Another 5.2L YJ thread - Page 11 - JeepForum.com
post #151 of 231 Old 08-03-2013, 07:45 PM
Chris
Guy with jeep
Chris's Avatar
I will donate a wrench and a swift kick in the ***!
Chris is offline
post #152 of 231 Old 08-03-2013, 09:55 PM Thread Starter
Xpress
Sweet a free wench! Anyone else?
All about that unibody life.
Xpress is offline
post #153 of 231 Old 08-03-2013, 11:06 PM
19Mike95
You help put a 4bt in mine ill help with yours rofl
19Mike95 is offline
post #154 of 231 Old 08-04-2013, 12:12 AM
caoboy
Originally Posted by mike_breaker_5 View Post
you can run an auto ecm on a manual and vice versa.
obd1 ... if you put an auto ecm on your manual all that happens is the air fuel mixture is a little diff to compensate for having a torque converter.
i ran an auto ecm with no problem for a while on my 5.2 before switching to the 5.9l manual ecm on my 5.2. hell... i even ran an auto 3.9l ecm on my 5.2 for about 1/4 mile. guy i bought it from said it was for a 5.9 not a 3.9. i quickly notified him of his mistake.
obd2...
not 100% positive but i think it is a possibility to put an auto ecm on a manual if you do something to trick the computer to think the transmission is always in drive. otherwise the ecm thinks your in park all the time and you have a terrible power loss. i know i read this somewhere on someone's swap thread but i can't remember for the life of me who it was or how he "tricked" the ecm.
The issue with California C.A.R.B is that the ECU has to be the same as the transmission. You can't jerry rig anything, all emissions equipment has to be there and working, as it as from factory, from the original vehicle.
caoboy is offline
post #155 of 231 Old 08-04-2013, 03:55 AM
mike_breaker_5
i wanna know how they are going to tell that it's an auto or manual ecm?most inspection places around here(PA) barely know how to operate a pen, nuch less tell if all pieces of a vehicle are stock.
besides... i wasn't talking about the 50 state legality of it, that's for whoever to figure out, i was speaking from the physical possibility of the matter.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #156 of 231 Old 08-04-2013, 08:22 AM
caoboy
They hook into the obd2 port and also physically check it. They comb the motor. They want you to pass, so even if you do fail, they show you what you need to do to fix it.
caoboy is offline
post #157 of 231 Old 08-05-2013, 11:05 PM Thread Starter
Xpress
Well that is reassuring, though I think I can do it right the first time. Do they charge to do a re-test?
Xpress is offline
post #158 of 231 Old 08-06-2013, 06:11 AM
caoboy
Call your local CARB ref and ask, its been a while since I've used them, and idk if it is different for a truck. Chat them up, let them know what you want to do. Theyll give you info you need to know.
caoboy is offline
post #159 of 231 Old 08-06-2013, 06:19 AM
mike_breaker_5
step one, move out of communist California.
step two, start your motor swap.
post #160 of 231 Old 08-06-2013, 07:39 AM
remmons
I Have nothing against California, other than the strictness of their emissions regulations, but I can see why they have them.
Robert.
remmons is offline
post #161 of 231 Old 08-06-2013, 07:49 AM
Chris
Guy with jeep
Chris's Avatar
There is no reason for failing people over a visual inspection. If you motor is putting out the correct numbers it should matter how you have it set up.
Chris is offline
post #162 of 231 Old 08-06-2013, 11:21 AM Thread Starter
Xpress
No. I will start it when I damn well please
Xpress is offline
post #163 of 231 Old 08-06-2013, 12:26 PM
remmons
Robert.
remmons is offline
post #164 of 231 Old 08-06-2013, 01:18 PM
DLWRUBI
Couldn't agree more. The only thing they should care about smog wise, is the emissions coming out the tailpipe.
DLWRUBI is offline
post #165 of 231 Old 08-06-2013, 02:17 PM
remmons
They do sometimes check for smog equipment to see if it is intact, i.e. a Catylitic Converter. But, they wouldn't know what to check for in an A.I.R. Injection system due to the many types that are installed on the many brands of vehicles, or if the PCM (ECM) is the proper unit for the vehicle.
Robert.
remmons is offline
