Brplatz's TJ "OPV" - Page 12 - JeepForum.com
post #166 of 182 Old 09-17-2013, 08:01 PM
dustinGERSTEL
Good job Bryan, good job.
Black Betty
-1999 Jeep TJ
-Sahara 4.0L I6 With Airaid C/A Intake and Airaid TBS / Banks Monster Exhaust
-4" RC X-Series Lift / 33" x 12.50 Goodyear Wrangler Kevlar MT/R's
dustinGERSTEL is offline
post #167 of 182 Old 09-26-2013, 01:19 PM
Walle
Soccer Mom and Jeep Hater
Walle's Avatar
This build sucks...
| 2014 JKOTY |
Walle is offline
post #168 of 182 Old 09-26-2013, 01:34 PM
NYGLT56
Your Local Body Builder
NYGLT56's Avatar
Originally Posted by Walle
This build sucks...
I agree
2014 TJOTY Winner
IG: overlanding_racingdriver_
A Daily Driven Lowrider Adventure TJ on 40s.
NYGLT56 is offline
post #169 of 182 Old 09-26-2013, 05:45 PM
2000GrayTJ
Question about your rear 4 link, any reason you didn't mount the lower axle side even with the tubes? From what I understand not only do you gain the clearance but also improves geometry a bit since you're effectively raising the uppers when you mount them on the truss. Great job it's inspired me to do mine next summer
good from far, far from good.
'99 TJ frame-off rebuild: http://jeepforum.com/forum/f22/99-tj-frame-off-rolled-bold-1199954/
2000GrayTJ is offline
post #170 of 182 Old 10-02-2013, 08:37 AM Thread Starter
brplatz
It has to do with how the rear axle ends up "pushing" the vehicle. The way MrBlaine explained it was that if from the side, you drew lines through your upper and lower links forward, they should intersect as close to the center of gravity as possible so that you don't squat when accelerating, or very little. The benefit of geometry outweighs a few inches of clearance right next to your tires.
The Second Amendment is in place in case they ignore the others.
That's like saying you wish your boyfriend was a bit less gay.
MOΛΩN ΛΑΒΕ
brplatz is offline
post #171 of 182 Old 10-02-2013, 12:15 PM
2000GrayTJ
So effectively you are setting your AS as close to 100% as possible (ie slightly higher than it would be if they were flush with tube)? I guess there is also some adjustability in the upper frame-side mount too which I thought was the best place do to that. Thanks for the info!
post #172 of 182 Old 10-02-2013, 04:53 PM
NYGLT56
NYGLT56's Avatar
Take a look at impeds build. His mounts are flush with the tube if you're wanting to go that route.
2014 TJOTY Winner
NYGLT56 is offline
post #173 of 182 Old 10-02-2013, 05:25 PM
2000GrayTJ
I'm well aware of that which is why I was asking for the reasoning behind him mounting his lower. Obviously if its coming from Blaine there's some reason, time to start playing with the calc.
post #174 of 182 Old 10-02-2013, 05:35 PM
NYGLT56
NYGLT56's Avatar
Imped went back and forth I believe with Blaine.
End result. Flush mount, and as far as I know it's probably one of the best TJ in terms of suspension geometry out there right now.
2014 TJOTY Winner
NYGLT56 is offline
post #175 of 182 Old 10-02-2013, 07:13 PM
_KONG_
It also has to do with having enough seperation at the axle. Moving the lowers up means you have to move the uppers up and can limit uptravel due to your tub
_KONG_ is offline
post #176 of 182 Old 04-15-2014, 03:29 PM
_KONG_
Any updates? How does it perform offroad?
_KONG_ is offline
post #177 of 182 Old 04-15-2014, 03:40 PM
Walle
Walle's Avatar
I am pretty sure he doesn't drive it anymore. Maybe he sold it or it got stolen while he was in the mall...
| 2014 JKOTY |
Walle is offline
post #178 of 182 Old 04-15-2014, 06:29 PM
NYGLT56
NYGLT56's Avatar
We're going to make it into a low rider. Didn't you read that txt?
2014 TJOTY Winner
NYGLT56 is offline
post #179 of 182 Old 04-15-2014, 08:22 PM
_KONG_
Welp. At least its not on jackstands
_KONG_ is offline
post #180 of 182 Old 04-15-2014, 08:39 PM
NYGLT56
NYGLT56's Avatar
Well actually...lol
2014 TJOTY Winner
NYGLT56 is offline
black rock "dune" or "Lobo" Temple Jeep Picture Requests 3 02-27-2012 06:20 AM
Photos 4" and 3" zone lift with 33" x 10.5" BFGkm 2003Sahara Jeep Picture Requests 0 02-08-2011 06:07 AM
Some call it "Dolores", some "Misery" mikes_muse Jeep Builds 5 10-18-2009 12:36 PM
2"-2.5" suspension lift+ 1"bl with 31" tires bmboll Jeep Picture Requests 5 03-29-2006 12:28 PM
My new "Sahara Edition" Liberty...package "S"... Liberty-4-All Jeep Builds 19 06-06-2002 10:41 AM
