AngryTJs Taranchula Rubicon Build - Page 177 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > AngryTJs Taranchula Rubicon Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRubicon Express Suspensions from CCOR 706-207-4140Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955
Unread 01-17-2014, 08:17 AM   #2641
janesy86
Gotta be Fresh
janesy86's Avatar
Lou, I think I remember you getting some UCF windshield guards... Did you ever mount them up? Curious on the fitmet. I want to get some to protect the replacement windshield frame I'm picking up this weekend to prevent what happened to my current one.
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
Hylined '03 Rubi Build
Western MA 4x4
janesy86 is online now   Reply With Quote
Unread 01-17-2014, 09:14 AM   #2642
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Yes they are mounted, fitment was good however hardware included sucked so I purchased some button head bolts to use instead.
I also grinded off the weld that shows on the surface
AngryTJ is offline   Reply With Quote
Unread 01-18-2014, 06:59 PM   #2643
aw12345
Here's something to think about, denting the windshield frame is not desirable. But with armor plating on the sides the change that you kitty corner it is much greater and that's pretty much the end of your wind shield and the frame
aw12345 is offline   Reply With Quote
Unread 01-19-2014, 06:58 AM   #2644
dayriesw
dayriesw's Avatar
If you don't want to hit the windshield frame, fold it down or remove it.
Impact Orange LJ - DD...sitting low, flat bottomed, fully armored and locked on 37s
dayriesw is online now   Reply With Quote
Unread 01-19-2014, 07:08 AM   #2645
purplepig
purplepig's Avatar
Or you put it on to cover the damage that is already there.
purplepig is offline   Reply With Quote
Unread 01-19-2014, 08:07 AM   #2646
janesy86
Gotta be Fresh
janesy86's Avatar
Thats ultimately what I plan on doing for some of the more hardcore trails. Drill out the hinge and put in something like a hitch pin.
Current frame is just too beat up and would need too much time to get it right to even fit the armor...
Western MA 4x4
Unread 01-19-2014, 08:11 AM   #2647
dayriesw
dayriesw's Avatar
If that's the case, look into a 97-02 frame due to much less trim that won't have to be removed from the frame every time you fold/remove it. Imped did the swap I believe. I want to cut off the pins and put a quick release piece for the frame. One day....
Unread 01-19-2014, 09:04 AM   #2648
OkLaHoMaTJ
Angry I think you can trim the Savvy UA pieces to fit around your body mounts. Just a though. I too like the idea of being able to drop the skid and have a separate crossmember holding up the drivetrain.
I do agree with you about the MML tho. In order to use the engine skid you have to use the Savvy MML. Kinda sucks and I wonder if there is a way to get around that?
My Thread - http://www.jeepforum.com/forum/f22/another-lj-rubicon-thread-1516486/
OkLaHoMaTJ is offline   Reply With Quote
Unread 01-19-2014, 01:51 PM   #2649
janesy86
Gotta be Fresh
janesy86's Avatar
Just picked up a mint 97-02 frame. Will swap out once I do the cage...
Thats what I plan to do once I do the raised body mounts. Shouldn't be to hard, just a little trimming. Could even weld on the outer pieces too Really they don't have to come off unless you want to take the whole enchilada off.. As for MML, just come up with your own brace mount, shouldn't be too hard with some steel and a welder.
Western MA 4x4
Unread 01-19-2014, 06:44 PM   #2650
aw12345
You don't drill the pins, just cut between the slots of the hinge then drive the outer part of the pins outwards. 7/16" bolt fits it perfect
Unread 01-20-2014, 05:07 AM   #2651
janesy86
Gotta be Fresh
janesy86's Avatar
Thanks bud, haven't seen any info so that helps.
Western MA 4x4
Unread 01-20-2014, 07:56 AM   #2652
dayriesw
dayriesw's Avatar
That is the process I have seen. Just cut one of the bolt's flanges off and drive it out. Then get a long shafted 7/16, cut the threads off, drill through the center for a pin and done.
Unread 01-20-2014, 08:55 AM   #2653
aw12345
actually the hinge has 2 pins in it that are serrated right behind the head. So what you want to do is cut both pins in the slots of the hinge.
then you can drive the remainder of the pins outwards. You don't have to bother with locking the replacement pin the windshield rubber puts pressure on the frame when bolted in place which retains the pivot pins nicely.
Unread 01-26-2014, 06:15 PM   #2654
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Finally in her new home
Untitled by lverdura28, on Flickr
Unread 01-26-2014, 06:38 PM   #2655
Shobes
Originally Posted by AngryTJ
Finally in her new home Untitled by lverdura28, on Flickr
Awesome man! Congrats! Good looking man cave
My "hard way" build - http://www.jeepforum.com/forum/f22/t...d-way-1483373/
Shobes is offline   Reply With Quote
