AngryTJs Taranchula Rubicon Build - Page 202 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > AngryTJs Taranchula Rubicon Build
Engo LED Flush Mount Lights *PAIR* Flood or Spot 1,600 LumYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 07-17-2014, 10:10 AM   #3016
duc202
I can see what I have going on around that time and try to meet you guys there Lou if that's possible. hopefully i'll have everything installed on my jeep by then
duc202 is offline   Reply With Quote Quick reply to this message
Unread 07-17-2014, 01:48 PM   #3017
AngryTJ
sounds good... I still have plenty to get done on my rig but Ill just finish the mandatory items to finally get out this year and wheel
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
My Rubicon build[/B][/SIZE][/URL]
[URL="http://www.jeepforum.com/forum/f345/jf-trip-2-0-a-2608114/"][SIZE="3"][B]
2015 Colorado Trip[/B][/SIZE][/URL]
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 07-17-2014, 06:09 PM   #3018
Driver831
Id wheel with you.. but my AC isn't working up to par... and you are a few country miles away from me
Follow on Instagram kids! @ Driver831
Driver831 is offline   Reply With Quote Quick reply to this message
Unread 07-17-2014, 07:18 PM   #3019
TURBevO8
August 23rd could work. Thought you meant July 23rd. Skimmed too fast.
2006 Impact Orange TJ X
2004 Apex Silver EVO VIII GSR
TURBevO8 is offline   Reply With Quote Quick reply to this message
Unread 07-18-2014, 03:05 AM   #3020
GregStephens2
Originally Posted by janesy86 View Post
I really want to make this since I got your text last night... I'll have to keep on my buddy. I really don't want to make the drive in the Jeep if I don't have to.
Yup my next major purchases are a trailer and truck.
Anyway she's all fixed and I was back up there last weekend
Greg Stephens/Arboreal Specialties
http://www.arborealspecialties.com/Home.html
GregStephens2 is offline   Reply With Quote Quick reply to this message
Unread 07-18-2014, 03:14 AM   #3021
GregStephens2
Earlier that same day on tombstone.........
Unread 07-18-2014, 09:31 AM   #3022
TURBevO8
That rear axle bearing looks like mine about 2 months ago. Did you get all the metal out of the housing? I did the best I could with a magnet and brake cleaner. Then installed a mangetic fill plug from Dimple.
Unread 07-18-2014, 09:33 AM   #3023
Tommy R
So where's the pics showing off the newly revamped, pimptastic wheels?? Inquiring minds wanna know!
2001 Wrangler - homemade long arm, 4.56s, 35" MTRs, D30/Lock Right/alloys, D44/ARB/35 spline alloys
My Jeep Build Journal
Tommy R is offline   Reply With Quote Quick reply to this message
Unread 07-18-2014, 09:45 AM   #3024
AngryTJ
might be a small drive for you
Yikes
Pics will be posted once all 4 are mounted.
Unread 07-18-2014, 10:12 AM   #3025
GregStephens2
Yikes is right!
Yes we had to pull the carrier and duech it all out.
Fwiw I am now a perminate Yukon gear fan the zip locker held up perfectly even seeing that the axle break cracked the drivers side carrier bearing.
Unread 07-20-2014, 09:04 PM   #3026
G Beasley
If my job ends in time I would love to head North and wheel with you again , especially as I am missing the Rubicon ...
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 07-21-2014, 08:57 AM   #3027
HellaTJ
Great build!
HellaTJ is offline   Reply With Quote Quick reply to this message
Unread 07-21-2014, 01:52 PM   #3028
dayriesw
dayriesw's Avatar
That is a trail fix. No need for a truck and trailer....
Impact Orange LJ - DD...sitting low, flat bottomed, fully armored and locked on 37s
Jeep-Owners.com
LouisianaOffroad.com
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 07-21-2014, 04:07 PM   #3029
GregStephens2
Maybe for you..... I had the axle, gear oil and tools but no carrier bearing. And I don't trust myself to get the carrier out and in.
Unread 07-21-2014, 04:12 PM   #3030
GregStephens2
Fwiw the splines were stuck in the carrier and had to be beat out after it was removed. Bearings on the carrier fell apart as we pulled it out.
