AngryTJs Taranchula Rubicon Build - Page 156 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > AngryTJs Taranchula Rubicon Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 09-18-2013, 11:45 PM   #2326
aw12345
yup sho was, gotta do that Area BFE one more time
Come Y'all and enter, make this the best contest yet!
http://www.jeepforum.com/forum/f9/february-tj-month-contest-submit-now-2061065/
aw12345 is offline   Reply With Quote
Unread 09-19-2013, 05:13 AM   #2327
Danno6102
Danno6102's Avatar
Nice video Lu!
If you gopro guys want to get a super steady shot with a simple, cheap, hand held homemade piece of professional type equipment, check out the silver flyer gimbal on youtube. Small enough just to throw in the jeep & steadiness is 100% better.
http://www.youtube.com/watch?annotat...&v=vkp80rUi090
IndyORV
My Build
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline   Reply With Quote
Unread 09-19-2013, 05:50 AM   #2328
duc202
Thanks for that Danno. I need that for my wheeling vids
duc202 is offline   Reply With Quote
Unread 09-19-2013, 07:12 AM   #2329
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Originally Posted by AndyE View Post
I was digging the trail up until "The Waterfall". Then I thought to myself, not only no, but **** no.
yeah helldorado is no joke but holy **** was it fun
Nice video Lu, great memories.
great memories for sure.
Originally Posted by Sahara707 View Post
Awesome video! Some fine wheelin
Yes sir! Thank you
Originally Posted by MO2500 View Post
You are getting pretty good at the whole video thing man, looks like fun! Oh wait, it was
I enjoy making videos even though they may not be the best quality. I cant believe that trail was something like half a mile and it took us around 4 hours haha
Im in
Originally Posted by Danno6102 View Post
Nice video Lu!
Thanks Danno, thats definitely an interesting idea
AngryTJ is offline   Reply With Quote
Unread 09-20-2013, 01:20 PM   #2330
dukie564
1995 XJ Cherokee
youtube has a anti-shake feature you can run the video though to reduce the movement
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 283,000 mi and runnin' strong
http://www.jeepforum.com/forum/f22/project-danger-cart-xj-1297118/
dukie564 is offline   Reply With Quote
Unread 09-20-2013, 04:49 PM   #2331
duc202
youtube's anti-shake will kill your video. The gopro has a nice mechanism in it which helps a lot w stability. I just noticed it on the videos that I made this week out at Rausch
Unread 09-20-2013, 06:54 PM   #2332
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Just FYI... a lot of that video was shot by me and my 12yr old son, not really paying enough attention to being steady. We were having to much fun!
gst95dsm is online now   Reply With Quote
Unread 09-21-2013, 10:07 PM   #2333
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
I'm not a fan of youtube's anti shake feature.
I thought you guys did a great job Nate, don't forget you were also spotting while filming.
Unread 09-24-2013, 08:45 AM   #2334
duc202
Lou, when you installed your Genright stretch tank/kit, what other components did you have to replace, if any (such as control arms, rear driveshaft, etc)?
j
Unread 09-24-2013, 09:04 AM   #2335
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Originally Posted by duc202
Lou, when you installed your Genright stretch tank/kit, what other components did you have to replace, if any (such as control arms, rear driveshaft, etc)? j
For the tank install alone you don't need anything else. When you remove the stock tank you take the fuel pump assembly out of it and use that in the new genright tank.
For a stretch not only do you need a stretch tank or fuel cell but longer driveshaft, longer control arms, adjusted spring perches, outboard shocks, cut the body for the wheel to not make contact and potentially longer brake lines. Not sure if I missed anything.
Unread 09-24-2013, 09:15 AM   #2336
gst95dsm
gst95dsm's Avatar
For the tank install alone you don't need anything else. When you remove the stock tank you take the fuel pump assembly out of it and use that in the new genright tank. For a stretch not only do you need a stretch tank or fuel cell but longer driveshaft, longer control arms, adjusted spring perches, outboard shocks, cut the body for the wheel to not make contact and potentially longer brake lines. Not sure if I missed anything.
And it's a **** ton of work....
Unread 09-24-2013, 11:32 AM   #2337
duc202
****. I thought that I could make the move to a rear stretch kit after replacing my CA's to adjustable CAs. that's crazy for about 5 extra inches in the rear
Unread 09-24-2013, 12:01 PM   #2338
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
haha no...its not cheap or easy
Unread 09-27-2013, 11:56 AM   #2339
green50gt
green50gt's Avatar
Forgive me if this was covered Lu, but what is your take on the Defender high lines? Fit, install, etc.
I'm researching my next build: Rokmen no longer makes a flared high line, Sinister fab doesn't either, that leaves PSC and Gen right. Defenders come with a battery tray bracket - genright you fork out another $200 for that.
If you had to do it again would you go with the Defenders again?
green50gt is offline   Reply With Quote
Unread 09-27-2013, 12:06 PM   #2340
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
I love my hiline defenders.
Overall the fitment was great my only issue is with the inner fenders they designed them to kind of be in the way of my antirock arms. If you recall I welded a gusset to the grill to hold it back some and still need to grind down the antirock arm bolt a bit.
I would do it again if I had to.
