AngryTJs Taranchula Rubicon Build - Page 10 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > AngryTJs Taranchula Rubicon Build
The Original 3/8" Ruffstuff Diff Cover!Safety Thimble FairleadsEngo winches available at www.rockridge4wd.com! Free shipp
Unread 11-06-2011, 07:05 PM   #136
AngryTJ
Haven't seen it around.
On a side note I got around to priming my Riddlers
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
My Rubicon build[/B][/SIZE][/URL]
[URL="http://www.jeepforum.com/forum/f345/jf-trip-2-0-a-2608114/"][SIZE="3"][B]
2015 Colorado Trip[/B][/SIZE][/URL]
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 11-07-2011, 05:02 PM   #137
AngryTJ
Whitejeep881 Im taking a trip out to Rausch Creek weekend of Nov19th...Any interest?
Unread 11-07-2011, 08:00 PM   #138
whitejeep881
Riddlers are da ****!!! they can take a beating, trust me i know lol. And about rausch its a little to late for me to take the date off work. The next time ill go to rausch will probably be in the beginning of april for the club comp. Hope to see you there.
whitejeep881 is offline   Reply With Quote Quick reply to this message
Unread 11-07-2011, 08:08 PM   #139
AngryTJ
No prob, by the way wheres that pic taken?
Unread 11-07-2011, 09:14 PM   #140
whitejeep881
mabell, mass. Its about 1.5 hours from milford, ct. We got a club run going up there in a couple weeks.
Unread 11-08-2011, 08:24 AM   #141
AngryTJ
What club might that be?
Unread 11-08-2011, 07:06 PM   #142
whitejeep881
sisoffroad. There are probably a half dozen members on there from milford, ct. But its mostly a younger ct based jeep club. We make trips to mabell pretty frequently and probably 3 rausch trips a year.
Unread 11-09-2011, 10:31 AM   #143
AngryTJ
How does someone go about joining the group? I may be interested if possible
No real news to report except my plans for the weekend to prep for next weekends wheelin trip:
1)Finalize install of Currie Rock Ribz
2)Finish paint and install Riddler covers
3)Complete bolt up of Rokmen Skid - previously only had 2 bolts holding it on
4)Retorq entire lift kit since its been almost 1500 miles from install
Unread 11-09-2011, 06:18 PM   #144
whitejeep881
Check out www.sisoffroad.com, And make sure you write in the newbie forum, and make it to some wheeling events.
Best of luck at rausch creek, make sure you do trail 1c, 13 b, those are some of my favs, dnt waste your time on the new properity its 80% green easy trails.
Unread 11-09-2011, 06:34 PM   #145
KevKaos
??? really ???
[SIZE="4"]KevKaos[/SIZE]
[SIZE="4"]Honey Badger Wheelin'[/SIZE]
[FONT="Arial Black"][SIZE="5"][COLOR="Red"]RED JEEP CLUB # 621[/COLOR][/SIZE][/FONT]
It's not much, but check out my build thread;
[url]http://www.jeepforum.com/forum/f22/kevkaoss-05-red-rubicon-build-thread-1170741/[/url]
[QUOTE=krashnpa;12397572] I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.[/QUOTE]
[QUOTE=squazz;13612008]so I use my original nuts?[/QUOTE]
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline   Reply With Quote Quick reply to this message
Unread 11-09-2011, 09:53 PM   #146
squazz
Originally Posted by KevKaos View Post
??? really ???
I think I got property on the new side
squazz is offline   Reply With Quote Quick reply to this message
Unread 11-10-2011, 03:53 AM   #147
krashnpa
JP did an article on this recently. RockKrawler got them together. Looks like a good run, will have to try it some day.
What!?! Your mailbox is right next to mine!
krashnpa is offline   Reply With Quote Quick reply to this message
Unread 11-12-2011, 01:03 PM   #148
AngryTJ
Retorq'd the entire suspension and found out my front passenger side shock is leaking so Ill def be calling Zone for a replacement. Also painted the Riddler Covers and fully mounted the driver side rocker panel. (before and after pics)
Unread 11-12-2011, 01:06 PM   #149
AngryTJ
Installed Rubber gasket to keep the elements out from behind the rocker panel
Unread 11-12-2011, 01:07 PM   #150
AngryTJ
Bastard Rockers take FOREEEEVER to install. Mock up the rocker, mark holes, take down, drill holes, back up, holes dont align, drill holes in rocker to adjust for misalignment, repeat process over and over, glue gaskets to rockers, bottom holes dont align due to the 1/4 gasket, realign drill more bolt up YOU GET THE POINT, F'N ANNOYING.....
Looking to change the diff fluid and covers tomorrow as well as fully bolt up my steering box skid. If I get some help Im also hoping to partially bolt up the passenger side panel
