Awheeler's 99 TJ Build - JeepForum.com
post #1 of 13 Old 11-26-2013, 07:39 AM Thread Starter
AWheeler
Exterior:
Metalcloak fenders
Smittybilt rock sliders
Smittybilt rear armor
Smittybilt rear bumper and swing arm
Front bumper with integrated winch plate
Recovery:
Harbor Freight 10k winch
Axles:
Rear: Ford 8.8
4.10
LSD
Disc brakes
Artec truss
Front: Rubicon D44 with stock air locker
Chromo axle shafts
Sleeved
Gusseted
Next upgrade will be super u joints
Driveline: BUILD IN PROGRESS
5.3 LS V8
LS6 headers
4L60E transmission
Novak Adapter (Transmission to Tcase)
Advanced Adapter VSS
Novak Tach Emulator
NP231J
SYE
Custom wiring harness
Custom speed sensor adapter
TBD - Shifter, exhaust and driveshafts
Lift:
Rough Country 4" lift
JKS front and rear adjustable track bar
Rough Country front and rear - upper and lower adjustable control arms
Tires:
Maxxis Mudders - 33x12.5x15 on Weld 15x10 for the street
Goodyear MTS Kevlar - 35x12.5x15 on black steelies for the trail
Interior:
None - looking for right set of new seats
It is finally time to post a build thread for my Heep. The surgical adventure that it is currently undergoing might be of interest to some, so here it goes...
I purchased "Project Smurf" (named by my daughter) about 3 years ago. It was mostly stock with a 4" lift, 33's and 15x10 weld wheels. Great for a driver.
AWheeler is offline
post #2 of 13 Old 11-26-2013, 07:44 AM Thread Starter
AWheeler
The first project was to install an 8.8 under the Jeep. So, I purchased an 8.8 from JFjeld. It is a 4.10 LSD with "Solid" diff cover and disc brakes. Since the Jeep has 3.73's, I purchased a 4.10 r&p for the D30 and an Aussie locker.
AWheeler is offline
post #3 of 13 Old 11-26-2013, 07:48 AM Thread Starter
AWheeler
Then came the body armor and bumpers. Metalcloak front fenders and SB rock sliders, rear quarter, swing arm rear bumper and SB KO front winch bumper. Then decided to use 35's on the trail.
AWheeler is offline
post #4 of 13 Old 11-26-2013, 07:59 AM Thread Starter
AWheeler
After driving it a bit like that, I went to the trail and ended up busting a u-joint, which ate the axle "ears", which pushed out the lower ball joint. So, I started looking for a new front axle.
This brings me up to today and where the build officially goes into overdrive. I ended up finding a replacement axle on Jeepforum from Battybluecb. It is a Rubicon D44 front axle with about 19k miles on it. Mostly stock but with chromo shafts, sleeved and gusseted. I am adding some super u-joints.
After long consults with Helldorado Customs and Leftlanetrucking, the Jeep is now in surgery for a heart transplant! It is getting a 5.3 with a 4L60E transmission and a NP231CHD / NP231J transfer case. Can't wait to get the project done. A disclaimer, Warrior Diesel and Automotive (Tim Smith) is doing the work out of Rogersville, MO. I will post pictures as things progress. Estimated time of completion is end of December - early January.
Can't wait!!
AWheeler is offline
post #5 of 13 Old 11-26-2013, 09:13 AM
monsonman
monsonman's Avatar
dang, well this build escalated quickly
'05 LJ Rubicon Build:
'98 TJ- build:
instagram: @vohnsonthemonson
monsonman is offline
post #6 of 13 Old 11-26-2013, 12:21 PM Thread Starter
AWheeler
HA, I hear ya. One of those threads that I didn't see a need to post until now. The 5.3 swap is what may be most interesting to folks, so pictures and updates to come as things progress.
AWheeler is offline
post #7 of 13 Old 11-28-2013, 10:08 AM
Jbostick
Heck of a build so far! When the 4l60e is swapped in what is used for the gear selector?
Jbostick is offline
post #8 of 13 Old 11-28-2013, 11:14 AM Thread Starter
AWheeler
Not sure yet. Will certainly let you know when we decide. My goal is to keep the interior as stock looking as possible, so it will need to be something that looks like it belongs there. Any suggestions?
AWheeler is offline
post #9 of 13 Old 11-28-2013, 11:38 AM
Jbostick
Keeping everything stock looking was also what I am looking for. I wonder if the gear selector from a 42rle could be adapted to use.
Jbostick is offline
post #10 of 13 Old 01-02-2014, 07:17 AM Thread Starter
AWheeler
Teardown is complete - ready for reassembly!! The shop doing the work is wonderful to work with...
AWheeler is offline
post #11 of 13 Old 01-27-2014, 07:42 PM Thread Starter
AWheeler
Frame is notched, motor mounts are done and engine is in! Lots of things left to do. The motor is actually Chevy orange.... looks like a different color in the picture.
AWheeler is offline
post #12 of 13 Old 01-29-2014, 08:14 AM Thread Starter
AWheeler
More updates
AWheeler is offline
post #13 of 13 Old 02-17-2014, 09:34 AM Thread Starter
AWheeler
Wiring, wiring and more wiring!! Who knew there was sooo much wiring in a simple TJ. Things are progressing along...
AWheeler is offline
