Bedwell's Jeep Sahara Build - Page 17 - JeepForum.com
post #241 of 391 Old 09-20-2013, 07:15 AM
AngryTJ
Tie rod flip and the savvy ultimate tie rod
AngryTJ is offline
post #242 of 391 Old 09-20-2013, 07:35 AM
MO2500
This is the best way to go for the stock setup. My 1.5"x.250" DOM tie-rod is already bent as well, trying to figure out what to do for mine.
Instagram: @omsmike
MO2500 is offline
post #243 of 391 Old 09-20-2013, 10:41 AM Thread Starter
Bedwell
1984 CJ8
What frustrates me the most is that I have $450 already invested in the Currie kit. I had bent multiple tie rods before so when I upgraded I had hoped that this would be able to satisfy my driving on the trails. I'm not sure if I want to invest another few hundred in my current setup, I had spoken briefly to Mike about making the step up to one tons within the next year or so, so I am trying to limit my spending on mods that won't be long term.
Subscribe to my YouTube Channel:
https://www.youtube.com/user/RockCrawlinJeeps
Bedwell is offline
post #244 of 391 Old 09-20-2013, 10:44 AM
AngryTJ
then just straighten your current currie tie rod and do the tie rod flip. Itll only cost you $20ish
AngryTJ is offline
post #245 of 391 Old 09-20-2013, 10:54 AM Thread Starter
Bedwell
1984 CJ8
I could be mistaken but isn't the swaybar kit needed as well by Mr. Blaine?
Bedwell is offline
post #246 of 391 Old 09-20-2013, 11:42 AM
AngryTJ
True you will need to also remove the stock swaybar bracket and raise that as well...so maybe a bit more then $20 but still less then a $500 savvy tie rod
AngryTJ is offline
post #247 of 391 Old 09-20-2013, 12:47 PM
IEcrawlerTJ01
4340 heat treated chromoly
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #248 of 391 Old 09-21-2013, 10:45 PM Thread Starter
Bedwell
1984 CJ8
I will be making one of these over the winter for the Ford 8.8, should help with the diff puking fluid...
http://www.pirate4x4.com/forum/gener...nder-15-a.html
Bedwell is offline
post #249 of 391 Old 09-23-2013, 07:34 AM
Holaday
I have a kit that I ended up not using. Sell you it for cheap if you want it
Holaday is offline
post #250 of 391 Old 09-23-2013, 10:31 AM Thread Starter
Bedwell
1984 CJ8
I'll keep that in mind, need to finish a couple things before Big Dogs first though.
Bedwell is offline
post #251 of 391 Old 09-23-2013, 10:39 AM Thread Starter
Bedwell
1984 CJ8
I was searching through some old family photos and stumbled across a few from our trip we took out west.
First ever wheeling trip, Summer 2002.
Bedwell is offline
post #252 of 391 Old 09-25-2013, 10:33 PM Thread Starter
Bedwell
1984 CJ8
Great progress made on the Jeep today! I had to return a serpentine belt to Westminster Auto Parts, they gave me a Cherokee 4.0 belt instead of the Wrangler. Anyway, swapped the belt out as mine was dry-rotted and had a small tear. I also went to TSC and picked up some new chain mounts for my M416 trailer as well as a swing down leg/jack. I also decided to finish a project that I have had at about 90% done, and that is my transmission cooler. I did not mount the cooler in the recommended location, as it would have lasted about 15 minutes into a normal day of trail riding. Yesterday I picked up about 25 foot worth of transmission hose, so today we used the fittings that was supplied with the kit and ran my own lines. Everything went well, however I did have a small leak after my test drive. I was not able to get the fan to turn on, but I believe that was due to not a long enough test drive and the colder evening air. I retightened the fittings and will test drive again before Big Dogs.
Bedwell is offline
post #253 of 391 Old 10-14-2013, 06:03 PM Thread Starter
Bedwell
1984 CJ8
My third and final trip this year at Big Dogs is in the books. If I had set weekends off I would have skipped this trip due to the weather. Regardless I still attended and will share my weekend below.
I left Friday morning around 10:30am to avoid traffic and get camp set up before dark. The trip down went farely smooth, I took my time as it was raining and I am still getting used to towing a trailer. I got to the Cove around 2pm and checked in at Camp 3. I have never camped there, its up above the bath house near the upper lake. I got camp set up at spot #43 and the resident at the cabin arrived and told me I was in the wrong spot. I was one site off so it took pretty much the rest of my strength to drag all of my camping gear up the hill and set up again. At that point I was tired and soaked from the rain so I took a nap until the rest of the group arrived.
Brad and Spence arrived in the late afternoon after battling traffic for 4 hours. I helped them get set up at spot #45, pitched a tarp over our camp and built a nice fire. I then moved my camp again as it was a nicer spot. Cooked a few burgers, while Brad and Spence were chowing down on pulled pork hotdogs. Joe and his buddy Bear finally made it after a few phone calls and wrong turns, and Brad got there last after a trailer breakdown. I called it an early night and was anxious to finally hit some trails in the morning.
Saturday morning I met Will waiting at our camp as he drove up the morning of. We had a late start, ran part of Wahoo and headed over to Corum. Will had taken the Rubicon this trip so he could have a roof and heat (I can't blame him.) He went to turn on the lockers and the dash lit up with error codes. We crawled under the TJ and found that the fittings to the housing were broken off the axle. Will took the bypass and I followed Tyler about halfway up Corum until he ripped the rear shock mount and unseated the coil spring. After removing the shock and reseating the spring, I turned around and headed back to camp as I had gotten seperated from Brad and Joe (they were waiting at the top of the trail.) I helped Will load the Rubicon on the trailer and rode back with him to the house to pick up his CJ7. After loading up the new rig and checking out the world famous Big Bird CJ, we headed back to the Cove for hopefully a better trail ride on Sunday. (It never stopped raining the entire weekend.)
On Sunday we had a late start again but regardless we were out on the trails. Will took the lead on Sunday and brought us over to the KGB trail. Traction was difficult, I was getting frustrated as I couldn't make a simple rock hill. I lowered my air pressure a few psi and it helped significantly. We got back on Pinnacle I believe and headed over to my favorite trail at Big Dogs, V Trail.
I apoligize for picture quality, I was filming with the GoPro at the same time.
Here is a video of me completing the bonus obstacle on V Trail:
The last two photos are me broken down not long after I did the bonus obstacle. I somehow was able to get the log stuck by the rear axle and it took out my ARB line (thankfully it did not hit my transcooler or punchure my gas tank.) After removing the log I called it a day and we headed back to camp, packed up and had a quick meal at Sonic before making the long trip home. Even though this was a rough wheeling weekend, I still plan on attending a couple Big Dogs events next year, hopefully with a truck and trailer though. (And alot less rain.)
Bedwell is offline
post #254 of 391 Old 10-17-2013, 10:14 AM Thread Starter
Bedwell
1984 CJ8
Finished another video from this past weekend, enjoy!
Bedwell is offline
post #255 of 391 Old 10-17-2013, 01:56 PM
MO2500
Yep, still glad I didn't make the trip. I would have been pretty miserable all weekend with the rain. I'll make it down there at some point though when it's dry.
Instagram: @omsmike
MO2500 is offline
4.0l sahara's green sahara build 4.0l sahara Jeep Builds 47 12-27-2012 10:45 AM
Jeep sahara build to zombie control blindside9704 Jeep Builds 0 11-10-2011 10:18 AM
2003 jeep sahara build nskipper7 Jeep Builds 2 11-03-2011 04:17 PM
My 01' Sahara build Bogar03 Jeep Builds 11 07-20-2011 11:16 PM
95 Sahara build!!!! teamhirev Jeep Builds 4 05-05-2011 12:20 PM
