AngryTJs Taranchula Rubicon Build - Page 107 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > AngryTJs Taranchula Rubicon Build
Rugged Ridge 8500lb Winch w/ Steel Cable $294.99 Shipped OSmittybilt Products at Oconee Off-Road!Building a Bumper?
Unread 03-24-2013, 11:52 AM   #1591
yellow_snocone
Yeah went with the genright stretch steel corners. I didn't want to mess with cutting my own wheel wells on some blanks
Good stuff
Military Jeepers
S.W. New Mexico region
Chester TJ build
2014 JF RUBICON TRIP
yellow_snocone is offline   Reply With Quote
Unread 03-29-2013, 11:47 AM   #1592
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
What's the hold up around here????
gst95dsm is offline   Reply With Quote
Unread 03-29-2013, 01:09 PM   #1593
yellow_snocone
Lets see your jeep stretch like Stretch armstrong
Military Jeepers
Chester TJ build
Unread 03-29-2013, 01:23 PM   #1594
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
The thing people call a job is taking all my time
haha In all seriousness Im making progress I just didnt plan to update the build until there is a good amount of work to report.
AngryTJ is offline   Reply With Quote
Unread 03-30-2013, 11:34 AM   #1595
djflyy
Wanderlust
djflyy's Avatar
to be sent for paint
You're not going to rattle can them? Just so touch-up is easier?
I'm even debating stripping my T&Ts up front and doing a rattle can black just 'cause touching up a metallic paint code is a PITA.
Boston Jeep Build Thread
North Shore Jeeps Website
Originally Posted by bmosing View Post
Cleaning this thing up is similar to a slightly abused pornstar throwing on a bunch of makeup to try to hide her eternal scars, but I think she doesn't look too bad
djflyy is offline   Reply With Quote
Unread 03-30-2013, 11:57 AM   #1596
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Scratching my head a little right now. Let me know if anyone has suggestions. So I'm cutting into the frame to move the upper buckets but the rear crossmember is welded directly behind this piece of the frame I need to cut out. How should I address this so the springs can fit in here?
Unread 03-30-2013, 12:28 PM   #1597
gst95dsm
gst95dsm's Avatar
I'd probably cut it, and work it into my new coil upper coil bucket since it looks like it's going to occupy the same location. All it's doing now really is holding up the front of the gas tank isn't it? As long as you don't cut the rear most cross member before you get that one secure again the frame will stay "relatively" square. That would be my ghetto fab thinking.
Unread 03-30-2013, 12:46 PM   #1598
IEcrawlerTJ01
More than a web wheeler
IEcrawlerTJ01's Avatar
It no longer hold the tank. Trench tank has new side mounts. All it does is body mounts
Angrytj
I would use the cut you started and just get rid of the entire crossmember an build a new one.
Remember it only holds the two body mounts now. And those are not hard to find a soloution for.
If you notch any lower like the barnes kit your gonna have to run a much smaller spring to achieve the same ride height
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline   Reply With Quote
Unread 03-30-2013, 01:00 PM   #1599
gst95dsm
gst95dsm's Avatar
Angrytj
Forgot about the body mounts! In that case since it's not hold the tank at all, and obviously no longer responsible for the shocks.... I'd make a new one just for the body mounts.
Unread 03-30-2013, 01:08 PM   #1600
IEcrawlerTJ01
This is what I said.
Jut make a new one to support body mounts. Nothing else
Nuff said...
Unread 03-30-2013, 01:14 PM   #1601
gst95dsm
gst95dsm's Avatar
Yep I was just agreeing.
Unread 03-30-2013, 03:04 PM   #1602
AngryTJ
Dreamin of Moab
AngryTJ's Avatar
Thanks for the advice guys. I'm thinkin Ill just notch the crossmember and use a smaller bucket. Potentially the ballistic fab ones and tuck the larger side on the inside of the frame?
Unread 03-30-2013, 07:18 PM   #1603
TJRHD
Ballistic fab stuff will never work on this forum...
NOT A HATER
TJRHD is offline   Reply With Quote
Unread 03-30-2013, 07:21 PM   #1604
Hendrix
TJOTY 2013
Hendrix's Avatar
X2. Stuff looks good on the cad machine, but is poop in the end.
Hendrix is offline   Reply With Quote
Unread 03-30-2013, 07:26 PM   #1605
gst95dsm
gst95dsm's Avatar
I'm sure you have it figured out but that coil bucket with the side piece looks perfect for a place to weld the "new" crossmember to if you so chose to make one, actually you could probably just section out a bit of the old one and reuse it. Now THAT's what I'd do. That would make the welding easier.... not so deep in there with the bucket on the backside. Of course I'm not sitting there looking at it so.... I'm just thinking out loud looking at your pics.
