Bruiser - Page 55 - JeepForum.com
post #811 of 1526 Old 10-25-2012, 04:52 PM
kbarwall
I just ordered the front truss, I welded on the C-Gussets last weekend, fit like a glove. When do you think you'll get around to the install?
kbarwall is offline
post #812 of 1526 Old 10-25-2012, 07:17 PM Thread Starter
spyder6
Got that Toyota chit
spyder6's Avatar
2010
if my saturday works out like i hope it does - im going to look at possibly getting the trusses and sleeves going this weekend. was hoping i might get to do the tire carrier instead though
My builds:
and
or follow us on
spyder6 is offline
post #813 of 1526 Old 10-26-2012, 07:27 AM
MountainMan864
Better get those trusses and sleeves done before wheelin harlan.
MountainMan864 is offline
post #814 of 1526 Old 10-26-2012, 03:49 PM Thread Starter
spyder6
spyder6's Avatar
2010
Amber covers for the d2
Sent by Paper Planes
My builds:
and
or follow us on
spyder6 is offline
post #815 of 1526 Old 10-26-2012, 09:39 PM
MO2500
Exactly what I've been wanting to see. I wondered how the color was with the covers vs the amber bulb version. Looks good
Instagram: @omsmike
MO2500 is offline
post #816 of 1526 Old 10-27-2012, 05:33 AM Thread Starter
spyder6
spyder6's Avatar
2010
The lens covers are very very dark amber. Roughly turn signals with a couple passes of night shades over them. In turn because they're a cover, they don't produce as much light as they would without, and the yellow they produce is lighter than what the actual yellow LEDs make. But I'm ok with that.
The slightly whiter yellow has a little more contrast for all the blacktop roads we have around here vs concrete towards downtown, plus the reduced output and color spectrum change means I can get away with using them on the street more than I did before. Plus they pop of in like 5 seconds if I want to go from 2800k to 5100k
My builds:
and
or follow us on
spyder6 is offline
post #817 of 1526 Old 11-02-2012, 04:11 PM
MountainMan864
Can we expect updates by tuesday? Tire carrier,sleeves,gussets, sliders done?
post #818 of 1526 Old 11-10-2012, 02:47 PM
MountainMan864
Ok so another week has passed. On to the next interesting build.
post #819 of 1526 Old 11-10-2012, 03:16 PM
2006_Sport
I can smell the brown on your nose from here Mountainman
It's not like Will doesn't have a wife, kid and a job or anything
2006_Sport is offline
post #820 of 1526 Old 11-10-2012, 04:10 PM
MountainMan864
Lil whatever ur name is I'm just messing around. I have a wife and 2yr old son and a 50 hour a week job to and I own my 1700sq ft home too. This is my fav jeep on this site that is driveable. Cant wait for updates.
post #821 of 1526 Old 11-12-2012, 09:01 PM Thread Starter
spyder6
spyder6's Avatar
2010
I have a minor update, just Havnt had a chance to write it. Too busy. I'm going to get it up tomorrow night
I had to order a W size drill bit from dewalt before I can put my sliders on. No one sells .386" OD bits anywhere.
Also need a angle drill to instal my tire carrier. Need to find one.
My builds:
and
or follow us on
spyder6 is offline
post #822 of 1526 Old 11-13-2012, 11:50 AM
Kodiak17
Ay or nay?
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #823 of 1526 Old 11-13-2012, 11:54 AM
Zjones1994
Ayy. Or a military kcco...
1998 Chili Pepper Red Jeep
USN Hull #233
Check out my build!
Zjones1994 is offline
post #824 of 1526 Old 11-13-2012, 12:35 PM Thread Starter
spyder6
spyder6's Avatar
2010
I've been sporting mine my last few times in uniform
My builds:
and
or follow us on
spyder6 is offline
post #825 of 1526 Old 11-13-2012, 06:24 PM Thread Starter
spyder6
spyder6's Avatar
2010
alright - lets get this party started
re-cap: rockers
titan tub armor - sanded
rocker skins - sanded
i dont have any "in process" pictures, but i can tell you i used Rustoleum Professional Aluminum self-etch primer (yes its specifically made for aluminum) on the tub armor. then i hit it with rustoleum black semi-gloss. the rocker skins simply got sanded, cleaned and then hit with 4 full cans of Rustoleum truck bed liner, which came out REALLY nice
i then decided that since i dont have a 90* drill yet, or a W (.386") drill bit yet, id work on something else id been meaning to do. i would have done either the sleeves or start working on the truss, but it was raining and i didnt want to push my dads tool chest with all my stuff in it up to the barn in the rain. (yeah i know, i need my own chest)
so removed my re-pin job of my factory foglight harness so i could connect my Rigid's to my sPOD. first up was cutting apart the harness the rigid's came with. crimped, soldered and heat shrinker
hooked up to the sPOD
then i cut the whole connector from my auto sway bar disco off, because its useless and was just hanging on the front crossmember filling with water.
i needed a way to seal it, without using ghetto electrical tape. so what i did was i took a piece of heat shrink tubing appropriately sized for the bundle of wires and heated up my needle nose pliers in my torch and sealed the end
wire condom
sealed away, for all of time
then i decided to do the same thing to the OEM foglight pins, so the factory harness could be retained for some devilish reasons i have.
tits
double tits
removed my plate
white and yellow
more updates this weekend
My builds:
and
or follow us on
spyder6 is offline
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/bruiser-1280161/
Posted By For Type Date
Project Overlander-Build Thread - Page 7 - Expedition Portal This thread Refback 10-25-2012 03:28 AM
Suggestions needed for UP MI overlander - Expedition Portal This thread Refback 10-02-2012 05:42 AM
2012 trade in value? Help. - Page 2 - Expedition Portal This thread Refback 10-01-2012 08:41 PM
Bigwapiti's 2011 Tundra build...'BIG NAMBE' - Page 2 - Expedition Portal This thread Refback 09-07-2012 10:01 AM
JK Safari snorkel - Page 2 - Expedition Portal This thread Refback 08-19-2012 01:24 PM
EcoBoost F150 for Peterson's Ultimate Adventure - Expedition Portal This thread Refback 06-19-2012 04:34 AM
$6.00 Hood blackout. - Expedition Portal This thread Refback 05-28-2012 12:53 PM
FJC Long Travel Build: 3Link Rear w/ Coilovers, Camburg, and more - Page 4 - Expedition Portal This thread Refback 05-10-2012 03:46 PM
Headlight Replacement - Page 4 - Expedition Portal This thread Refback 05-08-2012 10:35 PM
m35a2 build....and m105 camper build - Page 8 - Expedition Portal This thread Refback 05-03-2012 09:22 PM
Oshkosh HMMWV suspension upgrade - Expedition Portal This thread Refback 05-03-2012 02:20 AM
Dirt Bound Offroad TearDrop Trailer - Popup / out Roof & Back - Page 4 - Expedition Portal This thread Refback 04-23-2012 06:58 PM
Hutchinson Wheels - Page 2 - Expedition Portal This thread Refback 03-26-2012 06:51 PM
F150 trucks - Page 2 This thread Refback 03-17-2012 04:37 AM
"Blue Crush" JK build - RCCrawler.com Bulletin Board This thread Pingback 03-09-2012 12:11 PM
Tires This thread Refback 02-25-2012 06:03 PM
Chinese Air Locker This thread Refback 02-19-2012 02:58 PM
Red October Build - Page 3 This thread Refback 02-11-2012 10:15 PM
EcoBoost F150 for Peterson's Ultimate Adventure This thread Refback 01-31-2012 11:01 PM
FJC Long Travel Build: 3Link Rear w/ Coilovers, Camburg, and more - Page 5 This thread Refback 01-23-2012 01:01 AM
Red October Build - Page 10 This thread Refback 01-07-2012 08:14 PM
Hutchinson Wheels This thread Refback 01-04-2012 04:00 PM
JK Safari snorkel - Page 2 This thread Refback 12-25-2011 09:34 PM
JK Safari snorkel This thread Refback 12-25-2011 06:46 PM
Ford Ranger startup.... - Page 5 This thread Refback 12-25-2011 12:26 PM
General jeep ramblings thread This thread Refback 12-25-2011 11:44 AM
My All White 2012 JKUR This thread Refback 12-25-2011 08:27 AM
JK Safari snorkel This thread Refback 12-23-2011 08:50 PM
2nd Generation Tundra Building - Page 16 This thread Refback 12-23-2011 10:22 AM
2nd Generation Tundra Building - Page 16 This thread Refback 12-22-2011 10:03 PM
Red October Build - Page 10 This thread Refback 12-15-2011 06:21 PM
'12 JKU Suspension Question This thread Refback 12-11-2011 07:27 PM
Project Brooke: 1999 XJ - Page 4 This thread Refback 12-05-2011 05:53 PM
What's wrong with this picture This thread Refback 12-02-2011 08:24 PM
Bigwapiti's 2011 Tundra build...'BIG NAMBE' - Page 2 This thread Refback 12-02-2011 03:55 PM
Split the Jeep thread in two: one for Rock Crawlers and another for Expeditioning This thread Refback 11-30-2011 07:24 PM
