BBB Black and Blue YJ Build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > BBB Black and Blue YJ Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 09-23-2011, 04:46 PM   #1
ashland82391
Ill start by introducing myself as another newb. My name is Ashland Holstine, 20 years old, and currently live in the soon to be cold state of Michigan. I recently came in to some money so I decided to by another jeep. Before I just had a 95' jeep grand cherokee. I bought a 93' jeep YJ, 4 banger with 31x10.5x15 tires(I think the tires won me over), that needs quite a bit of work.
I bought the YJ for 2000$ (way to much). The guy I bought it from said it just needed a clutch, which I now know was not the case at all. Not only did it need a ton more but the clutch was fine. So far I have replaced the clutch (it was a little worn out), slave cylander, some kind of pressure piston that cost 200$, a motor mount, some thing that connects the motor mount to the frame, a new trasmission support/skid plate(also cost alot) and a new valve cover.
Right now ive put about 1000$ into it and havent even been able to drive it but if I have any luck ill be able to drive it home tomarrow, were the more cosmetic work will begin. I will have pictures of it up asap.
Soft Door Flap Solution
[url]http://www.jeepforum.com/forum/f27/soft-upper-door-flap-solution-1438559/[/url]
Build Thread
[URL="http://www.jeepforum.com/forum/f22/bbb-black-blue-yj-build-1268543/index12.html"]http://www.jeepforum.com/forum/f22/bbb-black-blue-yj-build-1268543/index12.html[/URL]
ashland82391 is offline   Reply With Quote
Unread 09-23-2011, 04:49 PM   #2
ashland82391
my jeep ZJ. All stock, 257,000 miles, from arizona, not a spot of rust on it.
Unread 09-25-2011, 05:12 AM   #3
ashland82391
So, everything worked out pretty good yesterday. Got a call at 11am saying that the jeep was done. I took my newish baby home (drives like a dream and shifts great) and started a little work. Fixed wind sheild wipers, the internal wiper arm disconected from the motor. Found out when I got it home that the hard top was only held on by two loose bolts so I got that all fasened down. Then remounted the seat belts because there original mounting spot were rusted out. I must say ive grown attached to the money eater already.
Unread 09-29-2011, 09:11 AM   #4
ashland82391
Finnaly back home from a crazy couple days of working on the heep. Here are some pictures of the most agrivating vehical in the world.
Unread 09-29-2011, 09:22 AM   #5
Kraxen
its beautiful! im a little biased cause my first wrangler was pretty much that exact color and it reminds me of it goodluck with it
92 YJ
95 YJ
Kraxen is offline   Reply With Quote
Unread 09-29-2011, 09:23 AM   #6
ashland82391
For the past few days Ive been working on the heep. Mounted the hard top, relocated the seat belt mounts, fixed windshield wippers, chager fuel filter, made relocation mounts for mirrors, changed all four shocks(had to cut the 18year old ones out with a tourch, replaced the front driver side brake hose and line, replaced both front brake pads, calipers, and rotors. It was a long couple of days but I eventually got everything done. I probabley could have got it all done in a day if everything wasnt so fricken rusted!!
Unread 09-29-2011, 09:26 AM   #7
ashland82391
ha thanks! Now that im done being mad at it im beginning to love it.
Unread 09-29-2011, 09:31 AM   #8
Kraxen
haha i know what you mean. as much as i love my jeep it seems like if its not one thing its another with it.
92 YJ
95 YJ
Unread 09-29-2011, 09:44 AM   #9
ashland82391
cutting out the shocks was a bear. they were crubling apart every time i grabed them.
Unread 09-29-2011, 09:45 AM   #10
ashland82391
new shocks
Unread 09-29-2011, 10:03 AM   #11
ashland82391
The body rust. Im ordering the steal today. Should be able to start body work some time within the next two weeks.
Unread 09-29-2011, 10:10 AM   #12
ashland82391
temperary fix for the windshield frame. When everit would rain water would pore out on my feet.
Unread 09-29-2011, 10:15 AM   #13
ashland82391
relocated seat belt
Unread 09-29-2011, 10:31 AM   #14
20jeepster10
Thats a nice start, gotta love the michigan rust.
20jeepster10 is offline   Reply With Quote
Unread 09-29-2011, 03:15 PM   #15
Kraxen
shes in rougher shape than i thought, The first pic you uploaded looked like it was damn near cherry condition, Nice start non the less. Nice ZJ also!
92 YJ
95 YJ
