AngryTJs Taranchula Rubicon Build - Page 94 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > AngryTJs Taranchula Rubicon Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGrizzly Lockers available at Rockridge4wd.comThe ULTIMATE "Selectable" Locker System! Brough
Unread 12-16-2012, 01:02 PM   #1396
AngryTJ
Originally Posted by mbporesky
Are you going to 4 link it? why not just do a 3 link. Or is the blue links just showing each side
I already 4 linked i just never put my measurements in the calculator to see my numbers
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
My Rubicon build[/B][/SIZE][/URL]
[URL="http://www.jeepforum.com/forum/f345/jf-trip-2-0-a-2608114/"][SIZE="3"][B]
2015 Colorado Trip[/B][/SIZE][/URL]
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 12-16-2012, 04:18 PM   #1397
Hendrix
TJOTY 2013
Hendrix's Avatar
I believe that's the rear, 3 link rear would just be crazy.
The CG looks high if that is 34
Hendrix is offline   Reply With Quote Quick reply to this message
Unread 12-16-2012, 07:06 PM   #1398
AngryTJ
It is the rear. Didn't really know where to measure for CG, any recommendations?
Unread 12-16-2012, 07:16 PM   #1399
Hendrix
TJOTY 2013
Hendrix's Avatar
I use the bell housing bolt that is above the starter.
Unread 12-16-2012, 07:23 PM   #1400
AngryTJ
Ill have to double check all my measurements. By lowering the CG it makes my antiquat # jump way up.
Unread 12-16-2012, 08:03 PM   #1401
Holaday
Where is this? Can I go wheeling with you guys next summer?
Holaday is offline   Reply With Quote Quick reply to this message
Unread 12-16-2012, 10:32 PM   #1402
AngryTJ
you mean this place?
Rausch Creek, PA
This video is muted so dont think your speakers are broke.
Unread 12-18-2012, 02:17 PM   #1403
mbporesky
Its the rear.... That explains it.
If it aint broke, fix it till it is.
mbporesky is offline   Reply With Quote Quick reply to this message
Unread 12-20-2012, 10:00 AM   #1404
AngryTJ
Updated measurements I believe are more accurate...
How do you post the 4 link calculations? This cell pic will have to do for now
Unread 12-20-2012, 10:12 AM   #1405
Imped
Imped's Avatar
Save it, select the cells you want to copy and paste it into paint. Save that file as a JPG and upload it to your host site like Photobucket. I changed a couple things and hosted the pic to my PB account so here you go.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 12-20-2012, 10:27 AM   #1406
AngryTJ
Ahh ok that makes sense.
So I'm new to the whole calculator thing but how does it look? Why does yours have a static antisquat?
Unread 12-20-2012, 11:01 AM   #1407
Imped
Imped's Avatar
You're using the same version I am. No idea why mine is labeled 'static' and yours isn't. Regardless of the label, the number is representing the exact same thing.
The changes I made and why:
1) Bumped up the veritical separation at the frame by lowering the lower frame mount 1". That brought the AS down and moved you from an oversteer to a very slight understeer situation. Much more desirable.
2) Moved the upper frame mount back a bit to give the upper and lower links a closer effective length.
I think that's a good plan to move forward from.
OlllllllO
Float Test Build
IndyORV
Unread 12-20-2012, 01:20 PM   #1408
AngryTJ
That all makes sense until your last sentence. My rear 4 link is already complete I just wanted to plot my measurements and see what the values came out as. Dont know if you recall but I used the poly brackets on the frame side so my uppers and lowers are roughly on the same plane therefore the upper mount cant be moved back. Im not 100% sure all the measurements are accurate but fairly close.
Heres how the values will be affected with a 5in stretch.
Unread 12-20-2012, 01:42 PM   #1409
Imped
Imped's Avatar
Yes, I know you're already 4 linked. What I meant was if you plan on making any changes to the mounts or wheelbase in the future you're in good shape as it sits.
OlllllllO
Float Test Build
IndyORV
Unread 12-25-2012, 11:05 AM   #1410
AngryTJ
Merry Christmas everyone! Have an amazing day and I hope everyone got what they wanted
