AND Another LJ Rubicon Thread - Page 9 - JeepForum.com
post #121 of 276 Old 11-20-2013, 08:36 PM Thread Starter
OkLaHoMaTJ
Originally Posted by MWV247 View Post
I'll be doing a 14 bolt but it's going to be a long arm setup. IMO once you go over 4.5 inches you need a long arm. Couple that with the fact that the ring gear is huge on a 14 the only way to package it properly with the factory fuel tank is to have the ring gear shaved -that's probably why no one has done it. Might as well shave the housing as well while you're at it.
Thank you for your input. I want to keep my Currie 4'' coils so lift will remain the same…just some high lines and trim the rear up to fit 40's. The 14 bolt will get the ballistic fab shave and the fuel tank is getting moved back 4'' similar to the Daddy Longlegs Build. So that should be plenty of room to clear the 14bolt but I see what you're saying. Packaging, in stock form, with the 14 bolt would be tight if not impossible.
Rokmen does quite a few short arm Spider 9's and such. TNT does some trusses for the 78-79 Dana 60 that are bolt in for front suspension…but nothing really for the 14 bolt axle crowd.
My Thread - http://www.jeepforum.com/forum/f22/another-lj-rubicon-thread-1516486/
OkLaHoMaTJ is offline
post #122 of 276 Old 11-20-2013, 08:42 PM
g-rocc
This is going to be something I'm highly interested in.
g-rocc is offline
post #123 of 276 Old 01-10-2014, 07:11 PM Thread Starter
OkLaHoMaTJ
Well…Yukon 5.13's are ordered.
Thanks goes out to G-Rocc and GBeasley here for answering some questions.
post #124 of 276 Old 01-10-2014, 07:42 PM
AngryTJ
Wait..your jumping up to 40s?
AngryTJ is offline
post #125 of 276 Old 01-10-2014, 07:45 PM Thread Starter
OkLaHoMaTJ
Oh no. 37'' Goodyear MTR/K's and RCV's. 17's. Preferably bead locks. Trying to find some deals.
post #126 of 276 Old 01-10-2014, 08:51 PM
G Beasley
Drove mine home with the 5.13s tonight and it was awesome . I think 37s will be perfect with the 5.13s on your LJ . Did you go with standard gears or JK's ?
G Beasley is offline
post #127 of 276 Old 01-10-2014, 09:41 PM Thread Starter
OkLaHoMaTJ
I went with the standard TJ gears.
Good to know about the gears G. I think you said the jeep was running around 2750rpm @ 65mph. So you think 3000 @ 70? On 35s.
post #128 of 276 Old 01-10-2014, 10:38 PM
g-rocc
Good choice bud. You won't be disappointed and I don't think you will have a time when you wish you had lower gears.
g-rocc is offline
post #129 of 276 Old 01-11-2014, 07:32 AM
G Beasley
I think thats probably about right , but I havent had it that fast yet .
post #130 of 276 Old 01-11-2014, 01:39 PM Thread Starter
OkLaHoMaTJ
Set to go next Friday. I'm going to drop it off and then go snowboarding that weekend. Should be ready by Monday.
post #131 of 276 Old 01-11-2014, 07:57 PM
G Beasley
Hopefully you are as surprised by yours as I was by mine .
post #132 of 276 Old 01-18-2014, 05:46 PM Thread Starter
OkLaHoMaTJ
Dropped the jeep off last night. Yukon 5.13's and master install kits. Next up are the RCVs.
I'll post my impressions as soon as I get the jeep back.
post #133 of 276 Old 01-18-2014, 06:25 PM
G Beasley
As long as you dont get in a hurry you are going to love it . I wish I had gone to RCV's when I had the chance ...
post #134 of 276 Old 01-19-2014, 07:37 AM
g-rocc
Don't get too anxious and make sure you do a good break in. I know it really sucks but it's worth it like a secondary tempering.
g-rocc is offline
post #135 of 276 Old 01-19-2014, 08:58 AM Thread Starter
OkLaHoMaTJ
Since it's off season for me, the Jeep is driven around town. I will rarely exceed 65mph around where I live. So the RPM's are not much of an issue at the moment. Once the snow melts though, 70mph on the highway's is pretty norm in some instances.
g-rocc what break in procedure did you follow?
