Brplatz's TJ "OPV" - Page 12 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Brplatz's TJ "OPV"
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 09-17-2013, 09:01 PM   #166
dustinGERSTEL
Good job Bryan, good job.
Black Betty
-1999 Jeep TJ
-Sahara 4.0L I6 With Airaid C/A Intake and Airaid TBS / Banks Monster Exhaust
-4" RC X-Series Lift / 33" x 12.50 Goodyear Wrangler Kevlar MT/R's
dustinGERSTEL is offline   Reply With Quote Quick reply to this message
Unread 09-26-2013, 02:19 PM   #167
Walle
Soccer Mom and Jeep Hater
Walle's Avatar
This build sucks...
| Walle's Build | 2014 JKOTY | Instagram |
Walle is offline   Reply With Quote Quick reply to this message
Unread 09-26-2013, 02:34 PM   #168
NYGLT56
Your Local Body Builder
Originally Posted by Walle
This build sucks...
I agree
Instagramin --> @thatonebeardedbro
2014 TJOTY Winner
NYGLT56 is offline   Reply With Quote Quick reply to this message
Unread 09-26-2013, 06:45 PM   #169
2000GrayTJ
Question about your rear 4 link, any reason you didn't mount the lower axle side even with the tubes? From what I understand not only do you gain the clearance but also improves geometry a bit since you're effectively raising the uppers when you mount them on the truss. Great job it's inspired me to do mine next summer
good from far, far from good.
'99 TJ frame-off rebuild: http://jeepforum.com/forum/f22/99-tj-frame-off-rolled-bold-1199954/
2000GrayTJ is offline   Reply With Quote Quick reply to this message
Unread 10-02-2013, 09:37 AM   #170
brplatz
It has to do with how the rear axle ends up "pushing" the vehicle. The way MrBlaine explained it was that if from the side, you drew lines through your upper and lower links forward, they should intersect as close to the center of gravity as possible so that you don't squat when accelerating, or very little. The benefit of geometry outweighs a few inches of clearance right next to your tires.
The Second Amendment is in place in case they ignore the others.
[QUOTE=mrblaine;14089403]That's like saying you wish your boyfriend was a bit less gay.[/QUOTE]
[COLOR="Blue"]MOΛΩN ΛΑΒΕ[/COLOR]
[URL="http://www.nmoffroad.com"][COLOR="DarkRed"]NMOffroad[/COLOR][/URL]
[URL="http://www.overland-motorsports.com/"][COLOR="Gray"]Overland Motorsports[/COLOR][/URL]
[COLOR="DarkSlateBlue"][URL="http://www.jeepforum.com/forum/f22/brplatzs-tj-opv-1240947/#post13888971"]My Build[/URL][/COLOR]
brplatz is offline   Reply With Quote Quick reply to this message
Unread 10-02-2013, 01:15 PM   #171
2000GrayTJ
So effectively you are setting your AS as close to 100% as possible (ie slightly higher than it would be if they were flush with tube)? I guess there is also some adjustability in the upper frame-side mount too which I thought was the best place do to that. Thanks for the info!
Unread 10-02-2013, 05:53 PM   #172
NYGLT56
Take a look at impeds build. His mounts are flush with the tube if you're wanting to go that route.
2014 TJOTY Winner
Unread 10-02-2013, 06:25 PM   #173
2000GrayTJ
I'm well aware of that which is why I was asking for the reasoning behind him mounting his lower. Obviously if its coming from Blaine there's some reason, time to start playing with the calc.
Unread 10-02-2013, 06:35 PM   #174
NYGLT56
Imped went back and forth I believe with Blaine.
End result. Flush mount, and as far as I know it's probably one of the best TJ in terms of suspension geometry out there right now.
2014 TJOTY Winner
Unread 10-02-2013, 08:13 PM   #175
_KONG_
It also has to do with having enough seperation at the axle. Moving the lowers up means you have to move the uppers up and can limit uptravel due to your tub
_KONG_ is offline   Reply With Quote Quick reply to this message
Unread 04-15-2014, 04:29 PM   #176
_KONG_
Any updates? How does it perform offroad?
Unread 04-15-2014, 04:40 PM   #177
Walle
Walle's Avatar
I am pretty sure he doesn't drive it anymore. Maybe he sold it or it got stolen while he was in the mall...
Unread 04-15-2014, 07:29 PM   #178
NYGLT56
We're going to make it into a low rider. Didn't you read that txt?
2014 TJOTY Winner
Unread 04-15-2014, 09:22 PM   #179
_KONG_
Welp. At least its not on jackstands
Unread 04-15-2014, 09:39 PM   #180
NYGLT56
Well actually...lol
2014 TJOTY Winner
