Ant-seize or threadlock? - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ant-seize or threadlock?
Labor Day Sale!Clayton Off Road - last day of the Labor Day special!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 04-10-2014, 09:56 PM   #1
rdiaz
Junior Member
rdiaz's Avatar
1978 CJ5
what do you guys recommend for the ubolt bolt's and shackle hanger bolts? can't find any good reference to recommend either or. here's a few pics of the project.
some stats:
Currie 9 inch wide track
4.11 gears
ARB locker
3.5 inch OME lift
cj to yj spring conversion
BFG mud terrain KM2's
Spyderlock beadlocks
Thanks for your help guys!
rdiaz is offline   Reply With Quote
Unread 04-10-2014, 09:59 PM   #2
rdiaz
Junior Member
rdiaz's Avatar
1978 CJ5
Also, would you guys cut the excess ubolt threads that extend down beyond the skid plate? those are direct from Currie. i'm assuming there made to fit a wide range of lifts and then be cut to keep the under surface smooth and remove the likleyhood of an obstacle hang up.
Unread 04-11-2014, 05:16 AM   #3
martinfan
Yes those bolts need trimmed. I've never used anti seize or lock tight just re torque after 500 miles or so. Shackle bolts I use a nyloc style nut. Don't forget shackles are part of the suspension and must "move freely". I've seen so many shackles over tightened and then drivers complain about the ride. Jeep looks good
martinfan is offline   Reply With Quote
