Bruised LJ - Page 23 - JeepForum.com
post #331 of 403 Old 11-10-2012, 11:19 PM Thread Starter
mJUSTINm
You serious? What's wrong with it? Can't be those ball joints.. Those things are beef!
-Justin
mJUSTINm is offline
post #332 of 403 Old 11-10-2012, 11:25 PM
TJdualsport
Yeaaaa.... I've been told some sets do this. Gotta go beat em up.
my dual sport build http://www.jeepforum.com/forum/f22/project-bumptastic-947070/
TJdualsport is offline
post #333 of 403 Old 11-10-2012, 11:38 PM Thread Starter
mJUSTINm
What the ****. That sucks man.
-Justin
mJUSTINm is offline
post #334 of 403 Old 11-11-2012, 12:22 AM
TJdualsport
Kinda like your steering only hundreds dollars more.... Lol
post #335 of 403 Old 11-11-2012, 11:09 AM
G Beasley
Originally Posted by mJUSTINm View Post
Thanks. It's hard to get a good bead on tubes!
Lots of practice , and positioning is what will make you better .
G Beasley is offline
post #336 of 403 Old 11-11-2012, 07:43 PM
TJdualsport
Aaaaaand. THAT'S WHAT SHE SAID!!,
post #337 of 403 Old 11-12-2012, 08:59 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
This is when mine first went on. I think it was at 5" or so with the HD springs.
I have no idea what is going on with the Currie rear 4" springs. When I did Marco's on his Unlimited with his hardtop installed, they came out just like your pic shows. I've done a few more on various rigs and some sit just right and some are low.
I think the spring company is screwing around somehow.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #338 of 403 Old 11-12-2012, 11:04 PM
TJdualsport
Whose the spring company?
post #339 of 403 Old 11-13-2012, 09:22 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I have no idea.
I am Savvy
mrblaine is offline
post #340 of 403 Old 12-04-2012, 04:37 PM
MrWhitaker0619
Your color combo isn't to bad either
Fuel - Interco - Besttop- Kicker - JVC -CORBEAU -Tuffy - KC - L.O.D - PSC - Rubicon Express - Viking - Warn - Gibson
/l ,[___],
l--L --OlllllO-
()_) ()_)-o-)_)
03 TJ X
MrWhitaker0619 is offline
post #341 of 403 Old 12-28-2012, 09:37 AM Thread Starter
mJUSTINm
Alright.. So I'm about to regear to 4.88s. I'm debating also putting in air lockers front/rear (Yukon zip lockers. Cheaper than ARB, great review, insane warranty). If I do that, would the stock front axle shafts hold up to the abuse? Or should I upgrade to 27 spline chromoly shafts?
-Justin
mJUSTINm is offline
post #342 of 403 Old 12-28-2012, 10:15 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I have no experience with an arb or yukon but I am running 35s on stock inner shafts and superior outer shafts with an aussie locker and 4.88s (manual 6 speed). This year I finally broke an outer shaft which is when I upgraded to the aftermarket outer shafts on a dd/medium throttle rock/hillclimbing/non-technical driver. I would say if you are on 33s, you would probably be fine but it is nice to have some piece of mine.
my 2 cents
Edit: I ran completely stock shafts (with all the same stuff as listed above) for almost two years before the break.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #343 of 403 Old 01-08-2013, 12:22 PM Thread Starter
mJUSTINm
Well, just scheduled an appointment to have the regear and lockers done. February 10th. The day after KOH. Sucks that I won't have 4x4 out there again this year, but it'll still be a good time!
Going with Yukon 4.88s, Yukon zip lockers front and rear, and upgrading to a larger compressor for the lockers and to inflate tires. Can't wait!
After that, I'm gonna order some valve stacks for my 7100s. I wanna play with the valving. They're at 278/75 right now. I want to try more compression and less rebound, maybe start with 255/80. I'll probably put in a flutter stack to have a more progressive compression. That's where you take the second smallest shim, and rearrange it right after the largest. It gives a softer initial compression on the largest shim, that firms up as you get into the rest of the stack. This is all new to me, so it'll be trial and error.
-Justin
mJUSTINm is offline
post #344 of 403 Old 01-08-2013, 12:49 PM
Ricochet88
Does he install them same day?
Rick "woody"
93 zj wagoneer pkg, 5in iro lift, 33/10.5/15 bfgoodrich km2
my build thread
R.I.P. TROY EDWARDS "bigbluezj94"
Ricochet88 is offline
post #345 of 403 Old 01-08-2013, 01:01 PM
mcannon111
Could you document the revolving pretty well? I want to do something similar to mine because I have the same shocks.
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
