Another YJ Build......GenRight Style - Page 12 - JeepForum.com
 3Likes
post #166 of 354 Old 09-26-2012, 04:54 PM
USMCBuckWild
I just noticed the little light inside the front fender above the tire. Very cool!!! Any details on that?
USMCBuckWild is offline
post #167 of 354 Old 09-26-2012, 05:24 PM Thread Starter
caddyman
Those are Rigid LED's and I use them for my front/side rock lights. I got then at 4 wheels parts, around $90ea
91 Jeep YJ Linked, Stretched, C/O's, Atlas, 39" Krawlers, ton's 60/14 bolt, ARB'S, GenRight's poster child!
My Build:
caddyman is offline
post #168 of 354 Old 09-26-2012, 06:19 PM
scubamc
Originally Posted by caddyman
Bad news, looks like my 44's just aren't wide enough, inner tire touches the spring
I ran into the same issue with my front 3 link. Spacers solved the problem.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #169 of 354 Old 09-26-2012, 07:09 PM Thread Starter
caddyman
I'm looking at a 3" spacers, just way to wide.
My Build:
caddyman is offline
post #170 of 354 Old 09-26-2012, 08:43 PM
scubamc
Agree. I was lucky and only needed 1.25" spacers.
scubamc is offline
post #171 of 354 Old 09-27-2012, 09:02 AM
ssyj94
Jeep turned out great! I run 1.5" spacers on my 8.8 to clear the coilovers and the tires still rub a touch when aired down. How bad are you getting into the coilovers? Got another question what did you end up running for spring rates?
My build:
ssyj94 is offline
post #172 of 354 Old 09-27-2012, 09:23 AM Thread Starter
caddyman
Really bad!!!
150/250, but that still might change to lighter spring?
My Build:
caddyman is offline
post #173 of 354 Old 09-27-2012, 11:37 AM
ssyj94
See how it is you may want togo lighter I was 175/250 and just swapped to 175/175 and the ride is noticably better. Can you just move the lower mount in on the axle some how close is the coil to the upper mount at full droop? Or it also looks like 1.5" spacer would probably do the trick. What do you have from the outside framerail to the inside buldge of the tire so I can compare it to mine for you.
My build:
ssyj94 is offline
post #174 of 354 Old 09-27-2012, 12:16 PM Thread Starter
caddyman
If I move the lower mount in to the diff then the shock goes passed vertical at full droop.
At the time of the photo I already had a 2" spacer on the axle.
Inner tire to frame is 5"
My Build:
caddyman is offline
post #175 of 354 Old 09-27-2012, 03:20 PM
soonermatt
Dumb question...can you pull your hoops in to get rid of that rub? The angle will make them slightly softer too.
soonermatt is offline
post #176 of 354 Old 09-27-2012, 09:33 PM Thread Starter
caddyman
The rear hoops? No, beside I would weaken them. I'm building 60's, just bought a front tonight.
My Build:
caddyman is offline
post #177 of 354 Old 09-28-2012, 11:20 AM
ssyj94
Yeah I've also got 5" with an 8.8 and 1.5" spacer. Your backspacing may be the difference in needing 3" spacers to clear.
I run 12" shocks so its prob more of an issue with the 14's. You gonna try to find an e350 60 for the back?
My build:
ssyj94 is offline
post #178 of 354 Old 09-28-2012, 09:45 PM
Pocketsempty
WOW! How much did that set you back? So us poorer folks have a number to shoot for...
i swear my yj knows when payday is coming...
Pocketsempty is offline
post #179 of 354 Old 09-29-2012, 01:09 AM Thread Starter
caddyman
I really haven't sat down and added it all up, but I did need to get a larger box for all the receipts
That's one of the reason's I'm building my own 60's, in fact I got the front axle last night. It was out of a 87 F350 SRW HP KP Drivers, in really good condition, king pins look almost new. Cali truck for sure!
My Build:
caddyman is offline
post #180 of 354 Old 10-25-2012, 03:48 PM Thread Starter
caddyman
Just a little update, still gathering parts for my axle swaps.
So far I have;
87 Ford Dana 60 KP HP front axle 69" WMS (I'm going to narrow to 67")
89 Chevy Suburban 3/4 14 bolt FF rear axle 67" WMS
Artec High steering arms
Reid Ford Knuckles
Rear Wilwood brake calipers
All new axle brackets and bridge from GenRight
New 39" BFG Krawlers (red label)
Still need,
5.13 gear sets
ARB lockers
Front inner and outer axle shafts
Drive flanges
New 8 lug Beadlocks wheels
Chevy F & R brake rotors
Seem like I've been down this road before.........................
My Build:
caddyman is offline
U-bolt style vs. strap style (driveshaft to yoke u-joint) I8AHUMR YJ Wrangler Technical Forum 27 12-08-2014 02:55 PM
Questions on LCG style build for street/mud/rocks teCh0010 TJ Wrangler Technical Forum 17 06-13-2012 06:38 PM
Dana 35 u-bolt style yoke to replace strap style Rickster TJ Wrangler Technical Forum 5 07-05-2009 12:57 PM
family style bar plus slant style to make a cage? YJames90 YJ Wrangler Technical Forum 2 03-21-2008 06:03 PM
old style / new style door window slider SPRPRBGT YJ Wrangler Technical Forum 0 10-21-2005 07:36 AM
