AngryTJs Taranchula Rubicon Build - Page 174 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > AngryTJs Taranchula Rubicon Build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueECGS DOTW - $100 off Yukon 8.8 C-Clip Eliminator KitNitro Gear Packages Now Available at Rockridge 4wd
Unread 12-20-2013, 02:44 PM   #2596
Lemmiwinks
You should also check out JonFund
Lemmiwinks is offline   Reply With Quote
Unread 12-21-2013, 02:52 PM   #2597
TURBevO8
This may be a bit off topic but a few pages back I saw you guys talking about high line washer bottle options. For those it may help, I used the one below and it works amazingly well!
link:
http://store.amequipment.com/15l-was...-12v-p-73.html
pics:
http://www.jeepforum.com/forum/f9/ge...02/index8.html
2006 Impact Orange TJ X
2004 Apex Silver EVO VIII GSR
TURBevO8 is offline   Reply With Quote
Unread 12-23-2013, 04:14 PM   #2598
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
I have looked into them as well as ronin wheelers
Originally Posted by TURBevO8
This may be a bit off topic but a few pages back I saw you guys talking about high line washer bottle options. For those it may help, I used the one below and it works amazingly well! link: http://store.amequipment.com/15l-was...-12v-p-73.html pics: http://www.jeepforum.com/forum/f9/ge...02/index8.html
Thanks for the added info!
Don't forget to go over and vote for tjoty guys and gals. The contest is coming to an end very soon.
AngryTJ is online now   Reply With Quote
Unread 12-25-2013, 07:35 AM   #2599
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Merry Christmas everyone!
Unread 12-25-2013, 08:09 AM   #2600
G Beasley
Merry Christmas to you and yours .
G Beasley is offline   Reply With Quote
Unread 12-25-2013, 01:07 PM   #2601
aw12345
helldorado21 by aartjestaartje, on Flickr
aw12345 is online now   Reply With Quote
Unread 12-25-2013, 04:54 PM   #2602
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Originally Posted by aw12345
Merry Christmas guys!
Unread 12-26-2013, 10:22 AM   #2603
Sarge30
Lou..
Just spent past few days reading your build. Came a long way in past few years. I see you have the Riddler diff covers. Did you have any issues with the front one hitting the trackbar? All the threads I have read, it will hit. Anything you did special? I see you have the JKS trackbar and the Currie steering. Thanks,
Sarge30 is offline   Reply With Quote
Unread 12-26-2013, 10:32 AM   #2604
gspup
Originally Posted by Sarge30
Lou..
Look at the Barnett diff cover. That's what I'll be buying.
gspup is offline   Reply With Quote
Unread 12-26-2013, 10:41 AM   #2605
janesy86
Gotta be Fresh
janesy86's Avatar
I love mine! Beefy where it needs to be, excellent clearance.
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
Hylined '03 Rubi Build
Western MA 4x4
janesy86 is offline   Reply With Quote
Unread 12-26-2013, 12:39 PM   #2606
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Originally Posted by Sarge30 View Post
Lou..
Sarge with your 4.5" springs you should have no issues. When I had my 4" zone springs I did not interfere with the riddler at all.
Now that I've dropped in ride height I notice it has scrapped it very lightly but I plan to address that this winter by seeing if anything needs to be adjusted or simply grinding down that spot a little.
Also thanks for taking the time to read through
Unread 12-26-2013, 02:24 PM   #2607
MO2500
Fabramicator
MO2500's Avatar
If it will hit with less lift it will hit with any amount of lift, spring height doesn't make things clear. You have to pull the springs and soft rubber from the bumps and cycle everything to see clearance issues as sometimes higher ride height will hide a problem until you put the suspension in a certain situation and the clearance issue shows itself. Longer bump stops can prevent clearance issues but we all know we want the least amount of bump possible to achieve better uptravel numbers so it's not always the best solution.
My Jeep Build
Useful tech links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is offline   Reply With Quote
Unread 12-26-2013, 02:34 PM   #2608
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Interesting...must have been the bumps I adjusted rather then the spring swap that caused the rubbing. Huh
Unread 12-26-2013, 10:15 PM   #2609
Sarge30
I've read with 2" bump you should be fine. I then saw you reduced your lift and figured you would have adjusted your bumpstops not to loose travel. To make things easier, I will probably just go with the Barnett cover. I first need to check my caster as Im hitting the diff cover bolts with the RE crapbar, then go from there. Thanks to all for the insight...
Unread 12-30-2013, 05:03 PM   #2610
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
I guess as a jeep owner you never really do make up your mind. Decided to visit the new Clayton shop and pick up a couple goodies.
