Another TJ-6 Build - JeepForum.com
post #1 of 119 Old 08-12-2012, 04:51 PM Thread Starter
Sahara Surfer
Another TJ-6 Build
Well, I have decided to follow in the footsteps of a few talented individuals before me and stretch my TJ tub and frame by 15”. A couple examples of my inspiration can be found on the following links (Thank you, 'Ziptie' Jason and ‘Kelowna’ Mike).
bctj's 108" TJ. the TJ6
Ziptie's Tj-6 build
I don’t know who coined the “TJ-6” moniker first, but I like the whole CJ-6 theme… and with their permission, I am going to run with it. Here are a couple of other 15” stretches I came across in my research.
Truth is, I always wanted an LJ. The advantages of the larger wheelbase and extra interior room can’t be denied. At one point, I was seriously considering trading my TJ for an LJ but the cost of this trade up always got in the way of this plan. It seems like LJ’s are hard to come by in general (I can’t say I blame people for wanting to keep them). Whenever one popped up, they were either high mileage Jeeps with a minimum $12K price tag or just too close to $20K. Considering that at best I can only get 6K for my 99 Sahara with almost 200K miles in the odometer, I knew I was going to pay dearly for it. Then there is the issue of the $6K I had already spent on mods over the years. I was going to have to start all over again (I just put on an AEV highline, I was not about to just give that away!!)
I then came across Mike and Jason’s impressive TJ-6 builds and others like them. As I looked into to it further, it dawned on me that this was something that was definitely within my fabrication abilities and budget.
I am licensed structural engineer by trade but do have some basic know how on metalworking and welding. Plus, I have recently dabbled in bodywork and automotive painting when I did my highline install.
Like Mike, I will use frame sections from a wrecked TJ for the frame extensions and will borrow ideas from the AEV Brute frame extension conversion. I will attempt to repair the 15” tub gaps with 18 gauge sheet metal and body filler (Some creativity will be required to effectively hide the splice seams). I will remove the soft top belt rail on the driver’s side and transplant the excess material to belt rail gap in the passenger side. I will then use a new LJ belt rail for the driver’s side.
Here is a digital previsualization of the finished product:
I will tally up all the material costs at the end along with any money I gained from selling my current soft top and frame from my TJ. So far, the biggest expense has been a new Bestop LJ top and soft top frame ($1000).
Along the way, I will incorporate upgrades to the roll cage, skid plate, suspension, and drivetrain that I would have already done on my SWB TJ anyway.
Sahara Surfer is offline
post #2 of 119 Old 08-12-2012, 04:57 PM Thread Starter
Sahara Surfer
Well, without any further delay... Here is my TJ-6 build:
After securing all the required steel, I proceeded to measure and cut the 15” frame extension sections along with drilling the ½” plug weld holes. As previously mentioned, these came from a junked TJ.
I then cut ¼” thick wall, rectangular 3” x 4” tube steel into sections for the smaller frame inserts. Using the frame extensions as templates, I sized the ¼” thick inserts to fit inside the frame sections in 8” lengths. I then welded the two halves together into a completed insert as shown on the right side of my welding table. The fitting for this took up the better part of a weekend. Details, details…
On the following image, I have the fabricated 3/16” fish plates that I will place on the interior faces of the extended frame sections; just like AEV does it with the Brute conversion.
post #3 of 119 Old 08-12-2012, 05:00 PM Thread Starter
Sahara Surfer
I then removed 26” of the passenger retainer belt rail as shown. This was accomplished by drilling out the spot welds with a spot weld remover bit and then carefully prying off the rail one section at a time:
I also removed the entire retainer belt rail on the driver’s side:
As previously mentioned, I will use sections from the removed driver’s side retainer rail to complete passenger side retainer rail gap. I bought a new LJ rail (black) for the driver’s side.
post #4 of 119 Old 08-12-2012, 05:03 PM Thread Starter
Sahara Surfer
Let the hacking of the tub continue! I drilled out all the spot welds at the rear floor splice with the spot weld remover bit as shown. From there, it was just a matter of carefully prying up the sheet metal edge with a chisel to separate the factory structural glue.
I then made my cuts on the rollbars. Because 1/8” to 3/16” of material will be lost as a result of the cut and subsequent weld gap created, I was careful to mark reference points on either side of the cuts before making the cuts. These reference points will help me later on with the installation of the extension pieces:
post #5 of 119 Old 08-12-2012, 05:10 PM Thread Starter
Sahara Surfer
Cutting the sides of the tub was tricky. The main roll bar ties into a boxed panel section that is part of the door frame. If we cut anywhere in this area, we weaken the main roll bar tie-in and the door striker attachment point. So that really just leaves us with one place. The interior seam where this boxed rollbar tie-in ends. You can see the seam in the following picture on the driver’s side of the tub (I already drilled some small reference holes at the ends and started cutting with a rotary blade):
Passenger side, already cut along seam:
The following image shows the cutting path I took. As shown previously, I cut straight down the belt rail, perpendicular to the top, until I got to the bottom of the belt rail bend. Here, I cut 9.5” along that seam I showed you earlier on the inside and then stopped. Note that until now, our cut has been on the interior side of the wheel well.
From the bottom wheel well flange (hi-lighted in yellow in the image below), I made a straight five-inch cut up to a point, 1” away from the edge of the wheel well. This five inch cut is on the exterior side of the wheel well. I then made another straight cut to the end of my previous cut, also on the exterior side of the wheel well.
The idea is to make these cuts as straight as possible to facilitate the new panel splices.
Next is the matter of completing the rear tub separation by making the final cuts along the wheel well hump.
From the edge of the separated bottom floor panel, I cut straight across to the roll bar tie-in box in the interior of the tub as shown:
To complete the cut on the edge of the raised floor panel, we need to make a cut with a sawzall on the exterior side of the wheel well as shown below. To access this area, I recommend removing the tire or jacking up the frame at the corner to clear the tire (What I did). It will also help tremendously, if you already have a 1” body lift like I did.
To complete the wheel well cut near the exterior face, I had to make one straight cut in the exterior face of the wheel well. Unfortunately, this will also make a horizontal cut on that roll bar tie-in boxed section. Oh well, one more area to repair after separation. To make the last few millimeters, you may need to use a dremel or jigsaw. Notice how I have the cut wheel well flange temporarily clamped out of the way. It would have been a shame to have accidentally cut this off with the sawzall after all the carefull measuring.
After making all our cuts as shown, the only thing holding the wheel well humps to the exterior sheet panel sides is a structural glue. I took a chisel and carefully separated the glue at these joints:
Once I remove the four body mount bolts attaching the tub to the frame, tub separation is achieved:
Here is another shot of the removed tub and the resulting cuts on the side of the tub.
post #6 of 119 Old 08-12-2012, 05:18 PM Thread Starter
Sahara Surfer
I went ahead and cut off the rearmost frame body mounts and ground down the area flat. At this point, my buddy Josh showed up to lend me a much needed hand on the frame build.
For safety’s sake, we went ahead and removed the fuel tank and moved it outside away from the work area (It is very easy to drop the tank once the body is out of the way… it also helps if it is only ¼ full). We did not want to take the chance of blowing up the garage with all the sparks flying once the fuel lines were cut.
Next, we cut the exhaust muffler off (I am replacing my old beat up one), separated the brake lines, e-brake assembly, and cut the fuel lines with a pipe cutter (to avoid sparks with powered tool). Lots of rags will come in handy here.
We then removed all the remaining body mount bolts and carefully raised the body near the frame cut area to give us more clearance (You may need to loosen the fan shroud, we were able to carefully raise the tub just high enough to avoid doing this).
We then drilled some extra ½” plug weld holes. After careful measuring, this is where we decided to make our cut mark:
We are committed now!!!
Note the blue tape pieces on either side of the cut area. There are reference marks on both strips with a measurement written on them. This is very important later on when putting the frame extensions in. We took the original separation distance on the marks and added 15” to verify the proper final dimensions.
Poor Jeep! What have I done!!
We then beveled and squared the exposed edges to prepare them for the frame extensions.
post #7 of 119 Old 08-12-2012, 05:27 PM Thread Starter
Sahara Surfer
The inserts and extensions required a bit of hammering and some final grinding work to fit them in. At 8” long, we made sure to tack weld one of the plug weld holds on each insert once it was four inches in to avoid slipping.
Note that we had no temporary frame bracing to insure a square fit. In retrospect, we should have tacked on some scrap tube on either sides of the cut, but it turned out that my rear bolted tube bumper already kept things square on the back half and on the front half, things hardly shifted. All in all, everything lined up successfully for reattachment.
Once the proper weld gap spacing and proper dimensions were assured, we took some L2x3x3/8 angles and clamped them on to the extensions to insure a straight frame splice.
Plug weld holes filled. She is not going anywhere.
We ran out of daylight and decided this was a good time to stop and have a beer. My buddy Josh was a huge help and I owe him lots of beers for all of his great ideas and expertise in auto work. Sorry his wife will not be too happy with him for being away all day!
Anyway, that is what I have so far. The Jeep is still on jacks and it will remain on them until I finish the seam welds at the beveled joints and weld on the fish plates. With the back of the tub off and the fuel tank dropped, new ideas keep popping into my head... outboarding the shocks? Relocate the spring perches? The plan is to eventually go to 35's. Now would be a great time to swap out that D35... If money permits. For now, I am putting in new control arms, a OME 2.5" lift, and an SYE. I can see this taking me a long time to finish.
post #8 of 119 Old 08-12-2012, 05:34 PM
Sundowner
Nice work so far! Cutting roll bars is fun, isn't it?
Sundowner is offline
post #9 of 119 Old 08-12-2012, 05:52 PM Thread Starter
Sahara Surfer
Especially when you try to do it with a Sawzall. Darn blade jumped all over the place.
post #10 of 119 Old 08-12-2012, 06:07 PM
clintrivera
I'll be doing this in the winter. I'll be watching this build close for sure.
clintrivera is offline
post #11 of 119 Old 08-12-2012, 07:40 PM
Sundowner
I sliced mine with an abrasive steel blade in a skillsaw...and it worked about as well.
post #12 of 119 Old 08-12-2012, 09:03 PM Thread Starter
Sahara Surfer
You will probably finish before I do! My wife hates it when I go MIA in the garage for long periods of time. I see lots of flowers and foot rubs in my future!
Good luck with your future build and happy planning.
post #13 of 119 Old 08-12-2012, 09:04 PM Thread Starter
Sahara Surfer
HAHA! You do know!
post #14 of 119 Old 08-13-2012, 01:09 AM
4wheelrampage
Why buy an LJ when you can make one your self?
I love it and it is awesome. I will be noting this for possible future plans.
Originally Posted by ApolloXIII
Tasting a drop isnt going to kill you.
And what doesnt kill you makes you stronger.
Therefore, tasting a drop of antifreeze actually makes you stronger :)
Mac users : control+option+command+8
4wheelrampage is offline
post #15 of 119 Old 08-13-2012, 01:21 AM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
Love the custom work your doing but have one a question. Im not a CJ or LJ guy so i am unaware of the specifics but just from what ive seen it looks like your building a LJ. i know they both share an extended wheelbase and overall length but is there anything that your doing that makes it more like a cj-6? Or is it just a meme used instead of saying "custom LJ build"?
SEMPER FI
LifeProof is offline
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 10:59 PM
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 12:15 PM
JeepDVL45's 'Bruiser' Build -- A Daily Driver's slow build JeepDVL45 Jeep Builds 41 08-11-2011 10:44 AM
