AngryTJs Taranchula Rubicon Build - Page 152 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > AngryTJs Taranchula Rubicon Build
1993-1998 Jeep Grand Cherokee Stainless Steel Exhaust Mani1996-1998 Jeep Grand Cherokee Header PanelBead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 08-14-2013, 12:39 PM   #2266
AngryTJ
Originally Posted by Hendrix
Awesome video man! You guys made a trip of a lifetime out of that.
Thanks John
It was a memorable experience that's for sure.
I have enough video for probably two more videos when I get around to it.
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
My Rubicon build[/B][/SIZE][/URL]
[URL="http://www.jeepforum.com/forum/f345/jf-trip-2-0-a-2608114/"][SIZE="3"][B]
2015 Colorado Trip[/B][/SIZE][/URL]
AngryTJ is online now   Reply With Quote Quick reply to this message
Unread 08-26-2013, 08:46 PM   #2267
AngryTJ
Incase anyone is interested
http://www.jeepforum.com/forum/f126/.../#post15839800
Unread 08-27-2013, 08:17 PM   #2268
AngryTJ
spent a couple minutes under the jeep tonight after putting on my fancy neoprene winch cover, tightened my jam nuts and transmission bolts and Im considering going up an inch.
Possibly try the currie 3" progressive springs.
I know I have to cut my rear crossmember where the old tank ties into so my upper axle mounts dont hit but I also dont think Im utilizing full uptravel in the rear unless I go a tad higher. Not only that but in the front my tracbar is slightly rubbing the diff
Going to cut the crossmember and grind the diff down a hair and go from there.
Unread 08-28-2013, 10:19 AM   #2269
bobthetj03
bobthetj03's Avatar
I didn't realize yours sat so low! Thoughts on the 3.5" cloak springs? Looks like they'd maximize droop, with the right shocks of course.
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
www.norcal-jeeps.com
bobthetj03 is offline   Reply With Quote Quick reply to this message
Unread 08-28-2013, 11:04 AM   #2270
AngryTJ
My concern now is when I cut the crossmember and get more uptravel will the upper arms run into the tub.
They currently dont but thats also because the axle cant travel any higher before hitting.
We'll see, Im prepping the jeep to go wheelin this sunday and then itll sit because my baby will be born in 3 weeks or less and Ill have more important stuff to do.
Unread 08-28-2013, 11:24 AM   #2271
jermeyg
How much uptravel do you have in the rear and how much room do you have between your truss and the diff? I have my uppers touching the tub while under full hard bump-axle supporting the weight of the rear. Your situation might be different as you are stretched but I don't think touching the tub under full hard bump is a bad thing. Any issues with removing the crossmember?
jermeyg is offline   Reply With Quote Quick reply to this message
Unread 08-28-2013, 12:06 PM   #2272
AngryTJ
I have not measured what I currently have but Id guess around 4 or 5" with one side stuffed while the other droops but at hard bump with both tires up at the same time probably only 2-3"
Unread 08-29-2013, 10:09 AM   #2273
duc202
how much lift do you have now?
duc202 is offline   Reply With Quote Quick reply to this message
Unread 08-29-2013, 10:16 AM   #2274
REDLYNER
Mall Crawling Racer
REDLYNER's Avatar
I have this problem as well and what I have learned is that if you jump the rig enough it will just self correct .
REDLYNER is offline   Reply With Quote Quick reply to this message
Unread 08-29-2013, 10:18 AM   #2275
brplatz
Haha this is damn good
The Second Amendment is in place in case they ignore the others.
[QUOTE=mrblaine;14089403]That's like saying you wish your boyfriend was a bit less gay.[/QUOTE]
[COLOR="Blue"]MOΛΩN ΛΑΒΕ[/COLOR]
[URL="http://www.nmoffroad.com"][COLOR="DarkRed"]NMOffroad[/COLOR][/URL]
[URL="http://www.overland-motorsports.com/"][COLOR="Gray"]Overland Motorsports[/COLOR][/URL]
[COLOR="DarkSlateBlue"][URL="http://www.jeepforum.com/forum/f22/brplatzs-tj-opv-1240947/#post13888971"]My Build[/URL][/COLOR]
brplatz is offline   Reply With Quote Quick reply to this message
Unread 08-29-2013, 08:46 PM   #2276
AngryTJ
2-2.5"
haha
Unread 08-29-2013, 08:52 PM   #2277
aw12345
You just have to be ready to start looking for your dentures when you land
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 08-30-2013, 08:14 AM   #2278
jermeyg
Lu could you measure the length of your rear springs (perch to perch)? With the 3" spring the ride height is about 11" and you can get 6" of uptravel. Hopefully that will be a reference point for you so you can decide if you want to try 3" springs.
Unread 08-30-2013, 10:17 AM   #2279
AngryTJ
Cool, thanks Jeremy
Unread 09-01-2013, 10:09 PM   #2280
G Beasley
Cool, thanks Jeremy
Jeremy is chocked full of goodness
How much longer til Baby Lu is due ?
G Beasley is offline   Reply With Quote Quick reply to this message
