BamaJeepman21's build thread - Page 4 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > BamaJeepman21's build thread
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 02-05-2013, 10:24 PM   #46
BamaJeepman21
Well after all these set backs and arguments, I have 33" Duratracs on order and my lift is going on Saturday.
-Jack
BamaJeepman21 is offline   Reply With Quote Quick reply to this message
Unread 02-05-2013, 11:07 PM   #47
jeepjake15
Nice!! when are they getting put on?
jeepjake15 is offline   Reply With Quote Quick reply to this message
Unread 02-06-2013, 07:00 AM   #48
BamaJeepman21
They should be going on Saturday too. If Bush Tire gets them by then.
-Jack
Unread 02-09-2013, 12:40 PM   #49
Bama_WJ
Half way there
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 02-09-2013, 06:44 PM   #50
BamaJeepman21
So someone did take pictures during the install.
Thanks guys for coming out and helping me putting it on. Thanks to Paul for the garage. I'll go over the details in a minute.
-Jack
Unread 02-09-2013, 07:49 PM   #51
BamaJeepman21
So I arrive at Pauls around 8:30 and we didn't wait to get started. Once jacked up we took off the side boards, front shocks, and coils. Most everybody else showed up at around 9:30 with Daniel taking his time and wandering in sometime later.
The front took no time at all. We finished it in maybe an hour and a half. We couldn't squeeze the coil in there so we had to undo the lower control arms to get them in there. The rear proved to take some time with that trackbar bracket. I, for the most part, looked something like this.
Surprisingly no bolts were broken or proved hard to get out. Probably due to me spraying them down for a week and a set of nice impacts. The steering stabilizer would not go on due to bad threads on the front so I'll see what I can do about that. We didn't drill new holes for the trackbars and the front is offset to the passenger side just a bit. I don't think the rear is offset at all. We weren't able to get the bumpstop extensions in there because the original ones are rotted. The wheel spacers look great BUT we didn't have lock tite so I'll need to pick some up. We also didn't get the MML/BL on today. We were too tired and starving for some lunch. It'll go on another time. Here's the breakdown:
The Pros:
No broken bolts
Rides better than stock
Dem asthetics.
The Cons:
Has vibrations from hell. I'll need to put the spacers on.
There is some clunk coming from the front, right when I accelerate under 10mph. Not entirely sure what it could be unless it's a control arm. Sounds almost like a griding/clunking.
We didn't have a 7/16th's bit to drill out the sway bar so the disconnects aren't on yet. Sketchy doing 70 back on the interstate.
No bumpstops.
Needs extended brake lines and breather hoses.
Steering stabilizer wouldn't go on.
I think that's it. Overall it was a great day and we had no real issues putting it on.
Dat driveshaft angle.
On second look, I need a better picture.
The goods.
-Jack
Unread 02-10-2013, 07:22 AM   #52
Matt Graham
Man that thing looks great. That BL will make it just right. Good work!
Instagram: @mattgraham79 - http://instagram.com/mattgraham79
Youtube: http://goo.gl/ar21Wp
Matt Graham is offline   Reply With Quote Quick reply to this message
Unread 02-10-2013, 10:14 AM   #53
BamaJeepman21
Here's the driveshaft angle.
-Jack
Unread 02-10-2013, 10:17 AM   #54
BamaJeepman21
Pictures of the steering/front and the back. The stabilizer wouldn't go on because the threads were bad, so I'll file them down and see if I can get the crown nut on there.
-Jack
Unread 02-10-2013, 07:44 PM   #55
BamaJeepman21
I took some measurements tonight.
Front:
Driver's side sticks out about 3" from the flare while the passenger side sticks out ~1". I'll need an adjustable front trackbar.
There's about ~4 3/4 of the shock shaft out. Definitly need to extend my bumpstops but I'll wait until I get new jounce bumpers since all of mine are rotted out.
Rear:
Driver side sticks out around 2 1/2" from the flare. Passenger side sticks out around 2" from the flare. I'll get an adjustable track bar at some point in time.
There's about 5" of shock shaft showing in the rear. Again, I'll put in my bumpstops when I get new jounce bumpers.
-Jack
Unread 02-10-2013, 07:55 PM   #56
BamaJeepman21
Here's the priorities list. I would like to get all this done before August when I move down to Tuscaloosa. Safe interstate driving and stability is a top top priority.
TO DO
Install BL/MML
Install steering stabilizer
Install bumpstops
Install swaybar disco’s
Install wheel spacers with lock tite. Re-torque all bolts
Alignment
26 tooth speedo gear- $40
Extended brake lines- $55
New jounce bumper on all 4 corners- $70
JKS front trackbar- $185
JKS rear trackbar- $155
Transmission cooler- $80
Remote transmission filter- $30
Transmission deep pan- $50
4 fan, electric fan- $400
JB Conversions super short SYE- $300
Carolina driveshaft- $200
Blue Monkey speedo healer- $160
Savvy rear upper arms- $279
Savvy rear lower arms- $309
-Jack
Unread 02-10-2013, 08:53 PM   #57
Moabrubi
TO DO
Install BL/MML
Install bumpstops
Alignment
Why a speedo healer? I was under the impression that all non rubicons used speedo gears.
Looks alot better BTW.
Moabrubi is offline   Reply With Quote Quick reply to this message
Unread 02-10-2013, 09:39 PM   #58
BamaJeepman21
The JB super short SYE eliminates the gear driven portion and uses an electrical connection.
Thanks. I need to wash, wax, and clean all the old crap out of it.
-Jack
Unread 02-10-2013, 10:20 PM   #59
256ChiliPepper
Looks good man! Glad I could help. Let me know if you ever need help with it. No idea why your drive shaft is at that steep of an angle, mine wasn't that bad when I first did my lift.
98 4cyl TJ on 35s, armored, geared, locked, and ready to wheel
88 MJ 4.0L AW4 4wd. Stock.
256ChiliPepper is offline   Reply With Quote Quick reply to this message
Unread 02-10-2013, 10:27 PM   #60
jeepjake15
I can help ya with that bl when the time comes. Only took me about an hour to do mine with handtools!
