AND Another LJ Rubicon Thread - Page 6 - JeepForum.com
post #76 of 276 Old 09-09-2013, 09:19 PM Thread Starter
OkLaHoMaTJ
You standing on Cleveland Rock gives a good perspective of its size
I'm 6'2'' and 215lbs just to put things into perspective. I don't have the intestinal fortitude to hit that wall.
Originally Posted by Moabrubi View Post
Hmm. Don't think my SWB TJ would stand a chance on Cleveland rock.
Stretch Jeep to 110" before Colorado trip, check.
Some of the guys I wheel with saw a 103'' wheelbase LJ doing it last year. I couldn't even imagine doing it in mine. It's a make it or roll it deal from the looks of it. If you slide left or right..you're dumping it.
My Thread - http://www.jeepforum.com/forum/f22/another-lj-rubicon-thread-1516486/
OkLaHoMaTJ is offline
post #77 of 276 Old 09-10-2013, 09:35 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Awesome Trail shots. That is how all trails should be explained. And if I ever get out there, you could probably talk me into trying Cleveland Rock with a good spotter and a lot of winches on hand to save my a**
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #78 of 276 Old 09-10-2013, 10:57 AM Thread Starter
OkLaHoMaTJ
If it was dry...I may have put the front end up on it but I doubt my rig could drive it.
You have to fully commit once the front tires hit the slab.
post #79 of 276 Old 09-10-2013, 12:56 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Only two answers after you commit... make it or not.
16 Taco
dayriesw is offline
post #80 of 276 Old 09-10-2013, 02:15 PM Thread Starter
OkLaHoMaTJ
Very true! I would feel safer with a better cage and no doors or top just in case the Jeep did go over.
post #81 of 276 Old 09-10-2013, 04:43 PM
g-rocc
Great pics. I love Holy Cross trail. The first time I saw Cleveland Rock I looked at it and just said no. The second time I drove it up the right side but it is a monster.
g-rocc is offline
post #82 of 276 Old 09-10-2013, 05:48 PM
G Beasley
Theres lots of cage builders near you ....
G Beasley is offline
post #83 of 276 Old 09-10-2013, 08:22 PM Thread Starter
OkLaHoMaTJ
I would try the right side if it were dry. Wet seems impossible.
Thinking about a Poly Performance cage down the road. First its getting gears and RCV's. Once the 35's sell, I'll find some 37's and some 17'' wheels.
Then I can't stop thinking about going either 2 routes with the Jeep.
1. Rock Krawler 4'' stretch long arm.
2. Genright/Poly 3/4 link long arm and modular under armor.
post #84 of 276 Old 09-15-2013, 03:37 PM Thread Starter
OkLaHoMaTJ
I've been looking at going with a hood hoop in the front and can't find anything that will work.
Mainly looking for something that will bolt on top of the Savvy front bumper. Any thoughts?
post #85 of 276 Old 09-15-2013, 03:50 PM
Moabrubi
I doubt you will find something that will bolt onto the Savvy bumper. All the ones I've seen weld on.
Are you tying it into anything or just adding the hoop? I don't think those hoops really prevent any damage by themselves.
Moabrubi is offline
post #86 of 276 Old 09-15-2013, 03:50 PM
IEcrawlerTJ01
I don't know of a bolt on one. But lots of places like genright and bluetorchfab sell pre bent hoops that could easily be welded to a flat plate with some holes that could bolt onto a couple of the factory frame bolts
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #87 of 276 Old 09-15-2013, 06:03 PM Thread Starter
OkLaHoMaTJ
I know Currie and Genright use to make one that used the winch mounting holes in the frame.
I'm not tying anything into it. As far as looks goes, yeah it does look good and I hope I never use it. It's kinda like a very nice roll cage. I hope I never have to use it.
That's what I was thinking. The pic of the Jeep that I posted has his hoop welded to his winch plate.
Old currie design http://www.quadratec.com/products/12056_202.htm
post #88 of 276 Old 09-15-2013, 10:01 PM
G Beasley
If you cant find what you want I could bend you one up and weld tabs on the bottom . You would then drill the holes and bolt it to your frame.
post #89 of 276 Old 09-15-2013, 10:22 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
If you cant find what you want I could bend you up one up and weld tabs on the bottom . You would then drill the holes and bolt it to your frame.
I wouldn't mind taking you up on that. Okla, he does pretty nice stuff.
16 Taco
dayriesw is offline
post #90 of 276 Old 09-16-2013, 08:00 AM Thread Starter
OkLaHoMaTJ
G I might take you up on that.
Shop you a PM. I'd like to see something like the Currie design that uses the existing frame bolts and possibly allow the factory tow hooks and fog lamps. I know...it's getting crowded in that area.
