BamaJeepman21's build thread - Page 5 - JeepForum.com
post #61 of 135 Old 02-10-2013, 09:29 PM Thread Starter
BamaJeepman21
Originally Posted by 256ChiliPepper View Post
Looks good man! Glad I could help. Let me know if you ever need help with it. No idea why your drive shaft is at that steep of an angle, mine wasn't that bad when I first did my lift.
Probably because the 3" springs gave closer to 3.5"-4" since I have no extra weight besides the hardtop.
-Jack
BamaJeepman21 is offline
post #62 of 135 Old 02-14-2013, 12:58 AM
redneckrubicon3
Dude hit me up anytime you need a shop to work in or some help, I'm close by. Love the Jeep by the way!
redneckrubicon3 is offline
post #63 of 135 Old 02-14-2013, 07:27 AM Thread Starter
BamaJeepman21
Thanks man!
I'm taking it to get aligned today. The vibrations have gotten somewhat better but I need to put on that BL/MML or drop the tcase ASAP. I almost don't like driving it because it feels like my driveshaft and tcase are shredding themselves apart.
I also bought a 7/16th bit the other day so I can get that swaybar drilled out. It's been raining the past 3 days so I haven't been able to get that finished. Then I'll lock tite/re-torque the wheels and wheel spacers. Then I can finally maybe get around to putting my bumpstops in.
-Jack
post #64 of 135 Old 02-14-2013, 08:38 AM
redneckrubicon3
Are you planing a sye? That will help a ton, and when you get adjustable links..... the pinion angle looked a bit off in one of your pics.
post #65 of 135 Old 02-14-2013, 09:18 AM
jeepjake15
Jack, were you out around 830-9 last night? I saw a jeep that looked similar to yours turning up governors from California st. If that was you the jeep looks great!!
jeepjake15 is offline
post #66 of 135 Old 02-14-2013, 11:13 AM Thread Starter
BamaJeepman21
Yea I'll get the JB super short SYE at some point. I have a list a page back of things to do before August.
That was indeed me. Are you going to be around Saturday? I really want to get that BL on and I need a garage.
-Jack
post #67 of 135 Old 02-14-2013, 11:54 AM
jeepjake15
I though so, everything looks great. And, I will be around but my garage is so full of crap it literally would take a day to make room for a vehicle. Although if its not wet or a$$ freezing cold it probably wouldn't be bad doing it in a driveway, that's what I did atleast. If I remember correctly you said you were installing an MML as well? If thats right, I haven't installed one before so I might not be your best bet for that but it doesn't look to be very complicated.
post #68 of 135 Old 02-14-2013, 12:04 PM Thread Starter
BamaJeepman21
Yea it's suppose to be 40* outside. Which is why I wanted a garage. For the MML, I would just take the fan shroud off and drive to the shop that's doing the MML. I don't want to cut it or do anything to it.
-Jack
post #69 of 135 Old 02-14-2013, 01:16 PM
jeepjake15
Mind if I ask what they are charging? I don't personally know how but from what I've seen I would never pay more than maybe 40ish? Seems pretty Straightforward.
post #70 of 135 Old 02-14-2013, 02:48 PM Thread Starter
BamaJeepman21
No idea yet. It's not an offroad shop but a smaller one that my dad is friends with and has taken his cars to get worked on/restored.
I'll just say Rocket City quoted me $500 for a BL/MML install...
-Jack
post #71 of 135 Old 02-14-2013, 03:07 PM
jeepjake15
Oh okay, shouldn't be too bad then. Yeah rocket city is ridiculous. They quoted me 800 labor for a 3in bl on my f150
post #72 of 135 Old 02-14-2013, 03:33 PM
janesy86
MML are pretty easy, just do one side at a time and its easy enough to line up. I did mine along with my BL in a few hours. Just make sure to PB blast all the bolts well. Then I helped my buddy with his and did it even quicker. I'd say try it yourself and save to coin.
Btw rigs starting to look pretty sharp!
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
janesy86 is offline
post #73 of 135 Old 02-14-2013, 07:23 PM Thread Starter
BamaJeepman21
They wanted $900 for my 3" lift/BL/MML all together. I know they have to make money and run a business but ******* I'm not going to pay almost the same for labor as I did the lift and everything!
I know I can knock out the BL. The MML still has me going eh. Nobody around me has done one except one of my friends and he said it was a complete *****. It all depends on if that other shop can cut us a deal.
Thanks man. I have to say it looks great. I just really need to wash and wax it. Just clean it up in general. I just now cleaned out all the old parts and stuff out the back.
On another note, I can cross some things off my list that are completed or on order.
TO DO
Install BL/MML
Install steering stabilizer
Install bumpstops
Install swaybar disco’s
Install wheel spacers with lock tite. Re-torque all bolts
Alignment
26 tooth speedo gear- $40
Extended brake lines- $55
Savvy/Currie bumpstop replacements- $175
JKS front trackbar- $185
JKS rear trackbar- $155
Transmission cooler- $80
Remote transmission filter- $30
Transmission deep pan- $50
4 fan, electric fan- $400
JB Conversions super short SYE- $300
Carolina driveshaft- $200
Blue Monkey speedo healer- $160
Savvy rear upper arms- $279
Savvy rear lower arms- $309
-Jack
post #74 of 135 Old 02-14-2013, 08:22 PM
Moabrubi
I don't know why so many people have issues with the MML. For me it was absolute cake. Instead of taking the entire motor mount off the block on the drivers side I opted to cut the bolt head off. It helped having 2 people so that one could move the motor where it needs to be while the other lines the motor mount through bolt up. I was able to knock it out in a couple of hours.
Moabrubi is offline
post #75 of 135 Old 02-17-2013, 04:19 PM Thread Starter
BamaJeepman21
Put on my BL today. Took about 2hrs with my dad and I taking our time. Went on without a hitch. But the radiator also finally decided to crack at the top. So I'm Jeepless until I get a new radiator. Definitly going Mopar since the original lasted 15yrs and 86,000 miles.
-Jack
CJ5 build thread hybridmoments Jeep Builds 195 10-24-2012 11:31 PM
my build thread Glenn5 Jeep Builds 3 05-18-2010 08:10 PM
97 TJ Build Thread joet7287 Jeep Builds 72 05-03-2010 12:14 PM
