Back in Black. . . . 2000 TJ build - Page 6 - JeepForum.com
post #76 of 231 Old 04-07-2012, 07:48 AM Thread Starter
JCJeep97
Looks like next paycheck will bring in the locker. I've decided on a Spartan, which Baseline4x4 is selling for $259 on sale, free shipping.
Hopefully the install will go smoothly. Just wish there was a place to test it around here
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline
post #77 of 231 Old 04-09-2012, 08:06 PM
Jankoid
Spartan for $240 from Rock Auto:
http://www.rockauto.com/catalog/rafr...SLD3027-864167
Google "rock auto discount code" for another 5% off.
Jankoid is offline
post #78 of 231 Old 04-20-2012, 02:23 PM Thread Starter
JCJeep97
Just ordered the Spartan from Northridge, was able to talk them down to $249.20 shipped. Looks like it will be here next Thursday. I'm reserving next weekend as garage time
JCJeep97 is offline
post #79 of 231 Old 04-28-2012, 12:23 PM Thread Starter
JCJeep97
Got the Spartan in last night. Two hour job my ***! Took about five hours, but was relatively easy. What a difference. In 2wd, it's absolutely silent and drives exactly as it did before the operation, but in 4wd the pulling power is pretty awesome!
Took it for a little test drive on a little path close to home and I'm really impressed with the traction. Can't wait to test it on the rocks.
This video online was quite a help. Even though he installs an Aussie, it's basically the same process:
I had to pull the carrier for my install. If you had 3.07's you probably could do it in-housing. I used 85W-140 oil. . . . I think that is the reason it's so quiet.
JCJeep97 is offline
post #80 of 231 Old 04-29-2012, 09:33 AM Thread Starter
JCJeep97
So far, I see only one problem with the Spartan, and I'm being picky. When you drive for a while in 4low, it has a tendency to stay locked for about 20 or 30 feet when you put it back in 2wd. No big deal, but worth mentioning.
Did I mention it can drive up a light pole now?
JCJeep97 is offline
post #81 of 231 Old 04-29-2012, 09:51 AM
Jankoid
A light pole? Pictures or gtfo.
Jankoid is offline
post #82 of 231 Old 04-30-2012, 05:44 AM Thread Starter
JCJeep97
Seriously? You know how long it took to wait for Mr. Walmart Security man to get far enough away so I could try it???
JCJeep97 is offline
post #83 of 231 Old 04-30-2012, 07:30 AM Thread Starter
JCJeep97
By the way, I know how to replace inner axle seals now. It's really easy. They are super cheap too.
JCJeep97 is offline
post #84 of 231 Old 04-30-2012, 07:54 AM
Jankoid
For seriously? Hows that?
Jankoid is offline
post #85 of 231 Old 04-30-2012, 10:49 AM Thread Starter
JCJeep97
In the video above that guy does it. In a nutshell:
1. Drain diff.
2. Pull axle shafts (all the way out).
3. Pull carrier (make sure you mark the races. . . . they only go one way).
4. Take out old seals, press in new.
5. Put your **** back together.
Not worth paying someone to do it IMO. Pulling the carrier is easier than you would think, and it gives you a chance to check all the teeth on the gears for damage. I went ahead and replaced my inner seals while I had everything torn down.
JCJeep97 is offline
post #86 of 231 Old 04-30-2012, 11:01 AM
Jankoid
I still think I will just wait until I regear, which I plan on doing once I get the money from working this Summer. I wont need the LJ offroad again until mid July anyways, and it can be run on road just fine with a leaking seal.
Jankoid is offline
post #87 of 231 Old 04-30-2012, 11:03 AM Thread Starter
JCJeep97
Makes sense to me. I'm probably going to tackle a regear myself this summer. You don't know where I could get some (well priced) 4.56 or 4.88's for a D30/D44 combo do ya?
JCJeep97 is offline
post #88 of 231 Old 04-30-2012, 11:11 AM
Jankoid
Don't know of a good place, but I hear Motive Gear is good for the money. Definitely go to 4.88 if you are staying on 35s. Also, when you regear you should pick up a junkyard HP30 from a 97-99 XJ. Then carry your locker, diff cover, stock axle shafts, and stock outers over to the new housing. They can be had for ~$125, and are a great strength upgrade over your LP30.
Jankoid is offline
post #89 of 231 Old 05-24-2012, 07:59 AM Thread Starter
JCJeep97
After Uwharrie this past weekend, I realized what a difference the Spartan made. No more ****ing around with open diffs for me. . . . the only drawback was having the front locked all the time made it a little tougher to make tight turns, but the advantages HEAVILY outweigh the drawbacks.
I'm ready to go again. I found out I need some SERIOUS practice in off-camber situations. . . . 15 degrees or more was about the edge of my comfort limit!
Pics:
Uwharrie May 19 012.jpg   Uwharrie May 19 024.jpg   Uwharrie May 19 040.jpg   Uwharrie May 19 045.jpg   Uwharrie May 19 114.jpg
JCJeep97 is offline
post #90 of 231 Old 05-24-2012, 08:29 AM
Jankoid
QFT
One trip to Coal Creek with me will fix that problem.
Nice to see some wheeling pictures for a change.
Jankoid is offline
nc guys
jeef124: A Black on Black XJ Build jeef124 Jeep Builds 54 10-09-2012 02:39 PM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
My 2000 TJ build... 07wurubi Jeep Builds 6 09-18-2010 12:17 AM
Black Jeep w/ Black tube front bumper with hoop, black tube back bumper and sides MaK10 Jeep Picture Requests 4 04-03-2006 06:54 PM
Back in Black tube yj Jeep Builds 2 10-04-2004 12:01 AM
