Ax15 swap to aw4 trans - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ax15 swap to aw4 trans
Want to be able to SEE? DOT Approved Headlights for under Coil Spring Options from Ruffstuff!Flush Mount LED Bumper Lights, CREE
Unread 11-27-2014, 12:45 PM   #1
turnbilljr
Junior Member
Hey everyone , I am wanting to go to automatic trans . I have a 94 wrangler with a 4.6 stroker and ax15 trans thinking about going to a aw4 automatic trans with a manual shift. Also going to install a 4" lift and run 33/1250/15 tires . With a 3.73 gear. Just need your all opinion on this. Do you think that the aw4 is a good automatic trans for this set up ? Thanks !
turnbilljr is offline   Reply With Quote Quick reply to this message
