AngryTJs Taranchula Rubicon Build - Page 161 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > AngryTJs Taranchula Rubicon Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 10-17-2013, 09:49 AM   #2401
dayriesw
dayriesw's Avatar
Do you have a photo for reference?
The one I posted two days ago showing the inner fender templates. Cant move a bit.
http://www.jeepforum.com/forum/f22/i...9/index75.html post 1112
Sorry for hijack
Impact Orange LJ - DD...sitting low, flat bottomed, fully armored and locked on 35s
dayriesw is offline   Reply With Quote
Unread 10-17-2013, 11:13 AM   #2402
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
If you look closely your AC line is in the exact same location as mine the only difference is the inner fender your trying to make comes up completely vertical making the AC line in the way where as mine is at an angle keeping the line under the hood and not visable.
AngryTJ is offline   Reply With Quote
Unread 10-17-2013, 12:33 PM   #2403
dayriesw
dayriesw's Avatar
Gotcha. I am going to replace it with a strait line when I get the chances.... Back to the regular-ly scheduled Taranchula Build
Unread 10-17-2013, 12:36 PM   #2404
gspup
Don't you hate spiders with a passion Lu ?
gspup is offline   Reply With Quote
Unread 10-17-2013, 12:47 PM   #2405
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Haha absolutely hate all kinds of spiders even if it's the size of a tic tac
Unread 10-17-2013, 02:51 PM   #2406
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
So I havent had much time to wheel or wrench but I did want to put together a list of items still needing to be addressed on the rig. I will be getting my rear main seal done to avoid leaking oil everywhere in the next couple weeks. Besides that the following list wont even be touched until after the 1st of the year when my wife and I will be looking to buy a house and I'll finally have a garage.
Winter To Do list:
-evo front 44 sleeves
-raised sway bar brackets
-tie rod flip
-Vanco Big Brake kit
-gusset the Cs
-savvy tailgate armor
-genright hood louvers
-rokmen strykers
-fix my destroyed body mounts and A pillar tie in
-cutout rear crossmember to improve rear uptravel
-test flex the rig and see if Ill need to outboard my front shocks
Once all that is done I will be looking to do the following (with no timetable in mind) to "finish" the jeep.
-hydro assist
-488 gears
-ARBs or selectable of that nature
-LED's
Unread 10-17-2013, 02:58 PM   #2407
bobthetj03
bobthetj03's Avatar
Impressive list! There is no such thing as "finishing the jeep"! LOL!
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
bobthetj03 is offline   Reply With Quote
Unread 10-17-2013, 03:34 PM   #2408
GregStephens2
Winter To Do list:
-tie rod flip
-gusset the Cs
-rokmen strykers
-hydro assist
-488 gears
-LED's
Thats a great list I might move the gears, lockers and assist up on the list but that just, me.
Some how I thought you already regeared?
Greg Stephens/Arboreal Specialties
http://www.arborealspecialties.com/Home.html
GregStephens2 is offline   Reply With Quote
Unread 10-17-2013, 04:52 PM   #2409
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
True
Originally Posted by GregStephens2
Thats a great list I might move the gears, lockers and assist up on the list but that just, me. Some how I thought you already regeared?
Well the to do list are all things I already have so they will be done first.
Unread 10-22-2013, 08:11 AM   #2410
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Rotated the tires yesterday for the first time in a long time. Main reason for delaying it so long is because I have two tires balanced with sticky weights and the others with dynabeads.
The 2 with weights I always kept in the front to avoid any vibes at highway speed but it was time to give it a try the opposite way around.
Went for a quick ride on the highway and at first as I got above 40 it started shaking like crazy. Not sure if the dynabeads had perhaps stuck to the inside of the tire from sitting so long? Stopped at a gas station inflated the tires to 28psi then jumped back on the highway and got it up to 70 without any major vibes so hopefully we are good to go.
Hardtop and hard upper doors are going on this week. Rear main seal getting done next weekend.
Unread 10-22-2013, 08:48 AM   #2411
JJeeper09
I have experienced different shimmy with tire pressure. Now they are on the low side of 25psi, and I rotated and got some shimming, so I'm going to inflate them up from that and see how she drives.
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is offline   Reply With Quote
Unread 10-22-2013, 03:20 PM   #2412
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
the tires were at about 20 psi when I had the shakes but I slowed down then went back up above 40mph prior to inflating to 28psi and it seemed to go away which led me to believe it was just the dynabeads and not the air pressure.
Unread 10-22-2013, 03:20 PM   #2413
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Who needs an LJ?
http://www.jeepforum.com/forum/f153/...miles-1711858/
Unread 10-22-2013, 06:17 PM   #2414
janesy86
Gotta be Fresh
janesy86's Avatar
Where'd that come from!?
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
Hylined '03 Rubi Build
Western MA 4x4
janesy86 is offline   Reply With Quote
Unread 10-22-2013, 06:32 PM   #2415
turbowilber
Epic, all you can say
turbowilber is offline   Reply With Quote
