Another YJ Build......GenRight Style - Page 4 - JeepForum.com
post #46 of 350 Old 05-09-2012, 10:38 AM Thread Starter
caddyman
Originally Posted by ThatJeepGuy View Post
Questions: What shift kit is in your 3speed? How much did it cost? Do you like it or would you just swap it out for a aw4 or ax15 if you were to do it again?
Also what brand SOA springs are those and how much lift do they provide over stock leafs SOA?
Just curious. Thanks
The three speed transmission was set up that way before I bought it. To be honest I not sure what I would rather have, auto or manual? This is my first Jeep and I almost didn't by it because of the auto transmission but it was a really good deal and I was looking for something cheap because I was going to modify it anyway. My next major project will be to put a LS1,2 or 3 in and I will need to change the transmission. I have friends that run NV4500 and other that run 4l60 or 4l80's. I will just cross that bridge when I get to it.
The SOA kit was also on the Jeep when I got it but the springs are Rubicon Express 1.5", I would say the over all lift is 6-7", I cleared 37" with no problem.
Hope this answered your question, let me know if you have any others. I have taken a lot of detailed pictures along this build, I've only posted a fraction of what I have taken.
The picture I posted is a before picutre with the SOA sitting on 37" Krawlers
caddyman is offline
post #47 of 350 Old 05-09-2012, 01:52 PM
ThatJeepGuy
Yea that answered my questions pretty well. I wad curious to see if the shift kit have you any dramatic improvements over stock. Thanks again. Keep them pictures coming!
93YJ / 4'' lift / 33'' mtzs / aussie locker in hpd30 / pos d35 in rear(for now) / xrc rock sliders & rear xrc tube fenders tj style/ AJ's offroad rear bumper and tire carrier / LP10000 Superwinch / SQUARE HEADLIGHTS
No farms no food
ThatJeepGuy is offline
post #48 of 350 Old 05-09-2012, 02:13 PM Thread Starter
caddyman
Sorry, not sure what type of shift kit it has but it has a good/harsh jerk when it shifts.
The only thing I really don't like about the transmission is that there is no over drive and with 4.88 I'm max'ed out at 50-55mph.
caddyman is offline
post #49 of 350 Old 05-09-2012, 04:43 PM
ThatJeepGuy
I think that has more to do with 37"s than the gears. I'll be shutting up now
No farms no food
post #50 of 350 Old 05-09-2012, 10:36 PM Thread Starter
caddyman
I installed the front link brackets, made the links, tie rod, drag link, and trac bar, then mounted everything for mock up.
Jeep Build Part 11 031.jpg   Jeep Build Part 11 039.jpg   Jeep Build Part 11 041.jpg   Jeep Build Part 11 045.jpg   Jeep Build Part 11 042.jpg
Jeep Build Part 11 048.jpg   Jeep Build Part 11 050.jpg   Jeep Build Part 11 054.jpg   Jeep Build Part 11 055.jpg
caddyman is offline
post #51 of 350 Old 05-18-2012, 02:55 AM
Adrian Hallows
Hey Caddy, Looking good mate. Anymore updates? You have some great photos there
Adrian Hallows is offline
post #52 of 350 Old 05-18-2012, 08:00 AM
crb577
So on the rear were you able to get the full 5" stretch with the ext tank? I got just under 4 with cycling suspension on mine just curious I have an 8.8 and wasn't sure if that was the cause. I wanted to go the route you are going but it was a bit to much for me but it looks great! The gen right stuff is top quality.
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,SOA xj rear 100" wheelbase, homemade greasable boomerang shackles, SS braided lines, 1" prothane body lift, 35" TrXus M/T, smitty built XRC.
lots of gen right armor and rear stinger.
crb577 is offline
post #53 of 350 Old 05-18-2012, 08:15 AM
USMCBuckWild
Amazing build!
Jealousy, I have it
USMCBuckWild is offline
post #54 of 350 Old 05-18-2012, 01:26 PM Thread Starter
caddyman
Thanks,
The "mate" through me off, I had to do a double take that you are in Australia!
I love the internet and JF.com, how else could someone from Australia be checking out my Jeep build.
That's awesome!
Thank you,
I didn't use the EXT tank, I used the COMP tank. I was able to stretch it 6" but have room to spare with the D44. Someday I might go with a D60 and should have room without doing anything to the links.
91 Jeep YJ Linked, Stretched, C/O's, Atlas, 39" Krawlers, ton's 60/14 bolt, ARB'S, GenRight's poster child!
My Build:
caddyman is offline
post #55 of 350 Old 05-18-2012, 01:36 PM Thread Starter
caddyman
I ran into a little clearance issue with the frame and drag link. I just notched the frame a little and now the issue is gone.
Shock hoops and cross over bar are tacked into place and just checking the final fitment and cycling the suspension.
Next I will be working on the bump stop can's and finishing the belly/engine skid plate.
To Be Continued.........
Jeep Build Part 13 006.jpg   Jeep Build Part 13 007.jpg   Jeep Build Part 13 005.jpg   Jeep Build Part 13 002.jpg   Jeep Build Part 13 024.jpg
My Build:
caddyman is offline
post #56 of 350 Old 05-18-2012, 08:38 PM
Kamikaze
Awesome build. Your skill is amazing. I really envy you jeep. Keep it up.
Live Free, Laugh Loud and be Friendly.
Kamikaze is offline
post #57 of 350 Old 05-18-2012, 10:27 PM
Tamatacan
Yeah this is one awesome build.
Tamatacan is offline
post #58 of 350 Old 05-19-2012, 04:32 AM
fratis
fratis's Avatar
make sure to turn your steering from lock to lock at full bump. your cut-out looks a bit tight.
do you get any binding between the draglink and tie-rod at bump with the drag mounted behind the tierod on the steering arm?
looks like the axle-trackbar mount might offend as well when the passenger side is high and the driver side is at full droop. i had to lower mine significantly as well as shave an inch off the bottom of the framerails.
continuous tacks are fine on the frame with such thin material but not needed on the axle tubing and links. there's enough meat to take the heat.
how much lower then the bottom of the framerail does the rear linkmount crossmember on the frame-end hang?
looking good. wish my frame was as clean.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #59 of 350 Old 05-19-2012, 12:03 PM
c_coops
Would continuous tacks be as strong as a normal weld pool? I've never considered doing this but it definitely looks good.
c_coops is offline
post #60 of 350 Old 05-19-2012, 09:18 PM Thread Starter
caddyman
It has to do with speed also, I have a continuous pool as I'm welding. Personally I've never had one of my welding break, pull a part or crack?
I'm not a professional welder but I did stay at a Holiday Inn Express last night.
My Build:
caddyman is offline
U-bolt style vs. strap style (driveshaft to yoke u-joint) I8AHUMR YJ Wrangler Technical Forum 27 12-08-2014 03:55 PM
Questions on LCG style build for street/mud/rocks teCh0010 TJ Wrangler Technical Forum 17 06-13-2012 07:38 PM
Dana 35 u-bolt style yoke to replace strap style Rickster TJ Wrangler Technical Forum 5 07-05-2009 01:57 PM
family style bar plus slant style to make a cage? YJames90 YJ Wrangler Technical Forum 2 03-21-2008 07:03 PM
old style / new style door window slider SPRPRBGT YJ Wrangler Technical Forum 0 10-21-2005 08:36 AM
