Bruised LJ - Page 13 - JeepForum.com
post #181 of 403 Old 11-20-2011, 09:51 PM Thread Starter
mJUSTINm
I want to see that truss on the WJ you were talking about Kevin. It was a T&J truss right? I don't know how much I like those trusses that run under the axle.. Not a fan of losing clearance.
Rick - 4.88s with the 4.0 and 42rle is what a lot of people would recommend. This transmission sucks.
-Justin
mJUSTINm is offline
post #182 of 403 Old 11-21-2011, 08:38 AM
Ricochet88
Wow must be a wrangler thing you have all that extra weight from the frame too ill still beat you in a race tho :-D
Rick "woody"
93 zj wagoneer pkg, 5in iro lift, 33/10.5/15 bfgoodrich km2
my build thread
R.I.P. TROY EDWARDS "bigbluezj94"
Ricochet88 is offline
post #183 of 403 Old 11-21-2011, 10:32 AM
TJdualsport
bring it!! hahaha mojave road in march!!! yea T&J built it. i should have snapped a pic, ill see if the owner todd jackson will send a pic
my dual sport build http://www.jeepforum.com/forum/f22/project-bumptastic-947070/
TJdualsport is offline
post #184 of 403 Old 11-21-2011, 11:26 AM Thread Starter
mJUSTINm
Well Rick you got those fancy new shocks, now let's see if you can drive! Haha you better go on the Mojave trip!
I like the UCF truss. It's more low profile compared to most, and at a decent price. http://www.undercoverfab.com/truss-s...ss-system.html
-Justin
mJUSTINm is offline
post #185 of 403 Old 11-21-2011, 11:44 AM
Hendrix
TJOTY 2013
Hendrix's Avatar
I like the UCF skid. It's more low profile compared to most, and at a decent price. http://www.undercoverfab.com/truss-s...ss-system.html
I like that truss. Very nice and low profile.
Sent from planet X.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #186 of 403 Old 11-21-2011, 11:51 AM
Ricochet88
I like that truss its low profile should clear the oil pan
What about ironrock offroads inner sleeve kit? You think that would be enough?
Rick "woody"
my build thread
post #187 of 403 Old 11-21-2011, 04:16 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
I like the trus but it doesn't appear like it would work very easily with the Currie axle housing kit without some modifications to either the truss, or the JJ kit... It would be nice if UCF made the same truss but already set up for the Currie kit.
Necromancer_tat is offline
post #188 of 403 Old 11-21-2011, 04:25 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
You could easily cut a notch in the passenger side of the truss to slide over the already welded and gussetted currie jj kit. Then burn in the truss to that.
Sent from planet X.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #189 of 403 Old 11-21-2011, 04:30 PM
TJdualsport
ive been impressed with the abuse a inner sleeve kit can take. gusset kit, inner sleeve, gusset on the steering knuckles, mini skids for the lower arms. sounds like a good combo to me. the hardest part of a traditional truss is welding to the center section. clearence to the oil pin isnt much of an issue.the bigger problem with the UCF kit is that it does nothing for the short side of the axle. thats why a good truss is done on the bottom of the housing going form C to C.
post #190 of 403 Old 11-21-2011, 06:14 PM
Necromancer_tat
Sent from planet X.
I know that, but I could just as easy have a truss made locally for the price that incorporates the JJ as part of the structure of the truss. I would've already purchased the UCF truss except when I asked them about the JJ kit I never recieved a satisfactory reply. http://www.jeepforum.com/forum/f43/n...ystem-1288314/
post #191 of 403 Old 11-22-2011, 01:33 AM Thread Starter
mJUSTINm
In that thread he makes it sound like a JJ could just be pressed into the mount. I sent him a PM to get more info.
-Justin
mJUSTINm is offline
post #192 of 403 Old 11-22-2011, 11:37 AM Thread Starter
mJUSTINm
From Matt
Originally Posted by undercoverfab
You would use a Currie driver side upper Johnny joint on the passenger side. It has the same internal diameter as the factory control arm mount.
-Justin
mJUSTINm is offline
post #193 of 403 Old 11-22-2011, 01:22 PM
Marconis
Sick Jeep, man. I like what you've done with it.
Marconis is offline
post #194 of 403 Old 11-22-2011, 01:52 PM
Necromancer_tat
Originally Posted by mJUSTINm View Post
From Matt
Thanks!
post #195 of 403 Old 11-22-2011, 02:10 PM Thread Starter
mJUSTINm
Yup. I wanted to know too. I like that option..
-Justin
mJUSTINm is offline
