll no Jeep is actually done, but I'm ready to start wheelin it. Once I get it going I'll probably put off the finishing touches (paint and such) till after the first of the year.
It's looking like it will be there and will be nice to see you again, it's been a while.
Ordered a set of 5.13 gears today the front and should be here Thurs and then having it installed on Fri.
...now parting out
jkl is offline
post #396 of 487 Old 10-08-2010, 10:59 AM
IPB
I cannot wait to see this beast finished!!!!
Too many toys not enough time....
IPB is offline
post #397 of 487 Old 10-08-2010, 06:16 PM Thread Starter
jkl
Today I had the front axle regeared to 5.13 Going wheelin tomorrow so not sure how much I'll get done to it, hopefully at least get the front end back under it. Have the tranny/transfer case adapter and seals and the contour fan sitting in the shop waiting to go in.
...now parting out
jkl is offline
post #398 of 487 Old 10-08-2010, 06:27 PM
johnny9
gettin real close now! your avatar will be alright on the door with the red paint also
see ya in the am
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
post #399 of 487 Old 10-08-2010, 09:45 PM
hallsofstone
I just read this entire build durning my shift at my second job today. I think I need to get some better jobs...
This is one really cool, original build and I can't wait to see some wheeling videos. Best of luck to you!
Jeeping Ohio Every Day
00 TJ Sport - Ever evolving DD/Rig
85 Suzuki GS700 - ugly
K.C.C.O.
hallsofstone is offline
post #400 of 487 Old 10-10-2010, 02:57 PM Thread Starter
jkl
I think you have a pretty good job if you can be on Jeepforum during your shift
...now parting out
jkl is offline
post #401 of 487 Old 10-10-2010, 03:02 PM Thread Starter
jkl
Front end stripped and ready to be dropped off for a regear
Richmond 5.13s and install kit
Installed
Ford Contour fan, still need to install it, its just sitting on there
Tranny/transfercase adapter
...now parting out
jkl is offline
post #402 of 487 Old 10-10-2010, 03:10 PM
hallsofstone
Got a point there that nobody could argue. I look between incoming calls. Basically what I mean is that I don't make enough to put any real money into my Jeep.
It looks like you're really making your money count on this very original build. Cool idea and I'm looking forward to seeing wheeling vids. It DOES sound like a real beast!
K.C.C.O.
post #403 of 487 Old 10-15-2010, 04:53 PM
johnny9
I hope it don't take that long, it's already been long enough. Wanted to finish it by this spring but now I'm shootin for fall (Jeeptoberfest).
been reading thru the hole thread again to see if anything benifit me now..it would benifit me to have a d60 front and your qoute is on track i see
build-
johnny9 is offline
post #404 of 487 Old 10-15-2010, 06:35 PM Thread Starter
jkl
here is what needs to be done by the 21st so i can take it to jeeptoberfest
replace transfercase adapter done!
make the sidemount for the transfercase done!
fix the overheating problem (going to do the contour dual fan) done! Who ever figured this swap out is a genuis.
gear change (found someone to do it, need to order gears) done!
replace power steering belt done!
replace lower radiator hose (somehow got a small hole in it) done!
exhaust somewhat done
Above items are finished
Putting the new trans/transfercase adapter on
New hood hinges and hood catches. Also hit some of the bare steel areas where I sanded with some primer.
Took it back down to my pasture and wheeled it a bit more and it did good. Now I just need to get a nut for the steering wheel, rebolt down the steering column, put a couple more bolts on the window hinges, grease everything again, and give it a good once over then it's off to Jeeptoberfest!
...now parting out
jkl is offline
post #405 of 487 Old 10-15-2010, 06:41 PM Thread Starter
jkl
Now I'm shootin for the spring again (Jeep Beach) to have the paint, wiring harness, lights, blah blah blah done and maybe even have the 40s on it.
...now parting out
jkl is offline
My 03 TJ Build Thread teamoney Jeep Builds 43 12-23-2011 05:48 AM
00CherokeeXJ14 Project "Xtreme Urban" Build thread 98GooseXJ14 Jeep Builds 15 02-26-2010 10:27 PM
Project Tadpole build thread Arcticcat843 Jeep Builds 47 09-13-2008 10:03 AM
Project 31: A 2002 TJ Build vitaminwater Jeep Builds 10 07-13-2008 12:40 PM
