Build thread: “Project Taildragger” - Page 17 - JeepForum.com
post #241 of 487 Old 04-09-2010, 11:08 AM Thread Starter
jkl
Originally Posted by AustinTexasXJ View Post
what front axle is that?
Chevy DRW Dana 60
'13 10th Anniversary Unlimited Rubi
...now parting out
jkl is offline
post #242 of 487 Old 04-09-2010, 12:11 PM
AustinTexasXJ
1987 MJ Comanche
Originally Posted by jkl View Post
Chevy DRW Dana 60
what lug pattern? and is it manual locking hubs
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
AustinTexasXJ is offline
post #243 of 487 Old 04-09-2010, 12:26 PM Thread Starter
jkl
8x6.5 lug pattern and manual hubs
...now parting out
jkl is offline
post #244 of 487 Old 04-09-2010, 04:34 PM
AustinTexasXJ
1987 MJ Comanche
nice. is it same lug pattern for the rear?
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
post #245 of 487 Old 04-09-2010, 04:40 PM Thread Starter
jkl
Yes, same pattern on the rear. Going to run spacers on the rear to help match the front width.
...now parting out
jkl is offline
post #246 of 487 Old 04-09-2010, 09:11 PM
AustinTexasXJ
1987 MJ Comanche
whys the front wider?
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
post #247 of 487 Old 04-10-2010, 09:46 PM Thread Starter
jkl
The front hubs are about 4" wider so you can run dually wheels on the front or rear axles. The rear axle is a SRW axle, so it will need spacers to help match the front width. Going to run stock H1 wheels for the double beadlocks, they have 7" backspacing and the DRW axle helps clear everything.
...now parting out
jkl is offline
post #248 of 487 Old 04-16-2010, 03:15 PM Thread Starter
jkl
Made a list the other day of things I need to finish. I know I probably forgot a few things and some things will come later.
Steering:
Steering shaft
Pitman arm redrilled for GM tie rod
Drag link
High steer arms
P/S hoses
P/S HD bracket
Brakes:
Booster/MC
Brake lines/hoses
Body:
Paint
Bedline interior
Black hinges
Roll cage
Suspension:
Traction bar
Swap F & R springs
Add a leaf
Rear u-bolts
Shocks
Hummer H1 wheels
Tires (going to run 39.5 TSLs)
Re-gear and Front locker
Engine:
Battery
Air cleaner
Hoses/belts
Exhaust
Throttle cable
Kickdown cable
Gas tank
Trans lines to cooler
Radiator
Shifters
203/205 doubler w/sye
Electrical:
Wiring harness
Lights
Gauges
Misc:
Winch
Correct bolts in everything
Soft top
Re-tube driveshafts
Finish welding a few things up
Winshield wiper motor and linkage
...now parting out
jkl is offline
post #249 of 487 Old 04-16-2010, 03:44 PM
johnny9
it also helps to have the list when you think you forgot something
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
post #250 of 487 Old 04-16-2010, 04:31 PM
Polecat
Polecat's Avatar
So your list includes pretty much everything.
Polecat is offline
post #251 of 487 Old 04-16-2010, 08:22 PM
johnny9
i did notice he put"Finish welding a few things up" that must cover the rear tire carrier and anything else he missed
build-
johnny9 is offline
post #252 of 487 Old 04-17-2010, 03:12 PM Thread Starter
jkl
Originally Posted by johnny9 View Post
...that must cover the rear tire carrier...
No, that falls under the "some things will come later" category
...now parting out
jkl is offline
post #253 of 487 Old 04-17-2010, 03:17 PM Thread Starter
jkl
Last night a starter and rear slip yoke showed up to the station. I'm on the second half of a 48 hr. shift so maybe tomorrow afternoon I'll get the starter in and fire the motor off for a minute
...now parting out
jkl is offline
post #254 of 487 Old 04-18-2010, 07:34 PM Thread Starter
jkl
Put the starter in a tried to turn it over but it turns slow. I think the starter may be bad. Going to take it with me to work and have it tested tomorrow.
...now parting out
jkl is offline
post #255 of 487 Old 04-19-2010, 04:38 PM Thread Starter
jkl
I may have bigger problems, starter tested good. Started a thread in CJ tech http://www.jeepforum.com/forum/f8/sb...lowly-1015934/
...now parting out
jkl is offline
My 03 TJ Build Thread teamoney Jeep Builds 43 12-23-2011 05:48 AM
00CherokeeXJ14 Project "Xtreme Urban" Build thread 98GooseXJ14 Jeep Builds 15 02-26-2010 10:27 PM
Project Tadpole build thread Arcticcat843 Jeep Builds 47 09-13-2008 10:03 AM
Project 31: A 2002 TJ Build vitaminwater Jeep Builds 10 07-13-2008 12:40 PM
