Bruiser - Page 52 - JeepForum.com
post #766 of 1526 Old 10-15-2012, 11:26 AM
MountainMan864
Whats the weight difference between the 38'' kevlars and the 37'' pbrs? Im assuming its got to be pretty close. Cant wait for more updates. The color and quality products really sells it to me.
MountainMan864 is offline
post #767 of 1526 Old 10-15-2012, 11:33 AM Thread Starter
spyder6
Got that Toyota chit
spyder6's Avatar
2010
The 38" Kevlars weigh in at 78lbs each. The 37" pbrs are 99lbs
So much win
Sent by Paper Planes
My builds:
and
or follow us on
spyder6 is offline
post #768 of 1526 Old 10-15-2012, 11:36 AM
Imped
Imped's Avatar
Holy ****.
OlllllllO
IndyORV
Imped is online now
post #769 of 1526 Old 10-15-2012, 12:23 PM
REDLYNER
REDLYNER's Avatar
You may want to double check those weights. Good Year has the 38" at 85lbs (still very light) and Pitbull has the 37" radial at 90lbs. I spent a good amount of time with those guys on the phone about those tires.
Have you seen the 38" MTR/K in person? It is every bit of 15" wide. Cool tire, but it is super wide.
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline
post #770 of 1526 Old 10-15-2012, 12:29 PM Thread Starter
spyder6
spyder6's Avatar
2010
I was going off memory. You have the facts though.
And yeah, I've seen them. I will Havnt decided if this is the way I want to go. I can't settle on the idea of new wheels when I'm going to get trail readys down the road anyway.
My builds:
and
or follow us on
spyder6 is offline
post #771 of 1526 Old 10-15-2012, 12:57 PM
REDLYNER
REDLYNER's Avatar
Don't get me wrong, they would look sick on your jeep, just know that it is a lot of tire (which I'm sure you do).
REDLYNER is offline
post #772 of 1526 Old 10-15-2012, 12:58 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
They're a super fantastic way to royally piss off your power steering pump
Mol is offline
post #773 of 1526 Old 10-15-2012, 05:56 PM
INCA
Jeep is looking so good! ill do a better job following it.
INCA is offline
post #774 of 1526 Old 10-15-2012, 08:04 PM Thread Starter
spyder6
spyder6's Avatar
2010
in stock form my jeep weighed in at 4017lbs. my TJ stock weighed 3832lbs. my goal is to get this jeep rolling and 'done' on 37's with a max weight of 4700lbs with an ideal goal of 4500lbs.
if i had to guess, as it sits right now im probably sitting at 4050lbs tops. the removal of the factory rock rails and the addition of the nemesis rockers should add 30lbs or so. tire carrier would be another 60lbs, winch will be another 70. savvy bumper should see me drop a couple pounds. trusses, gussets and sleeves will add another 120lbs. and i expect the 37's to add a total of 75-85lbs.
that would put me right at theoretical 4410 unladen. i have a couple lbs to playwith there.
My builds:
and
or follow us on
spyder6 is offline
post #775 of 1526 Old 10-15-2012, 08:29 PM
kbarwall
Hey Spyder, I am about to upgrade my suspension as well and wondering if you have done any research on Outboarding the rear shocks on the JK. I think this was one of the best suspension upgrades I made on my LJ and havent seen it done on JK's besides on those with wider axles and/or coil overs. Do you have insight on why this isnt really done in the JK world and curious if youll be going this route. I assume since the body is much wider vs. the frame on the JK you need either a wider axle, low back spacing wheel or both. I dont want to go this extreme yet as far as axles. Sorry if I missed it in this thread, lots of pages ot read through. I just thought I would think through this mod prior to installing my lift. I looking into getting the entire currie kit, minus spring, then going with 2.5" AEV spring and Bilstein 5170's.
Thanks,
Kevin
kbarwall is offline
post #776 of 1526 Old 10-16-2012, 08:55 AM Thread Starter
spyder6
spyder6's Avatar
2010
Thanks,
Kevin
Here is a post from some pages past:
so i think ive decided on a direction to move towards. i think im going to put my Fox's for sale, but not actively try to sell them. ive already offered them to several people and they'd like to have them but they cant do anything till after the first of the year. thats fine with me as im not going to mount them till after that. the main decision behind this is that i really cant mount the rear Fox's like i want to - there just simply isnt enough room in the wheel well to outboard them like i had originally wanted to. i cant french the frame because the frame rail is flush with the body on the JK's, and i really dont want to go through the work to cut a hole in the wheel well and then try my hand at sheet metal work. as much as that would be the best solution, it doesnt really work for me in this time frame. plus, the way the anti-rock mounts now, really messes with the space behind the axle.
so, if they do sell im just going to do the std currie suspension with Wayne's tuned Fox IFP shocks - pretty much the exact same setup that Gerald runs on his JK - except mine is better.
otherwise, if they dont sell - by the time i get to doing the suspension i'll find a way to make them work. i may fab up a crossbar to go inbetween the frame rails at the top of the hump and run the shocks inboard (as much as i dont want to)
discuss.
here are some pictures for you guys to think about:
So, I still don't know. Hoping someone will have an idea
My builds:
and
or follow us on
spyder6 is offline
post #777 of 1526 Old 10-16-2012, 11:31 AM
kbarwall
THanks! sorry I missed that. Ill explore some options as well.
Since you have had some time to drive on the anti rocks now, how do you like them for both from and rear with daily driving? I am most likely going the Currie route but with a AEV2.5" springs adn bilsteins and have yet to decide on wether to get the anti-rocks or not. In other words, if you were able to figure out a solution to outboard your rear shocks, would you do that over the anti-rock?
kbarwall is offline
post #778 of 1526 Old 10-16-2012, 11:56 AM
MO2500
Don't get me wrong, outboarding does provide some increased stability but it is not a replacement to a anti-rock sway bar. So to me its more a question of which one do you do first and how soon after can you afford the other.
Instagram: @omsmike
MO2500 is offline
post #779 of 1526 Old 10-16-2012, 12:02 PM
Imped
Imped's Avatar
This.
Looks like he'll have to move the bar in front of the axle to make room for shocks.
OlllllllO
IndyORV
Imped is online now
post #780 of 1526 Old 10-16-2012, 12:27 PM Thread Starter
spyder6
spyder6's Avatar
2010
With Connors help I may have found a place for the antirock infront of the axle. Details tonigjt
My builds:
and
or follow us on
spyder6 is offline
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/bruiser-1280161/
Posted By For Type Date
Project Overlander-Build Thread - Page 7 - Expedition Portal This thread Refback 10-25-2012 04:28 AM
Suggestions needed for UP MI overlander - Expedition Portal This thread Refback 10-02-2012 06:42 AM
2012 trade in value? Help. - Page 2 - Expedition Portal This thread Refback 10-01-2012 09:41 PM
Bigwapiti's 2011 Tundra build...'BIG NAMBE' - Page 2 - Expedition Portal This thread Refback 09-07-2012 11:01 AM
JK Safari snorkel - Page 2 - Expedition Portal This thread Refback 08-19-2012 02:24 PM
EcoBoost F150 for Peterson's Ultimate Adventure - Expedition Portal This thread Refback 06-19-2012 05:34 AM
$6.00 Hood blackout. - Expedition Portal This thread Refback 05-28-2012 01:53 PM
FJC Long Travel Build: 3Link Rear w/ Coilovers, Camburg, and more - Page 4 - Expedition Portal This thread Refback 05-10-2012 04:46 PM
Headlight Replacement - Page 4 - Expedition Portal This thread Refback 05-08-2012 11:35 PM
m35a2 build....and m105 camper build - Page 8 - Expedition Portal This thread Refback 05-03-2012 10:22 PM
Oshkosh HMMWV suspension upgrade - Expedition Portal This thread Refback 05-03-2012 03:20 AM
Dirt Bound Offroad TearDrop Trailer - Popup / out Roof & Back - Page 4 - Expedition Portal This thread Refback 04-23-2012 07:58 PM
Hutchinson Wheels - Page 2 - Expedition Portal This thread Refback 03-26-2012 07:51 PM
F150 trucks - Page 2 This thread Refback 03-17-2012 05:37 AM
"Blue Crush" JK build - RCCrawler.com Bulletin Board This thread Pingback 03-09-2012 01:11 PM
Tires This thread Refback 02-25-2012 07:03 PM
Chinese Air Locker This thread Refback 02-19-2012 03:58 PM
Red October Build - Page 3 This thread Refback 02-11-2012 11:15 PM
EcoBoost F150 for Peterson's Ultimate Adventure This thread Refback 02-01-2012 12:01 AM
FJC Long Travel Build: 3Link Rear w/ Coilovers, Camburg, and more - Page 5 This thread Refback 01-23-2012 02:01 AM
Red October Build - Page 10 This thread Refback 01-07-2012 09:14 PM
Hutchinson Wheels This thread Refback 01-04-2012 05:00 PM
JK Safari snorkel - Page 2 This thread Refback 12-25-2011 10:34 PM
JK Safari snorkel This thread Refback 12-25-2011 07:46 PM
Ford Ranger startup.... - Page 5 This thread Refback 12-25-2011 01:26 PM
General jeep ramblings thread This thread Refback 12-25-2011 12:44 PM
My All White 2012 JKUR This thread Refback 12-25-2011 09:27 AM
JK Safari snorkel This thread Refback 12-23-2011 09:50 PM
2nd Generation Tundra Building - Page 16 This thread Refback 12-23-2011 11:22 AM
2nd Generation Tundra Building - Page 16 This thread Refback 12-22-2011 11:03 PM
Red October Build - Page 10 This thread Refback 12-15-2011 07:21 PM
'12 JKU Suspension Question This thread Refback 12-11-2011 08:27 PM
Project Brooke: 1999 XJ - Page 4 This thread Refback 12-05-2011 06:53 PM
What's wrong with this picture This thread Refback 12-02-2011 09:24 PM
Bigwapiti's 2011 Tundra build...'BIG NAMBE' - Page 2 This thread Refback 12-02-2011 04:55 PM
Split the Jeep thread in two: one for Rock Crawlers and another for Expeditioning This thread Refback 11-30-2011 08:24 PM
