AngryTJs Taranchula Rubicon Build - Page 60 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > AngryTJs Taranchula Rubicon Build
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 05-17-2012, 10:38 AM   #886
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Originally Posted by KevKaos View Post
That's not hard to do with Lu's thread. He's throwing money at his rig like its a high class call girl.
HEY!! ..... She makes me feels special
AngryTJ is offline   Reply With Quote
Unread 05-17-2012, 12:19 PM   #887
KevKaos
I bet she does. hehehe
Are you planning on using a Speedohealer or anything to get your speedo back in synch after doing the bigger meats? I'm like 3mph off at highway speed with my 33s.
[SIZE="4"]KevKaos[/SIZE]
[SIZE="4"]Honey Badger Wheelin'[/SIZE]
[FONT="Arial Black"][SIZE="5"][COLOR="Red"]RED JEEP CLUB # 621[/COLOR][/SIZE][/FONT]
It's not much, but check out my build thread;
[url]http://www.jeepforum.com/forum/f22/kevkaoss-05-red-rubicon-build-thread-1170741/[/url]
[QUOTE=krashnpa;12397572] I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.[/QUOTE]
[QUOTE=squazz;13612008]so I use my original nuts?[/QUOTE]
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline   Reply With Quote
Unread 05-17-2012, 01:05 PM   #888
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
I have a programmer so Yeah I corrected the speedo in relation to the tire size Im running
Unread 05-17-2012, 01:29 PM   #889
KevKaos
So what are you using to do that? I was looking at the SpeedoHealer, but you have a programmer that does more? I dont remember reading about it in your thread.
Unread 05-17-2012, 01:36 PM   #890
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Im using a Superchips Jeep Programmer. It allows me to program for tire size change, gear ratio, better gas mileage, read check engine lights, 4hi locker mod and other shiznit.
Off topic are those alloy axle seals you have still causin issues?
Unread 05-17-2012, 08:11 PM   #891
KevKaos
Yeah! I hate them. Maybe if I had read that you can use form a gasket to keep them in place, I would feel better about them.
Unread 05-20-2012, 07:03 PM   #892
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Got started tearing down the rear suspension to start my 4link.
Few before shots:
Stripping down and removing the rear axle:
Cutting and Grinding (not the final product) Such a b*itch
So worked for about 5 hours and we got the axle out, frame lower control arms brackets cut off, all brackets on the axle cut off and ground down, trac bar bracket cut off, and started to cut the upper spring perch.
Im happy with that progress, anyone have any tips on how to cut the spring perches on the inside of the frame!?
Unread 05-20-2012, 08:46 PM   #893
KevKaos
You put those axle tube caps on yet? We took mine off today, and you should see what happens to them when they spin in the tube like mine did. I'll have to get a pic up so you can see them.
Now about tops. I know you said that you got a Rampage, and I saw pics of it. And I know you said you like it. Are there any cons in your opinion? I gashed my top on a tree while doing an off camber section,mso I need a new top. Do you still have to se the door surrounds? One got a little piece broken off, but I can fix that. I really thought I would have more time to figure out what top to get, but such is Honey Badger wheelin.
You ever sell that Novack shifter? Looks like I might have to do one of those as well. My linkage is all F'd up. At least that all I hope is wrong with the Transfer Case.
Unread 05-20-2012, 09:30 PM   #894
Driver831
Too bad you don't have a torch, would make a lot less grinding too. looks good tho!
Driver831 is offline   Reply With Quote
Unread 05-20-2012, 10:23 PM   #895
MO2500
Fabramicator
MO2500's Avatar
Lu, when I removed my spring perches, I just cut the outside welds and then beat on them with a BFH back and forth until I broke the welds on the inside of the frame rail. Are you re-using the perches or replacing them with aftermarket?
My Jeep Build
Useful tech links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is offline   Reply With Quote
Unread 05-21-2012, 04:56 AM   #896
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
For the top you need door surrounds, windshield header and tailgate retainer.
Extra Novak shifter I had is long gone.
I wish. Thanks
Planning to reuse them
Unread 05-22-2012, 06:11 PM   #897
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
About time
Unread 05-22-2012, 06:57 PM   #898
MO2500
Fabramicator
MO2500's Avatar
You ended up switching to the discovery shafts right?
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 05-22-2012, 07:44 PM   #899
bobthetj03
bobthetj03's Avatar
Dang! You ain't messing around! Way ta jump right in to it!
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
bobthetj03 is offline   Reply With Quote
Unread 05-22-2012, 07:51 PM   #900
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Yeah still got the chromoly ujoint but went with Discovery shafts since there was no timetable for the evolution.
Yeah man its finally time. Cant wait till its done!
