Allgood_73's Build - 2004 Jeep Rubicon - Page 3 - JeepForum.com
post #31 of 533 Old 12-23-2010, 10:59 AM
NMLJ
NMLJ's Avatar
Yeah, I was being a lil sarcastic. Lol
NMLJ is offline
post #32 of 533 Old 12-23-2010, 01:25 PM Thread Starter
Allgood_73
No Compromises
Allgood_73's Avatar
Ehh, I like it... saves people who just wanna see the build and not all the crap in between.
Just ordered my mml from Brown Dog ... cant wait to get them!
When I get home on in a few days I'll order the Clayton lift, tummy tuck, Currie anti-rock, Currectlync Steering System, Bilstein 5100 Shocks, and a couple other skids. I'm not sure when I'll pick up the 35's... but probably sometime next week.
Can't believe how fast it's coming along now. Things have really started to take off.
Allgood_73 is offline
post #33 of 533 Old 12-23-2010, 01:56 PM
NMLJ
NMLJ's Avatar
You honestly do have a nice jeep and build going.
I do have a question though. If someone had posted in the middle of you "reserving" your posts, would you have asked them to delete it?
/l ,[___],
l--L --OlllllO-
()_) ()_)-o-)_)
-2006 Impact Orange LJ-
MY BUILD THREAD
THE HARDEST THING ABOUT A ZOMBIE OUTBREAK WOULD BE PRENTENDING NOT TO BE EXCITED
NMLJ is offline
post #34 of 533 Old 12-23-2010, 02:24 PM Thread Starter
Allgood_73
No Compromises
Allgood_73's Avatar
haha, it's funny you should say that.... I was pretty nervous someone would shoot a quick reply in between and say something like "Gotcha!". My buddy (01LimitedXJ) was over at the house when I was putting them in and he almost pulled out his phone and did just that.
Cheers man, I'll post pics when all the goods arrive
post #35 of 533 Old 12-23-2010, 02:38 PM
01LimitedXJ
hahaha i was trying to i couldnt get a signal...dang tmobile.
sweet deal on the MML, ill hit up glenn about borrowing the cherry picker. ive got to pic up some more hd jackstands...or make some more tall ones...i want to pull the front axle on mine this weekend...also pulling the rear once i make an axle cart. guess who gets to help carry the 14 bolt
01LimitedXJ is offline
post #36 of 533 Old 12-23-2010, 05:44 PM Thread Starter
Allgood_73
No Compromises
Allgood_73's Avatar
...please no.
post #37 of 533 Old 12-24-2010, 03:43 AM
ItsaFinRubicon
glad there's another rubi build on here... keep up the good work
|R.C. 4"|PSC|Smittybilt|35" KM1|QTec|R.C.|
Originally Posted by Dtowngoalie View Post
rausch frock rauschhhhhhhhhhhh
Originally Posted by ajamison View Post
trails frock trailssssss!
ItsaFinRubicon is offline
post #38 of 533 Old 12-24-2010, 08:26 AM
Sgt.Fuzz
So far, so good.
My build:
Sgt.Fuzz is offline
post #39 of 533 Old 12-24-2010, 11:15 AM Thread Starter
Allgood_73
No Compromises
Allgood_73's Avatar
Alright guys, I need your help:
I'm looking to do the Clayton Long Arm lift with their oil and transmission skid plates and I really like how I will not have to cut the skid plates in order to get the long arm kit to work. I also really like how it's two pieces and makes maintenance easier.
That being said, I could go with UnderCoverFab and get the tummy tuck for close to half the cost and with pre-cut holes for drainage and the oil.... but my biggest concern is the UCF skid shows to increase clearance by 2.5" while Clayton only shows a 1.5" clearance gain.
Are the numbers really the same? I'm thinking Clayton might be stating the height from JUST the skid plates, whereas UnderCoverFab might be stating the height of the skid plates + 1" body lift.
post #40 of 533 Old 12-24-2010, 03:29 PM Thread Starter
Allgood_73
No Compromises
Allgood_73's Avatar
I checked with UCF and they confirmed that the 2.5" clearance is not including any body lift. The stock skid hangs down 4.5" while their skid hangs down 2".
That being said....I need help deciding. Both of these are the 1/4" steel... not aluminum... that way I can compare "apples to apples":
Under Cover Fab = $507.84 Shipped
http://undercoverfab.com/56-322-thic...kid-plate-.jpg
Pros:
Much Cheaper
Pre-drilled drainage holes
Pre-drilled oval oil drainage hole
2.5" of additional clearance
Cons:
Holes cause it to be slightly weaker and possibly get hung up on rocks.
The engine skid brackets look weaker than that of Clayton's.
Clayton Offroad = $736.25 Shipped
http://claytonoffroad.com/images/SP-TJCB.jpg
http://claytonoffroad.com/images/SP-TJ-1.jpg
Pros:
Main skid plate is a 2 piece design with cradle which holds the transmission without the skid plate being on.
No holes makes the skid slightly stronger.
Appears to be a more "solid" skid plate system... such as the rear skid brackets.
Cons:
Much more expensive
Must remove engine skid each time I need to do a oil change.
Lack of drainage holes allow water / mud to sit on top of the skid and form rust.
1.5" of additional clearance. 1" less clearance than the UCF skid.
post #41 of 533 Old 12-24-2010, 03:48 PM Thread Starter
Allgood_73
No Compromises
Allgood_73's Avatar
Well, I think my mind is now made up. Matt @ UCF just called me and we had a great chat. I am actually going to go with Ultra High-Clearance skid plate system and then use a LoPro transmission mount. This will give me a total of 3.5" of additional clearance.
Matt also told me that I'll most likely have to two notches out of the back of the skid plate in order to fit the Clayton long arm brackets. He said that when you do this, it makes the skid plate 33% weaker than the normal state... therefore, just mount the skid up, drill an initial hole through the skid and frame, then pull down the skid, drill out the frame hole to what is needed to fit a Jeep OEM rivet nut, and then the plate is back to full strength.
I think the pros now easily outweigh the cons.... so UCF, here I come!
post #42 of 533 Old 12-30-2010, 02:05 PM Thread Starter
Allgood_73
No Compromises
Allgood_73's Avatar
Alright, over the last few days I went on a huge shopping spree to take my TJ in to "stage 2" of the build:
I bought Brown Dog mount mount lifts on the 23rd and even though it was over the holidays... I still got them on the 29th. After seeing them...WOW! Not only did Tim ship them fast over a holiday, but the packaging was top notch, and the mml itself looks to be impervious. This is only topped off by a great price, a jeepforum discount, and free shipping. Brown Dog is already highly recommended in my book.
Next, I went through Kolak here on JeepForum to order my Claytons Offroad 4" long-arm lift kit, Bilstein 5100 series shocks, Currie Currect-Lync steering system, and Currie Anti-Rock swaybar system. To top off the deal, he threw in a OME SD40 steering stabilizer and RE rear extended swaybar endlinks since the Clayton kit does not come with rear extensions (for whatever reason). He was a pleasure to buy from, did his best to give me the best possible price, and was easily available over Christmas weekend. Should be here within the next couple weeks... to my surprise, Kolak said Clayton shutsdown the entire week after Christmas.
Lastly, I ordered the UCF 1/4" carbon steel full tummy tuck in the ultra high clearance (only hangs down 1 inch!) with the LoPro rubber transmission mount. I have already received the shipping notification from them... I couldn't believe their turn around time.
Between the lift, tires (not YET bought), and tummy tuck, I will have an impressive 9.5" of additional clearance between me and the ground. Now just to get it all installed... and then take it on a little wheelin trip!
post #43 of 533 Old 01-05-2011, 01:42 PM Thread Starter
Allgood_73
No Compromises
Allgood_73's Avatar
Updated my build to be in chronological order instead of different sections. It's much easier to see where I started at and where I am now.
I'll be adding some pics tonight and will try to update the spreadsheet too.
Thank you to all who voted me the
AND
Built Not Bought... pshh... how about, Wheeled Not Garaged.
An unbreakable toy is useful for breaking other toys.
Buyers / Sellers To Avoid: sidetracked
post #44 of 533 Old 01-11-2011, 09:10 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Damn dude, You have been busy since I checked in last. If you need some help let me know. I have access to a welder.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #45 of 533 Old 01-11-2011, 10:44 PM
Sgt.Fuzz
Nice! Any progress pics yet?
My build:
Sgt.Fuzz is offline
My 2004 Rubicon TJ Build havoc64 Jeep Builds 90 01-13-2017 09:08 AM
Starting the build! 2004 Jeep Rubicon samv1368 Jeep Builds 47 12-17-2011 08:30 PM
2004 NC Rubicon Build Hinson Jeep Builds 134 03-04-2011 11:12 AM
2004 Jeep Wrangler Build tib0lt Jeep Builds 4 08-13-2010 09:30 PM
Pre-built 2004 Rubicon Build jrbrannan Jeep Builds 3 08-05-2010 12:17 AM
