Ill start by introducing myself as another newb. My name is Ashland, 20 years old, and currently live in the soon to be cold state of Michigan. I recently came in to some money so I decided to by another jeep. Before I just had a 95' jeep grand cherokee. I bought a 93' jeep YJ, 4 banger with 31x10.5x15 tires(I think the tires won me over), that needs quite a bit of work.
I bought the YJ for 2000$ (way to much). The guy I bought it from said it just needed a clutch, which I now know was not the case at all. Not only did it need a ton more but the clutch was fine. So far I have replaced the clutch (it was a little worn out), slave cylander, some kind of pressure piston that cost 200$, a motor mount, some thing that connects the motor mount to the frame, a new trasmission support/skid plate(also cost alot) and a new valve cover.
Right now ive put about 1000$ into it and havent even been able to drive it but if I have any luck ill be able to drive it home tomarrow, were the more cosmetic work will begin. I will have pictures of it up asap.
