A baby Xj on its way to manhood! - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > A baby Xj on its way to manhood!
Bill Baird Motorsports DIY parts - NalinMFG.comFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 03-16-2014, 05:03 PM   #1
stottman888
So heres the story, I was 14 years old and really wanted a jeep. All that i had was a 2004 kawasaki kx 85 so i figured thats somewhere good to start. About a year and a half later I have been through 7 bikes (1999 kx 60,2003 kx 85, 2004 kx 85, 2008 kx 100,1997 kx 125,and lastly a 2004 RM-Z 250f) 1 quad (2001 trx 400 athena big bore 440 kit and all sorts of other goodies) an enclosed trailer and then a CJ-7 with a 350 SBC it was a turd but still made money . And this is where i ran into my now current 1999 jeep cherokee sport 4.0 AW4 np 231 hp d30 and Chrysler 8.25 rear end 179,XXX miles. SHes currently all stock except for the tires which are 28 inch good year wranglers (basically brand new) . The only real problems I've really had with it so far is the airbag light is on which Ive yet to figure out and there was some rust holes in the rear quarter panels, it was an up north car brought down here to south florida but thats the only really bad rust spots just started working on the rust today and decided why not start a build thread from the very beggining. So now ive got some final ideas running through but im going to go through a couple stages.
Stage 1: 31s 4.5 inch rustys lift uni body re-inforcements steering box brace.
Stage 2: One tons full width comp cut and 35s-38s and everything thats needed for when running one ton running gear.
Finally Stage 3 which im not sure if i want do yet or not still deciding but here goes it, 383 stroker mated to a th 350 built.
I would like some input and some pointers on this build maybe ideas and things that would just be neat, im only 15 and have done this on my own so far and i think now is the time for help and questions lol. Oh yeah and just a couple pics to show you what im working with here
stottman888 is offline   Reply With Quote
Unread 03-16-2014, 09:21 PM   #2
freaknajeep
1971 DJ
ok so heres some inspiration for ya....
Be carefull while Hugging the Trees...They leave dents on your Jeep....
Shhhhhh I'm not crazy...It's just the voices in my head
freaknajeep is offline   Reply With Quote
Unread 03-17-2014, 12:39 PM   #3
stottman888
That Xj looks great! In due time will my xj look similar but with a personal touch to it. Is it just me or did that 4.3 seem a little underpowered for that?
Unread 03-17-2014, 01:12 PM   #4
caronaxtr
Looks good, first 2 things I'd suggest to do would be 1) loose the mud flaps, 2) do a cut & fold to the rear before you can't even do that. Looks like that thing has send some salty winters.
I went from this:
To this:
Quick & easy, looks 100% better than that Rust hole.
Lookin good & good luck. Get a build thread going right away, even for the little stuff.
caronaxtr is offline   Reply With Quote
Unread 03-17-2014, 01:32 PM   #5
stottman888
Good job on your cut and fold bud! I think that's what I'm going to do now thanks for the suggestion, how did you seal it up though sorry if I sound like dummy I've never done it before but I guess I'm gonna learn lol. And yes definitely mud flaps are gone those things were hideous.
Unread 03-19-2014, 08:32 AM   #6
caronaxtr
There are a bunch of right ups on doing cut & folds. Do a search here @ cherokee forum. Here are some pictures from my cut & fold:
Side cut:
Back:
Front:
Crap that was cut out:
Sheet metal I used, cut to size, primed & painted & a crap load of silicone calk to seal it up:
Finished product:
Tips, layout, layout, layout, cut with a 4.5" angle grinder ( needed a sawzall for 1 cut), used stainless steel material, drilled & used pop rivets to hold everything together. A couple of weeks later I monstalined underneath with 2 heavy coats & also didmy rockers. Good luck and let me know if you have any other questions.
Unread 03-20-2014, 02:03 PM   #7
stottman888
Thanks caronaxtr ! thats really gonna help me out when i get around to doing it been real busy with school havent had the chance to mess around with her. Also good choice with the stainless steel no rust for you.
Unread 04-14-2014, 06:56 PM   #8
stottman888
I've been trying to figure out a problem in the Jeep for a while now i think i need a little help. The radio in it works but only in the soundbar nothing in the front. I pulled them out tested them followed the wire all the way back and still nothing. So i figured the only other thing left would be the head unit because when the radio is on the speakers go loud then quiet and jump all around. Is my head unit bad? Has anybody else had this problem?
Unread 04-15-2014, 11:35 AM   #9
caronaxtr
Sounds like your head unit may be bad is it stock or aftermarket? If you have dials / knobs the contacts get worn out over time. Depending on what your wants/needs area new aftermarket head unit could start at $80 and up. A wiring harness is about $30 or so. Quick and easy upgrade, might want to do speakers too since the head unit will be new, the old stock speakers may sound like crap (mine do with a newer head unit, but music is down the list for me)
Unread 04-15-2014, 04:57 PM   #10
Name
i had the same problem, turned out the wire in the door was broken, but the rubber insulation was still intact.
Name is offline   Reply With Quote
Unread 04-17-2014, 07:09 PM   #11
stottman888
Alright well i went ahead and decided to just buy a new head unit from best buy now just gotta get the motivation and time to do it. Finally got a job (at a car upholstery shop) Its nice to have a job now just saving for all the fees of getting your license and insurance.
Unread 06-01-2014, 09:32 PM   #12
stottman888
Well pretty successful weekend took the Heep out to a couple little mudholes around town and then somehow managed to blow out my front tire on something and it tore the whole sidewall out . So i went back to my carlot and just threw an old ranger tire and rim on there for the day. And then wrapped up Sunday night by taking the girlfriends tj out pictures to come soon, ahh livin the jeep life!
1926864_763009517071902_5411031119495525738_n.jpg   1959514_763009487071905_4918875222497479902_n.jpg   10155731_763009360405251_5590722512203398089_n.jpg   10411339_763009437071910_729283429407416244_n.jpg   10440282_763009460405241_3084828266173612783_n.jpg
Unread 07-14-2014, 08:49 PM   #13
stottman888
Im having some trouble the jeep i have no interior lights no gauges no radio and the power locks work but to only unlock.. Does anybody have any suggestions cause i already banged on the dash because of the ground behind it and checked a couple fuses but am still lost i need some advice thanks
Unread 07-14-2014, 09:28 PM   #14
stottman888
Just figured it out, it was a 15 amp fuse IOD under the hood.
Unread 07-15-2014, 08:54 AM   #15
patrickomalley
Lookin good!
patrickomalley is offline   Reply With Quote
