AngryTJs Taranchula Rubicon Build - Page 149 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > AngryTJs Taranchula Rubicon Build
Building a Bumper?Ruffstuff Axle Simple Swap Kit!~Artec JK 1 TON SWAP~
Unread 07-29-2013, 10:57 AM   #2221
MO2500
Fabramicator
MO2500's Avatar
Originally Posted by 1981Chief View Post
So.....how much do you have into this beast of a jeep?
We don't talk about numbers... that's the #1 rule of being a Jeep owner lol
My Jeep Build
Useful tech links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is offline   Reply With Quote
Unread 07-29-2013, 11:03 AM   #2222
Danno6102
Danno6102's Avatar
that's like asking a chick how much she weighs.
IndyORV
My Build
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline   Reply With Quote
Unread 07-29-2013, 11:06 AM   #2223
MO2500
Fabramicator
MO2500's Avatar
Funds are low for hydro assist right now but I am curious to see how yours holds up Mike. Might try and avoid buying the PSC box and save some cash
If you want to move the 1 (or 2?) holes to swap to a saginaw box I will gladly build you a steering box. Mine is working awesome now!
Durability wise I see no difference with the PSC gear. I screwed up rushing to do the other box and didn't clean it out thouroughly. I also didn't double check that my adjustments hadn't changed between mock up and final assembely but your adjustments need to be spot on with the PSC kit as well so that isn't an issue with the stock box.
I only have ~ $600 into my Hydro assist and it's all PSC pump, reservoir, ram, hoses, except the box and Derale cooler.
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 07-29-2013, 12:08 PM   #2224
aw12345
Only the top mounting hole needs to be moved, bottom holes are identical.
Fitted both a 2000 and a 1997 box on my Jeep, didn't mess with the lower 2 holes
Come Y'all and enter, make this the best contest yet!
http://www.jeepforum.com/forum/f9/february-tj-month-contest-submit-now-2061065/
aw12345 is online now   Reply With Quote
Unread 07-29-2013, 12:23 PM   #2225
MO2500
Fabramicator
MO2500's Avatar
That makes it relatively easy then.
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 07-29-2013, 12:56 PM   #2226
yellow_snocone
Damn only $600 mike thats not bad at all. Seems like its just a matter of getting everything right that could pose a challenge.
Military Jeepers
S.W. New Mexico region
Chester TJ build
2014 JF RUBICON TRIP
yellow_snocone is offline   Reply With Quote
Unread 07-29-2013, 01:59 PM   #2227
Danno6102
Danno6102's Avatar
I just looked on rock auto & you can get a reman 2000 tj/xj box for $130.
IndyORV
My Build
Unread 07-29-2013, 03:06 PM   #2228
MO2500
Fabramicator
MO2500's Avatar
I pulled one from the junkyard last week for $25. It was getting all new seals and o-rings when I pulled it apart anyway (roughly $30). Looks and works like new now!
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 07-29-2013, 03:07 PM   #2229
MO2500
Fabramicator
MO2500's Avatar
No more work than you need to do when you install the PSC kit.
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 07-29-2013, 05:34 PM   #2230
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
this is my first time researching hydro assist so thanks for the info
AngryTJ is offline   Reply With Quote
Unread 08-02-2013, 06:58 PM   #2231
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Selling the following if anyone is interested...
Rokmen Alum strykers $150
18" arms $70
Unread 08-03-2013, 03:46 AM   #2232
freaknajeep
1971 DJ
In my opinion do what works for you...me personally would not even think of driving anything off-road that wasn't full hydro....I do know that there is a company selling an assist kit that comes with all the necessary pieces so you don't have to drill anything....I want to say it's psc..but I've had way many beers since I did that wasted research....if I can't turn my wheel with my pinky while digging in the cooler..I won't drive it....but then again my off-road rigs have never been dual purpose either...while I may drive them on street I wouldn't say it was legal..but then I do live in Mississippi...here long as you have brakes, lights and a seatbelt they will let you register anything...
Be carefull while Hugging the Trees...They leave dents on your Jeep....
Shhhhhh I'm not crazy...It's just the voices in my head
freaknajeep is offline   Reply With Quote
Unread 08-03-2013, 09:58 AM   #2233
Hendrix
TJOTY 2013
Hendrix's Avatar
Why are you not using the Stykers? I think they would look reall good with your Raceline wheels.
Hendrix is offline   Reply With Quote
Unread 08-03-2013, 10:07 AM   #2234
jermeyg
Hey Lu, here is some information I have gathered about PSC Hydro Assist, if you have seen it already please ignore.
http://www.jeepforum.com/forum/f22/2...l#post15567620
Post 192
jermeyg is offline   Reply With Quote
Unread 08-03-2013, 11:44 AM   #2235
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Thanks but I have no interest in full hydro especially for a street driven jeep.
I dunno really just thought about selling em to save up for hydro assist. If they don't sell ill put em on.
Post 192
Thanks Jeremy!
