BBB Black and Blue YJ Build - Page 68 - JeepForum.com
 107Likes
post #1006 of 3663 Old 07-08-2013, 12:20 AM Thread Starter
ashland82391
Originally Posted by DpDave View Post
I've had that issue before... once it was the locker self destructing, the second time it was the carrier that exploded. Not much fun, but it gave me an excuse to go from 3.08 gears to 4.56's.
Good luck with the repair bill...
Awh crap, i hope that's not the case....
ashland82391 is offline
post #1007 of 3663 Old 07-08-2013, 12:43 AM
DpDave
Well, maybe you'll be "lucky" and only have a smoked pinion bearing or something.
Fingers crossed...
If yer gonna fight, fight like the third monkey on the ramp to Noah's Ark.
My Build Thread:
DpDave is offline
post #1008 of 3663 Old 07-08-2013, 09:52 AM
20jeepster10
Sorry to hear that that's what's wrong with my yj front end is wasted if you need parts let me know I've got 2 numbers one is parts the other is a complete axle reasonable
Good luck fixing hope it's the easier of the choices
Frozen Mitten...
20jeepster10 is offline
post #1009 of 3663 Old 07-08-2013, 12:36 PM Thread Starter
ashland82391
Thanks man, I'll definitely shoot you a pm if it's trashed.
post #1010 of 3663 Old 07-08-2013, 12:37 PM
zte87
GIVE IT THE ONION
zte87's Avatar
What where you doing with it messed up?
zte87 is offline
post #1011 of 3663 Old 07-08-2013, 12:46 PM Thread Starter
ashland82391
I think it's been a progressive thing. I think it started when my front ds came loose on the highway. I was wheeling for about 3 hours just fine. Then i can out to the parking lot in 2wd, turned sharp on the pavement and that's when i herd the strange popping. Every time it pops the steering shots straight for a second.
post #1012 of 3663 Old 07-08-2013, 01:51 PM Thread Starter
ashland82391
Good news! Everything looks good. No metal shavings, no cracks, chips, nothing. The fluid was pretty dirty and grainy and the pinion was really loose. Soooo, hopefully that is why it was acting up.
Hers a video
https://www.youtube.com/watch?v=gkjw...e_gdata_player
post #1013 of 3663 Old 07-08-2013, 01:58 PM
DpDave
That's good news! Will the pinion nut tighten back down or do you need a new crush sleeve? Either way, lots less work and $$$
My Build Thread:
DpDave is offline
post #1014 of 3663 Old 07-08-2013, 02:02 PM Thread Starter
ashland82391
Hmm, I'll try it out. I don't know anything about the crash sleeve though.
post #1015 of 3663 Old 07-08-2013, 02:41 PM
DpDave
usually there is a sleeve over the pinion shaft that crushes between the upper and lower bearings to help keep the pinion from moving in and out. I know with the GM 10 and 12 bolts once you crush that sleeve, a lot of times you had to change it out before you could get the proper torque back on the nut. If that's the case, it's not that big a deal, just a lot of work to pull the carrier, then the pinion.
For sure try and crank the nut down and tighten it up. If you can get rid of the slop that way you should be golden!
My Build Thread:
DpDave is offline
post #1016 of 3663 Old 07-12-2013, 11:21 PM
zte87
GIVE IT THE ONION
zte87's Avatar
Did you get her sorted out?
zte87 is offline
post #1017 of 3663 Old 07-12-2013, 11:28 PM Thread Starter
ashland82391
Not yet, I'm just waiting for pay day to get the kit. Im also going to be looking for a new front drive shaft. I went to get my current one balanced the other day and they told me there was too much play in the slip and i needed a new one.
Curt told me he thinks a xj shaft would work, do you know anything about this?
post #1018 of 3663 Old 07-13-2013, 12:18 AM
zte87
GIVE IT THE ONION
zte87's Avatar
I may be wrong but I think the stock front Xj shaft is a dc setup which would require are different kind of yoke on the tc, but like I said I could be wrong.......I had my slip you on my shaft replace a yr ago and I am all ready for a new one again. I have happy with my rear tw shaft so I am thinking of getting made up for the front but that has to wait till BONUS/TAX time :/
zte87 is offline
post #1019 of 3663 Old 07-13-2013, 12:32 AM Thread Starter
ashland82391
I'll have to spend some time at the jy with a tape measure and see what will work.
post #1020 of 3663 Old 07-13-2013, 12:48 AM
Rubicon0311
Now that I think about it, front xj drive shafts are cv shafts. Did the yj's not come with cv shafts in the front?
Rubicon0311 is offline
Blue on Black build BloodThirsty Jeep Builds 166 01-01-2016 09:40 PM
Project "Blue & Black YJ". My '91 YJ Build. Matt Graham Jeep Builds 305 03-12-2014 12:43 PM
dark blue/blue jeep TJ with Black Hardtop JSBlu974X4 Jeep Picture Requests 2 03-02-2013 09:03 PM
fj blue rubicon with black rims black tube fenders bremz8 Jeep Picture Requests 5 06-22-2009 11:30 PM
blue tj with black or tan soft top matt0102 Jeep Picture Requests 0 11-29-2008 12:01 PM
