BamaJeepman21's build thread - Page 5 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > BamaJeepman21's build thread
Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri2007-2016 Jeep JKU 4" X-series suspension lift **dea
Unread 02-10-2013, 10:29 PM   #61
BamaJeepman21
Originally Posted by 256ChiliPepper View Post
Looks good man! Glad I could help. Let me know if you ever need help with it. No idea why your drive shaft is at that steep of an angle, mine wasn't that bad when I first did my lift.
Probably because the 3" springs gave closer to 3.5"-4" since I have no extra weight besides the hardtop.
-Jack
BamaJeepman21 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 01:58 AM   #62
redneckrubicon3
Dude hit me up anytime you need a shop to work in or some help, I'm close by. Love the Jeep by the way!
redneckrubicon3 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 08:27 AM   #63
BamaJeepman21
Thanks man!
I'm taking it to get aligned today. The vibrations have gotten somewhat better but I need to put on that BL/MML or drop the tcase ASAP. I almost don't like driving it because it feels like my driveshaft and tcase are shredding themselves apart.
I also bought a 7/16th bit the other day so I can get that swaybar drilled out. It's been raining the past 3 days so I haven't been able to get that finished. Then I'll lock tite/re-torque the wheels and wheel spacers. Then I can finally maybe get around to putting my bumpstops in.
-Jack
Unread 02-14-2013, 09:38 AM   #64
redneckrubicon3
Are you planing a sye? That will help a ton, and when you get adjustable links..... the pinion angle looked a bit off in one of your pics.
Unread 02-14-2013, 10:18 AM   #65
jeepjake15
Jack, were you out around 830-9 last night? I saw a jeep that looked similar to yours turning up governors from California st. If that was you the jeep looks great!!
jeepjake15 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 12:13 PM   #66
BamaJeepman21
Yea I'll get the JB super short SYE at some point. I have a list a page back of things to do before August.
That was indeed me. Are you going to be around Saturday? I really want to get that BL on and I need a garage.
-Jack
Unread 02-14-2013, 12:54 PM   #67
jeepjake15
I though so, everything looks great. And, I will be around but my garage is so full of crap it literally would take a day to make room for a vehicle. Although if its not wet or a$$ freezing cold it probably wouldn't be bad doing it in a driveway, that's what I did atleast. If I remember correctly you said you were installing an MML as well? If thats right, I haven't installed one before so I might not be your best bet for that but it doesn't look to be very complicated.
Unread 02-14-2013, 01:04 PM   #68
BamaJeepman21
Yea it's suppose to be 40* outside. Which is why I wanted a garage. For the MML, I would just take the fan shroud off and drive to the shop that's doing the MML. I don't want to cut it or do anything to it.
-Jack
Unread 02-14-2013, 02:16 PM   #69
jeepjake15
Mind if I ask what they are charging? I don't personally know how but from what I've seen I would never pay more than maybe 40ish? Seems pretty Straightforward.
Unread 02-14-2013, 03:48 PM   #70
BamaJeepman21
No idea yet. It's not an offroad shop but a smaller one that my dad is friends with and has taken his cars to get worked on/restored.
I'll just say Rocket City quoted me $500 for a BL/MML install...
-Jack
Unread 02-14-2013, 04:07 PM   #71
jeepjake15
Oh okay, shouldn't be too bad then. Yeah rocket city is ridiculous. They quoted me 800 labor for a 3in bl on my f150
Unread 02-14-2013, 04:33 PM   #72
janesy86
MML are pretty easy, just do one side at a time and its easy enough to line up. I did mine along with my BL in a few hours. Just make sure to PB blast all the bolts well. Then I helped my buddy with his and did it even quicker. I'd say try it yourself and save to coin.
Btw rigs starting to look pretty sharp!
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
[URL="http://www.jeepforum.com/forum/f22/janesys-03-rubicon-build-1358239"]Hylined '03 Rubi Build[/URL]
[URL="http://www.wm4x4.com/forums/"]Western MA 4x4[/URL]
janesy86 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 08:23 PM   #73
BamaJeepman21
They wanted $900 for my 3" lift/BL/MML all together. I know they have to make money and run a business but ******* I'm not going to pay almost the same for labor as I did the lift and everything!
I know I can knock out the BL. The MML still has me going eh. Nobody around me has done one except one of my friends and he said it was a complete *****. It all depends on if that other shop can cut us a deal.
Thanks man. I have to say it looks great. I just really need to wash and wax it. Just clean it up in general. I just now cleaned out all the old parts and stuff out the back.
On another note, I can cross some things off my list that are completed or on order.
TO DO
Install BL/MML
Install steering stabilizer
Install bumpstops
Install swaybar disco’s
Install wheel spacers with lock tite. Re-torque all bolts
Alignment
26 tooth speedo gear- $40
Extended brake lines- $55
Savvy/Currie bumpstop replacements- $175
JKS front trackbar- $185
JKS rear trackbar- $155
Transmission cooler- $80
Remote transmission filter- $30
Transmission deep pan- $50
4 fan, electric fan- $400
JB Conversions super short SYE- $300
Carolina driveshaft- $200
Blue Monkey speedo healer- $160
Savvy rear upper arms- $279
Savvy rear lower arms- $309
-Jack
Unread 02-14-2013, 09:22 PM   #74
Moabrubi
I don't know why so many people have issues with the MML. For me it was absolute cake. Instead of taking the entire motor mount off the block on the drivers side I opted to cut the bolt head off. It helped having 2 people so that one could move the motor where it needs to be while the other lines the motor mount through bolt up. I was able to knock it out in a couple of hours.
Moabrubi is online now   Reply With Quote Quick reply to this message
Unread 02-17-2013, 05:19 PM   #75
BamaJeepman21
Put on my BL today. Took about 2hrs with my dad and I taking our time. Went on without a hitch. But the radiator also finally decided to crack at the top. So I'm Jeepless until I get a new radiator. Definitly going Mopar since the original lasted 15yrs and 86,000 miles.
-Jack
