AngryTJs Taranchula Rubicon Build - Page 195 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > AngryTJs Taranchula Rubicon Build
Bill Baird Motorsports DIY parts - NalinMFG.comFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 04-27-2014, 11:51 AM   #2911
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Originally Posted by TURBevO8
That's cool. I think I know how I'm gonna do it now. I almost did something really dumb. Good thing I thought about if before welding. At his point I'm really more interested in how you routed the fuel lines. Thanks!!
You're on the right track, loosening the body mounts and lifting the body up will allow access. It looks like a hard bead to run but it's actually not bad. The inverted welding will be much more difficult at the novice level.
gst95dsm is offline   Reply With Quote
Unread 04-27-2014, 12:30 PM   #2912
aw12345
There is enough room to weld as is, just takes a bit of creative positioning of the gun. Welded everybit of suspension under mine without lifting the tub.
Now welding the exhaust in was more adventure some.
Come Y'all and enter, make this the best contest yet!
http://www.jeepforum.com/forum/f9/february-tj-month-contest-submit-now-2061065/
aw12345 is offline   Reply With Quote
Unread 04-27-2014, 04:26 PM   #2913
TURBevO8
Originally Posted by aw12345
There is enough room to weld as is, just takes a bit of creative positioning of the gun. Welded everybit of suspension under mine without lifting the tub. Now welding the exhaust in was more adventure some.
Once I seated the bracket against the frame rail I realized what I was thinking the other day when I posted here was not an issue. Today I fiddled around and now know how I'm gonna weld and run the lines. The overhead welds I did on my frame notch came out well so I think I'll be ok. I'd same I'm at the intermediate level. Haha
So I got the routing of the lines figured out but not sure how I want to secure them. Suggestions??
Am I hijacking your thread? Should I move this conversation to mine?
2006 Impact Orange TJ X
2004 Apex Silver EVO VIII GSR
TURBevO8 is offline   Reply With Quote
Unread 04-27-2014, 05:20 PM   #2914
aw12345
You can use P style clamps or the stock clamps just bend a strap and weld it to the frame and shove the plastic clips that secure the OEM lines under the strap.
Unread 04-27-2014, 06:09 PM   #2915
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Once I seated the bracket against the frame rail I realized what I was thinking the other day when I posted here was not an issue. Today I fiddled around and now know how I'm gonna weld and run the lines. The overhead welds I did on my frame notch came out well so I think I'll be ok. I'd same I'm at the intermediate level. Haha So I got the routing of the lines figured out but not sure how I want to secure them. Suggestions?? Am I hijacking your thread? Should I move this conversation to mine?
I was able to just move the lines and use the same clamps. No worries
AngryTJ is offline   Reply With Quote
Unread 05-02-2014, 11:13 AM   #2916
TURBevO8
Going to outboard my shocks tonight after work. 2 questions please....
1. Did you set your frame shock towers normal to your lower links at ride height (as opposed to vertical or some other angle)?
2. Did you set your Poly axle shock mounts parallel to your lower links (normal to your towers)?
Thanks!
Unread 05-02-2014, 11:54 AM   #2917
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Thanks!
The shock towers themselves I set with the jeep sitting on its own weight at roughly a 90* angle from the lower arms.
Depending what length shocks you will be using you then need to set your tower and your lower mounts appropriately to maximize travel.
ie. With the jeep sitting at ride height while using 12" shocks I set the tower and the axle mount to show 6" of shaft allowing for 6 up and 6 down.
Granted I dont get that sort of uptravel right now but thats because Im hitting my crossmember with the axle truss which will be addressed.
Nonetheless try and keep your axle mount parallel to the ground and out of the rocks.
Unread 05-02-2014, 01:28 PM   #2918
TURBevO8
Here is what I was planning to do...my lower arm hits my frame which is what sets my up travel (theoritically...I doubt the coil can even compress that much). I was going to use this to set how high to mount the shock on the frame, and add 1/4-1/2" so the shock never bottoms out. The shock lenght will determine droop. I went with 11" shocks in case I ever want to go a tad higher. I may need coil retainers. We shall see. As for the axle brackets, my initial thought was to do what you said for ground clearance. But won't the shock bind if the axle mount bolt is not parallel to the frame tower bolt? I guess it depends on how much play there is in the rubber bushings. I will have to play around with this and see what I have to work with...thanks for the response.
Unread 05-15-2014, 09:25 AM   #2919
bobthetj03
bobthetj03's Avatar
I hear crickets chirping over here! You get those new tire installed yet?
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
bobthetj03 is offline   Reply With Quote
Unread 05-15-2014, 10:37 AM   #2920
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
maybe...maybe not
Unread 05-15-2014, 12:35 PM   #2921
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
To answer your question though no the new tires have not been mounted.
No real progress has been made since all my time is spent renovating my house so I can move in.
Potential for some real goodies soon though
Unread 05-15-2014, 03:21 PM   #2922
navman
You gonna finish before me? lol
95 YJ 5.0 linked etc
http://www.jeepforum.com/forum/f22/m...-build-931241/
navman is offline   Reply With Quote
Unread 05-15-2014, 06:31 PM   #2923
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
The jeep or a house Reno?
Unread 05-21-2014, 05:24 PM   #2924
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Finally had some garage time
Untitled by lverdura28, on Flickr
Unread 05-21-2014, 05:34 PM   #2925
awinski
new tires?
one more horse power than the average pentastar [url]http://www.jeepforum.com/forum/f22/plus-1-horse-power-after-build-2157673/[/url]
twitter/IG - @Becauseracejeep
awinski is offline   Reply With Quote
