AngryTJs Taranchula Rubicon Build - Page 112 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > AngryTJs Taranchula Rubicon Build
Rough Country Lift Kits and Parts!Dan's Old as Dirt Birthday Sale!Premium LED Lighting by VISION X, Proudly sold at ROCKRIDG
Unread 04-14-2013, 08:13 AM   #1666
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Originally Posted by dayriesw View Post
Very sexy fenders and hood.
Originally Posted by platinum5.9 View Post
Angry I'm excited to see it all come together. I love the fenders, hood and rear armor and flares. I'll be keeping up with this for sure.
Thanks man Im pretty pumped to get it all together!
Originally Posted by Hendrix View Post
Those corners turned out so good. I will seal them and then put a thin coat of seam sealer on the outer seam to keep water out before I paint.
They look great!
Originally Posted by duc202 View Post
are those Mikey's old rims and tires? that set looks great on your jeep
No but they are the same style rims as Mike used to have
AngryTJ is online now   Reply With Quote
Unread 04-14-2013, 10:51 AM   #1667
yellow_snocone
Looking good Lu I cant wait to see the complete finish product
Military Jeepers
S.W. New Mexico region
Chester TJ build
2014 JF RUBICON TRIP
yellow_snocone is offline   Reply With Quote
Unread 04-14-2013, 06:55 PM   #1668
aw12345
Post a few pics of your rear anti rock mount if you have time
Come Y'all and enter, make this the best contest yet!
http://www.jeepforum.com/forum/f9/february-tj-month-contest-submit-now-2061065/
aw12345 is offline   Reply With Quote
Unread 04-14-2013, 06:57 PM   #1669
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
I think I'll cut the entire bracket off chop it and mount it on the top side of the frame
Unread 04-14-2013, 07:47 PM   #1670
aw12345
If all else fails knock the nylon inserts out of the mount, find some tubing that will fit it and then do what needs doing. i guess your setup started as a curry mount behind the wheel TJ kit
Unread 04-14-2013, 09:06 PM   #1671
MO2500
Fabramicator
MO2500's Avatar
Lu, I don't have a good picture but if you cut the bracket about a 1/2" below the bushing sleeve straight across then it works pretty well, that's how I did mine. Just make sure you take the poly bushing out before welding.
My Jeep Build
Useful tech links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is online now   Reply With Quote
Unread 04-16-2013, 08:31 AM   #1672
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Spent a couple hours last nt cutting the upper arms down 2" and cutting the bungs out to reweld. (Disclaimer: My first welds on tube) Also patched and filled in the gaps from the coil bucket to the frame.
Tomorrow ill get it sitting on its own weight and measure for the out boarding of the shocks
image-1111715902.jpg   image-2927202456.jpg   image-3424774964.jpg   image-1762400408.jpg
Unread 04-18-2013, 12:27 PM   #1673
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Been feelin like **** the past couple days but was able to take advantage of a UCF 15% off email coupon and buy some windshield guards. Also planning to get the jeep rolling again this weekend
Unread 04-18-2013, 12:33 PM   #1674
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Windshield guards???? Never seen em, gonna have to check that out. Hope you feel better soon man!
gst95dsm is offline   Reply With Quote
Unread 04-18-2013, 12:37 PM   #1675
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Thanks man! Check em out
http://undercoverfab.com/misc-armor-...r-jeep-tj.html
Unread 04-18-2013, 02:37 PM   #1676
gst95dsm
gst95dsm's Avatar
Ill wait for you on this one, apparently the Gen rights don't fit well, and the ucf look a little odd to me with that weld seam in the middle. Gonna let you figure it out first, haha!
Unread 04-18-2013, 07:55 PM   #1677
Jeepin72
Is it the weekend yet?
Jeepin72's Avatar
Did you sort out those shock mounts and the GenRight tank? I had problems with my Clayton stretch and the GenRight tank and so did a buddy of mine (user name hoovail). I had to drill some holes through my new frame slots for the tank. Hoovail welded more steel to his tank and extended the GenRight mounting tabs to get a new hole location.
Jeepin72's Build Thread
Jeepin72 is offline   Reply With Quote
Unread 04-18-2013, 08:05 PM   #1678
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
I havent addressed it yet but Ill likely cut the frame for the shock towers in that location and just drill a hole through the towers to put a bolt and secure the front of the tank.
Unread 04-20-2013, 02:14 PM   #1679
Hendrix
TJOTY 2013
Hendrix's Avatar
Teaser....
Hendrix is offline   Reply With Quote
Unread 04-20-2013, 02:24 PM   #1680
gspup
Teaser....
Pimp !
gspup is offline   Reply With Quote
